W123 transmission cooler lines hoses - Printable Version
+--- Thread: W123 transmission cooler lines hoses (/showthread.php?tid=1631)
W123 transmission cooler lines hoses - rdirtycar - 08-17-2010
The cooler line orfices in the 722.3x transmission are female 14mm x 1.5. Use 14mm banjo to 6an available from Pegasus. The male fitings on the transmission cooler are 16mm x 1.5. Use female 16mm x 1.5 to 6an from BAT Mocal. Standard 11/16 hose supports around radiator hose and fender washers bolted to the stock locations. I'll put pictures of it all in my car profile when I finally wake up from this project.
RE: W123 transmission cooler lines hoses - Captain America - 08-18-2010
Great info. THANKS!
