Hugh makes an ALDA from an ADA - Printable Version
+--- Thread: Hugh makes an ALDA from an ADA (/showthread.php?tid=1978)
Hugh makes an ALDA from an ADA - HughF_UK - 11-17-2010
So as my M series bosch pump has no ALDA on the top (it came from a uk spec w124 300d) I need some way of controlling the off-boost smoke.
So this Bailey dump valve got donated to the cause:
[Image: 20101117_001.jpg]
Half an hour in the lathe and it looks like we're getting somewhere:
[Image: 20101117_008.jpg]
The plan is to rethread the top plate to accept an m10 socket cap screw, make a new piston rod that will seal into the lower steel part (which has a small lip seal inside) and then using a ptfe plug, resin up the dump ports and sleeve the outside with another aluminium tube. I'll then fit an air connection to the underside of the piston.
Increase boost = rising piston Smile
RE: Hugh makes an ALDA from an ADA - ben2go - 11-17-2010
I'm lost but maybe in the end I'll get it.Still learning this ALDA stuff.
I get this puzzled but intrigued look every time I look at an ALDA thread.
[Image: faq-photo.jpg]
RE: Hugh makes an ALDA from an ADA - Biohazard - 11-19-2010
^^ Haha! I love that look!
Thats a nice looking Alda you're working on there! Can't wait to see how well it works out.
