Leaky injector? - Printable Version
+--- Thread: Leaky injector? (/showthread.php?tid=3275)
Leaky injector? - BSharp - 01-15-2012
I have what at first I thought was a miss on my 87 190D Turbo. If I slighty let up on the brake when idleing in gear it will slightly lurch because of one cylinder (at first I thought it was a miss). I used my IR gun to check exhaust manifold temps.Atidle#2cyl is about 20 deg hotter than the rest. It seems maybe it is getting too much fuel. Does that sound right? I did replace the fuel delivery valves a little while ago but I am not sure if it related.
