How much for a mechanical pump for an OM606 turbo? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: How much for a mechanical pump for an OM606 turbo? (/showthread.php?tid=3333) |
How much for a mechanical pump for an OM606 turbo? - gn3dr - 02-08-2012 Hi I briefly mentioned on here before that I was planning an OM606 + 722.6 transplant from a '99 E300 into a 1979 Jaguar. I have only just started removing the engine and box + wiring from the donor car in the last 2 weeks. I really want to achieve the challenge of getting the whole thing running on the orignal electronics - ideally removing the electronic key and immobiliser crap. However if this proves to be too time consuming my backup plan is what is suggested on here all the time - fitting the mechanical pump from a 603 turbo and also either fitting a mechanically controlled auto box, convert to manual or fit an independent controller to the 722.6. As I am in Ireland though there were no 603 turbos sold here or in the UK so I've no easy access to the pump. Where is the best place to source a turbo 603 pump and roughly how much should one cost - I don't really need to modify it for major power - if I got more or less what was on the stock E300 that would do for now as this will be a daily driver. RE: How much for a mechanical pump for an OM606 turbo? - gn3dr - 02-09-2012 Anyone got any pointers? RE: How much for a mechanical pump for an OM606 turbo? - JustPassinThru - 02-09-2012 If you had waved $150 plus postage at me three days ago, I could have gotten you a just-overhauled OM603 IP, Bosch # 0 400 076 992, from a 1987 300SDL. Tomnik tells me that his excellent custom-made elements can be built into it, even though it is an earlier-style model of this pump. But, regrettably, the car went to the crusher yesterday afternoon. RE: How much for a mechanical pump for an OM606 turbo? - erling66 - 02-09-2012 In Norway you are talking 300$ if you can find one. Everyone wants them RE: How much for a mechanical pump for an OM606 turbo? - gn3dr - 02-09-2012 (02-09-2012, 03:25 PM)erling66 In Norway you are talking 300$ if you can find one. Everyone wants them OK Thanks for the replies people. Good to have a baseline. I am almost done ripping out the wiring for the engine and gearbox from this E300 - there's a lot of it. Does anyone know of any conversions that have successfully used the factory electronics - web searches throw up very little information on this. |
