Stupid question - VNT-turbo install - M21D24(BMW) - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Stupid question - VNT-turbo install - M21D24(BMW) (/showthread.php?tid=3439) |
Stupid question - VNT-turbo install - M21D24(BMW) - Diesel-Wiking - 03-13-2012 Hello guys. I've bought an VNT-turbo from 220cdi W211, since my original turbo is singing on its last phrase. I have questions about the steering of VNT. My question is stupid, but I want to give it a try: -What happens if I weld the "WG-rod", or pressure steering rod, in locked position, or lock the vacuum intake-line? Will it be driveable? it will propably give very high turbo pressure and the vnt-system want be able to be controlled, but still, will it work?! RE: Stupid question - VNT-turbo install - M21D24(BMW) - Simpler=Better - 03-13-2012 You can lock it into one specific place, you will have to monitor your boost levels to find the sweet spot for the actuator. I had my GT2056 setup so that it would still make 8psi on the highway when vacuum was removed. RE: Stupid question - VNT-turbo install - M21D24(BMW) - Diesel-Wiking - 03-13-2012 (03-13-2012, 09:02 AM)Simpler=Better You can lock it into one specific place, you will have to monitor your boost levels to find the sweet spot for the actuator. I had my GT2056 setup so that it would still make 8psi on the highway when vacuum was removed. Thanks, I will give it a try RE: Stupid question - VNT-turbo install - M21D24(BMW) - led-panzer - 03-13-2012 Get a second gauge for backpressure if you're going to do that. RE: Stupid question - VNT-turbo install - M21D24(BMW) - Diesel-Wiking - 03-13-2012 (03-13-2012, 09:14 AM)led-panzer Get a second gauge for backpressure if you're going to do that. You think it will be a problem? or just to controll the backpressure? RE: Stupid question - VNT-turbo install - M21D24(BMW) - Alastair E - 03-13-2012 (03-13-2012, 09:19 AM)Diesel-Wiking(03-13-2012, 09:14 AM)led-panzer Get a second gauge for backpressure if you're going to do that. It could well cause a problem. Too much exhaust back-pressure can completely bog-down the engine, so it will make less power than a N/A engine and make LOTS of smoke! The trick is to get the boost high and the back-pressure as low as possible,--Not easy!.... RE: Stupid question - VNT-turbo install - M21D24(BMW) - Diesel-Wiking - 03-13-2012 (03-13-2012, 12:29 PM)Alastair E(03-13-2012, 09:19 AM)Diesel-Wiking(03-13-2012, 09:14 AM)led-panzer Get a second gauge for backpressure if you're going to do that. The turbo is much bigger than the stock turbo and with bigger exhaust it might reduce the back pressure a bit, or? I will give it a try, both with open and closed actuator, and then try to adjust it both up and down, to see if I make it work... RE: Stupid question - VNT-turbo install - M21D24(BMW) - Simpler=Better - 03-13-2012 For what it's worth, when I first ran my 2056V I had the actuator in backwards...The turbo spooled instantly , but wouldn't let me go beyond 2,000repm. |
