M-pump automatic vs manual difference? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: M-pump automatic vs manual difference? (/showthread.php?tid=3954) |
M-pump automatic vs manual difference? - Falkrum - 09-28-2012 Hello. Can you tell me the difference between M-pump with automatic and manual transmission? I have 250D turbo om602 with automatic transmission. I can buy M-pump from 290D om602 with manual transmission. Can i install this pump in my 250D? RE: M-pump automatic vs manual difference? - aaa - 09-28-2012 The manual transmission models have the anti-jerk actuator attached to the bottom of the pump. It can be ignored when you install it on the automatic. RE: M-pump automatic vs manual difference? - pp d - 09-28-2012 (09-28-2012, 05:29 AM)Falkrum Hello. Can you tell me the difference between M-pump with automatic and manual transmission? You can use that pump, just take the hilavitkutin From the automatic pump and install it to a new one. RE: M-pump automatic vs manual difference? - aaa - 09-28-2012 (09-28-2012, 12:21 PM)pp d hilavitkutin Vacuum control valve I'm guessing? RE: M-pump automatic vs manual difference? - pp d - 09-29-2012 (09-28-2012, 04:54 PM)aaa(09-28-2012, 12:21 PM)pp d hilavitkutin Yes, thanks. I lost the English word RE: M-pump automatic vs manual difference? - Falkrum - 09-29-2012 Thanks a lot, guys! |
