Super Pumps from Finland - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Super Pumps from Finland (/showthread.php?tid=3957) |
Super Pumps from Finland - jeemu - 09-28-2012 If need 8mm pump and high fuel amount on high rpm s adress to contact is info@herlevi.fi They can give good service and thy listen customer wishes. RE: Super Pumps from Finland - Siekkinen - 09-29-2012 Max fuel up to 7200 rpm. 270mm3 max RE: Super Pumps from Finland - winmutt - 09-29-2012 (09-28-2012, 01:50 PM)jeemu If need 8mm pump and high fuel amount on high rpm s adress to contact is info@herlevi.fi Pics or it didnt happen! Does this mean Jeemu has another project in his hands? RE: Super Pumps from Finland - tomnik - 09-29-2012 interesting how you can get 270 ccm/1000 with 7mm plunger lift minus pre lift and a diameter of 8mm .... But anyway, what nozzles are suitable for those delivery and rpm? Any changes in hard line design and delivery valves? Different governor springs or just light fly weights? Daily drivable? Tom (09-29-2012, 09:03 AM)Siekkinen Max fuel up to 7200 rpm. 270mm3 max RE: Super Pumps from Finland - dieselmeken - 09-30-2012 (09-29-2012, 03:48 PM)tomnik interesting how you can get 270 ccm/1000 with 7mm plunger lift minus pre lift and a diameter of 8mm .... Yes this is intresting, sounds like pure race in my ears, not for daily drive & 270cc with std deliveryvalves sound a bit too much, maybee with modified valves, but Jeemu sure have some answer to us. RE: Super Pumps from Finland - jeemu - 09-30-2012 Pleace read that start post again. RE: Super Pumps from Finland - mantahead - 10-01-2012 (09-30-2012, 03:55 PM)jeemu Pleace read that start post again. secret pumps from finland RE: Super Pumps from Finland - dieselmeken - 10-02-2012 Yes, Big secret. I got a mail anyway. Hi. Is the 7000 rpm M-pump drivable or only for race? Is the governor lightned or is it another governor spring in it? How to get 270cc of fuel? Modified deliveryvalves? Price on 8 mm pump? / Göran Hello, Possible use pump in drivable. Pump informations are secret , Sorry Price is 2200€ RE: Super Pumps from Finland - mercemann - 10-02-2012 Im using this pump. It is now adjusted to 190cc. A lot of power and much stronge then other super pumps, allso at low rpm. Not very easy to drive, but a lot i think is from my gearbox. I will change to a 722.6 during winter. Then i will report. RE: Super Pumps from Finland - Siekkinen - 10-05-2012 They do tractor pulling so they know how to make a pump with high delivery amounts. But unfortunately they don't tell anything about them. |
