Air line size question: turbo-IC-manifold - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Air line size question: turbo-IC-manifold (/showthread.php?tid=3991) |
Air line size question: turbo-IC-manifold - kotka - 10-10-2012 hi, I continue my project to "merry" om606A, mechanic pump with Tom's elements, GT28RS, customized IC and manifolds on my g-vagon. here the first cut of the manifold for your fun but more to follow so the question is: a) the compressor output is 51mm b) IC i plan put has 76mm in-out pattern what line's (turbo-IC-manifold) diameter would you recommend? i'm thinking of 76 or 63mm 76 would give more lag i think as the lines volumes is 21% larger then 63 ones. so more time to make sound pressure in there. any ideas? RE: Air line size question: turbo-IC-manifold - Simpler=Better - 10-10-2012 I've always believed that bigger is better so long as it fits under the hood. Don't know the exact effect on spool times, but it will probably be negligible (half a second? don't know) RE: Air line size question: turbo-IC-manifold - MFSuper90 - 10-10-2012 I'm not trying to rain on your parade or downgrade your work in anyway, but header pipes are all suppose to be the same length. Other than that sounds like a bada** project! And i dont know about spool time, but ive been told by many that the bigger the piping after the turbo, the better. RE: Air line size question: turbo-IC-manifold - kotka - 10-10-2012 Same length of pipes helps get max output of the tubular manifold at paticular rpms. The diff length defenitelly reduces max "effectiveness" but smooth the torque pattern. In my case the smooth and extended high torque pattern is the key - it's a offroader It would be nice to make all pipes equal but g-vagon hood doesnt allow for this and.... this is not a racer Btw - what makes bigger line better? RE: Air line size question: turbo-IC-manifold - Simpler=Better - 10-11-2012 You can always make the pipes .5m long and stick the turbo up above the hood RE: Air line size question: turbo-IC-manifold - MFSuper90 - 10-12-2012 (10-10-2012, 10:39 PM)kotka Same length of pipes helps get max output of the tubular manifold at paticular rpms. The diff length defenitelly reduces max "effectiveness" but smooth the torque pattern. In my case the smooth and extended high torque pattern is the key - it's a offroader I figured you knew more about it than i did, i was just throwin my 2 cents in The header looks pretty sweet! |
