parts list needed for superturbo conversion - Printable Version
+--- Thread: parts list needed for superturbo conversion (/showthread.php?tid=3994)
parts list needed for superturbo conversion - brianmccourt - 10-11-2012
as above i know i need a
intercooler
om603 intake with 6th cut off?
good lift pump
uprated diesel injection pump
hx30-35
clutch not sure what one yet
any other bits?
RE: parts list needed for superturbo conversion - mantahead - 10-11-2012
hi,
depends how much power you want.
you will also need exhaust manifold and some sort of wastegate.
dual mass flywheel will hold 385bhp
RE: parts list needed for superturbo conversion - brianmccourt - 10-11-2012
only after 250-300 was going to make a up pipe for the turbo and get one with a internal wastegate?
(10-11-2012, 03:46 PM)brianmccourt only after 250-300 was going to make a up pipe for the turbo and get one with a internal wastegate?
ok lad, i run 385bhp with Dieselmeken pump and hx35 fitted to uppipe and uprated clutch and pressure plate. Standard clutch give up at 266bhp.
RE: parts list needed for superturbo conversion - winmutt - 10-11-2012
What clutch are you running manta?
To OP, what engine do you have? 602?
RE: parts list needed for superturbo conversion - mantahead - 10-12-2012
[quote='winmutt' pid='45086' dateline='1350008583']
It was a clutch i got made in England for 1998 w202 c250td, it was the strongest pressure plate he had, it was 5 puck paddle. can't remember company name but can find out.
[Image: SU1HMDA4NzktMjAxMjA0MDctMTI0OS5qcGc.jpg]
[Image: SU1HMDA4ODAtMjAxMjA0MDctMTI0OS5qcGc.jpg]
This is after it has done some work.
RE: parts list needed for superturbo conversion - brianmccourt - 10-12-2012
its a deasent looking clutch how much? what boost you running mantahead?
any parts for sale????
(10-12-2012, 03:21 AM)brianmccourt its a deasent looking clutch how much? what boost you running mantahead?
was running 3.3 bar at one time with 12cm housing, no wastegate, and only run about 2.6 or 2.7 bar with 18.5cm housing. Clutch was about £400 or so. Not much left, all sold to fund new project. I have welded diff for c250, c250 manual box, some e300 bits as well, also holset hx35 with two different exhaust housings.
alri how much for the hx? prob be bit big for my one would it ?
hi,
i sent you pm.
