Element's DieselKontor - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Element's DieselKontor (/showthread.php?tid=4315) |
Element's DieselKontor - bruno_pinho - 02-02-2013 Hi Guys ... Someone can tell me if the elements of the 7mm DieselKontor deducts more fuel than the stock 6mm elements from Bosch? thanks RE: Element's DieselKontor - winmutt - 02-02-2013 Deducts? More bigger elements == more fuel == less fuel economy. Not sure what you were asking really. RE: Element's DieselKontor - bruno_pinho - 02-02-2013 My question comes from reading some negative feedbacks on these elements. The question is: Even though they are not as good as elements that have proven here in the forum, I will not be able mentendo one of these instead of a 6mm better flow = more whp's. I'm not looking for crazy powers, but wanted something more than I have who are 265hp OM605's an electric pump. RE: Element's DieselKontor - winmutt - 02-02-2013 Not sure what DieselKontor is? Not sure who's elements you are taking about. RE: Element's DieselKontor - bruno_pinho - 02-02-2013 They say are elements of ford transit ..... RE: Element's DieselKontor - raysorenson - 02-02-2013 (02-02-2013, 01:02 PM)winmutt Not sure what DieselKontor is? Not sure who's elements you are taking about. http://www.dieselkontor.de/product_info.php?products_id=3462&osCsid=32af289857dd1e4582bd82648d6c85f9 RE: Element's DieselKontor - bruno_pinho - 02-04-2013 then nobody can say anything about these elements ... what kind of performance may have in relation to 6mm bosch. RE: Element's DieselKontor - dieselmeken - 02-04-2013 I can Old 7 mm, good for 120cc, No retarded notch for later ignition at low idle. Engine goes a bit hard Good for 350-400hp in 6 cyl engine I dont use them. For power up to 2-250hp, OM606 6mm Bosch is to prefer. For moore power, 7,5-8,0mm is da shit. RE: Element's DieselKontor - Savitas - 02-05-2013 (02-04-2013, 12:45 PM)dieselmeken I can Do you know any OM606 example with 6mm Bosch element and power around 250 HP? I want to know what kind of turbo is used? Even Holset HX 35 12cm2 seems to big at this case.. RE: Element's DieselKontor - EDH_Performance - 02-05-2013 (02-05-2013, 05:55 AM)Savitas(02-04-2013, 12:45 PM)dieselmeken I can A holset hy35 would be better than hx35 (02-05-2013, 05:55 AM)Savitas(02-04-2013, 12:45 PM)dieselmeken I can A holset hy35 would be better than hx35 RE: Element's DieselKontor - RedDiesel - 02-08-2013 Any videos of cars with DieselKontor elements? |
