Silly question about removing rack limiter - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Silly question about removing rack limiter (/showthread.php?tid=4319) |
Silly question about removing rack limiter - jenyus - 02-03-2013 So this is probably a silly question, but does the IP have to be removed from the engine to remove the rack limiter? RE: Silly question about removing rack limiter - Simpler=Better - 02-03-2013 If you're careful you can do it with a magnet. Have you read the IP tuning document before you yank it? RE: Silly question about removing rack limiter - jenyus - 02-04-2013 Okay cool, yeah I read the runin guide already. Thanks! RE: Silly question about removing rack limiter - RedDiesel - 02-08-2013 Best way to remove it is to first pull out its alignment dowel from the pump body so you have room. |
