Throttle linkage OM606 with 603 pump - Printable Version
+--- Thread: Throttle linkage OM606 with 603 pump (/showthread.php?tid=5472)
Throttle linkage OM606 with 603 pump - Domino81 - 03-27-2014
Hi,
Is there any part that can be easily adopted to move the pump throttle lever? the solution that I have got from om603 gives me about 40mm of movement whereas lever on the pump can be moved by c.a. 80mm.
Is there any throttle that can adopted easily from another car, is there a throttle that can be purchased? or you guys mostly weld&bend based on own invention?
RE: Throttle linkage OM606 with 603 pump - hansebanger77 - 03-27-2014
I use stock linkage from 606NA but I use also the NA intake. But the NA linkage can be fit on the turbo intake
RE: Throttle linkage OM606 with 603 pump - mantahead - 03-27-2014
hi,
you could just rig up a cable
RE: Throttle linkage OM606 with 603 pump - Hario' - 03-27-2014
Clevis crimped onto a throttle cable & DIY bracket?
RE: Throttle linkage OM606 with 603 pump - Domino81 - 04-01-2014
any pictures?
Technical drawing in CAD? Smile
