722.6 Information wanted - Printable Version
+--- Thread: 722.6 Information wanted (/showthread.php?tid=6386)
722.6 Information wanted - ross - 03-27-2015
First post on this forum, looking for some information on the 722.6 for a conversion in my Land Rover 90.
Having done a bit of searching and reading on this forum I think I am looking for a 722.634 gearbox. I want the higher ratio W5A580 version for the gearing but the strength is an added bonus.
Can someone confirm what model Mercedes in the UK would have been fitted with a W5A580 that will bolt straight onto an OM606?
Thanks in advance.
RE: 722.6 Information wanted - erx - 03-27-2015
Only W5A580 for OM606 is from 270CDI.
RE: 722.6 Information wanted - ross - 03-27-2015
(03-27-2015, 05:48 PM)erx Only W5A580 for OM606 is from 270CDI.
From which model though? W210? or W211? I could not find the information.
RE: 722.6 Information wanted - erx - 03-28-2015
They are the same, w211 have some internal improvments but they both will bolt on. Also w203 c270cdi.
RE: 722.6 Information wanted - ross - 03-29-2015
(03-28-2015, 04:10 AM)erx They are the same, w211 have some internal improvments but they both will bolt on. Also w203 c270cdi.
The ebay seller has given me this number from the box: r140271 26 01.
Is that correct for a 2001 c270cdi?
Edit: http://pages.ebay.com/link/?nav=item.view&alt=web&id=151612382926
RE: 722.6 Information wanted - erx - 03-29-2015
Code starting with R140... is for housing only but it seems to be the right one.
(03-29-2015, 07:27 AM)erx Code starting with R140... is for housing only but it seems to be the right one.
Where on the box will it show the 722.6XX number so I can make sure? Its an hour each way from me.
and by the way, thank you for the help... It is much appreciated as I'm new to MB stuff!
You can see it on the last picture, little square on the side of the housing. Sometimes numbers are hard to see.
http://www.ebay.com/itm/MERCEDES-CLK-W209-270-CDI-2-7-DIESEL-AUTOMATIC-GEARBOX-WITH-TORQUE-CONVERTER-/181678347974?pt=LH_DefaultDomain_3&hash=item2a4cdf96c6
RE: 722.6 Information wanted - ross - 03-31-2015
(03-29-2015, 07:50 AM)erx You can see it on the last picture, little square on the side of the housing. Sometimes numbers are hard to see.
Right the number he has sent me doesn't tie up to the list I have.... its 722640. The number isn't on the list!
Any idea what it is then?
RE: 722.6 Information wanted - erx - 03-31-2015
722.640 seems to be newer version from w211 or w203, 722.634 is from w210. I belive they only have internal differences and maybe different flexidisk flange.
RE: 722.6 Information wanted - ross - 04-01-2015
(03-31-2015, 11:18 AM)erx 722.640 seems to be newer version from w211 or w203, 722.634 is from w210. I belive they only have internal differences and maybe different flexidisk flange.
Found the information in your thread!
http://www.superturbodiesel.com/std/showthread.php?tid=6189&pid=69944#pid69944
The 722.640 is from either: W211 220CDI/270CDI/280CDI/
So from that it looks like it should bolt straight onto the OM606 Big Grin. Assuming the 647.961 has the same bellhousing pattern.
