WANT TO BUY: Double Water Pump Pulley - Printable Version
+--- Thread: WANT TO BUY: Double Water Pump Pulley (/showthread.php?tid=6560)
WANT TO BUY: Double Water Pump Pulley - Greazzer - 06-08-2015
Hello,
Looking for the double belt water pump pulley for the OM617 engine. I think there are 2 flavors. I will measure mine tonight since the one I have barely fits without rubbing the crank pulley. I recently got one at the local P-A-P but it was warped a hair -- just my luck.
Shipping should be $5.75 (flat rate priority envelope -- just wrap in newspaper or foam or something along those lines).
PM if you have one.
RE: WANT TO BUY: Double Water Pump Pulley - Greazzer - 06-08-2015
Mine is 6 7/8th. I am guessing the 2 flavors are different by a bunch and not just a few mm's.
RE: WANT TO BUY: Double Water Pump Pulley - Greazzer - 06-09-2015
Sourced one. THANKS everyone !
