Anyone know where to get stock style 16mm banjo bolt - Printable Version
+--- Thread: Anyone know where to get stock style 16mm banjo bolt (/showthread.php?tid=6714)
Anyone know where to get stock style 16mm banjo bolt - TurboTim - 08-28-2015
Dont want to convert to AN style and would rather have stock style plastic hose but I dont have any 16mm banjos in my parts bin.
RE: Anyone know where to get stock style 16mm banjo bolt - Volker407 - 08-29-2015
(08-28-2015, 06:00 PM)TurboTim Dont want to convert to AN style and would rather have stock style plastic hose but I dont have any 16mm banjos in my parts bin.
Oh come on!
please use your own brain! Big Grin Wink
http://www.ebay.com/itm/M16-x1-5-Banjo-Bolts-Washer-Fuel-Fitting-Banjo-Union-Bolt-Diesel-Petrol-hose-/270642509941
http://www.amazon.com/16MM-1-50-Banjo--Fluid-Adapter-Fitting/dp/B00J0JHSNY/ref=sr_1_2?ie=UTF8&qid=1440833663&sr=8-2&keywords=banjo+bolt+m16
http://parker.com/portal/site/PARKER/menuitem.c9e5838e8a4c0934704b7b10237ad1ca?searchbox=banjo%20bolt&selectCategory=ALL&vgnextoid=941b13fc0fa14110VgnVCM10000032a71dacRCRD&vgnextfmt=EN
google
bing
yahoo
Gruß
Volker
RE: Anyone know where to get stock style 16mm banjo bolt - hents99 - 08-29-2015
Any hydraulic shop can help you with it I guess.
RE: Anyone know where to get stock style 16mm banjo bolt - TurboTim - 08-29-2015
If you actually used your brain and read the post I am not looking for the bolt, I am looking for stock style banjos for the plastic lines not the bolts....like the MB banjo fittings. Thanks though.
Im not sure if these are specifically mb or what other places could I look. I can always do the AN route but they are just so big and bulky
RE: Anyone know where to get stock style 16mm banjo bolt - barrote - 08-29-2015
junk yard ... did u tried that route
(08-29-2015, 08:29 AM)TurboTim If you actually used your brain and read the post I am not looking for the bolt, I am looking for stock style banjos for the plastic lines not the bolts....like the MB banjo fittings. Thanks though.
Sorry, I hope you know I wasn´t  serious about that.  I had thought the smilies would have made that clear.
Gruß
Volker
RE: Anyone know where to get stock style 16mm banjo bolt - anjay - 08-29-2015
So, if I understand correctly, you need banjos for fuel filter? Or is it for for 16mm banjo bolts?
I have some, just not sure what exactly you are looking for.
RE: Anyone know where to get stock style 16mm banjo bolt - DiseaselWeasel - 08-29-2015
Try "banjo hose fitting" - like this? https://www.tyagiracing.com/products.php?product=16MM-Banjo-Bolt-Fitting-Kit-for-8mm-Hose
RE: Anyone know where to get stock style 16mm banjo bolt - hents99 - 08-30-2015
Most hydraulic shops sell these banjos and fittings like here: https://www.belmetric.com/metric-hoses-metric-banjo-bolts-and-fittings-c-14_850.html
RE: Anyone know where to get stock style 16mm banjo bolt - Hario' - 09-04-2015
Search 'banjo hose barb' at the same time.
