Om603 Twin charging help. - Printable Version
+--- Thread: Om603 Twin charging help. (/showthread.php?tid=6717)
Om603 Twin charging help. - Hearns - 08-31-2015
Hello, i have an om603 with 7mm pump and a hx35w. And i feel like its really slow from 0, and instead of changing turbo i would like to make a twin charge system using a eaton m62 supercharger with a magnetic pulley.
since its goin to be a daily driver also i would be ideal to be able to run it with only the turbo and disconnecting the superchargers magnetic pulley by a switch in the car.
My orignial idea was to make kind of a compound setup, with the supercharger blowing through the turbo and by doing that i think i would be quite easy to let the supercharger disconnect att about 0.7-1.0 bar of pressure and then open a flap in the pressure pipe and let the turbo breathe freely.
All input is welcome.
I also think that the heat from compunding it might be an issue but im by no means an expert when it comes to this..
RE: Om603 Twin charging help. - Duncansport - 08-31-2015
(08-31-2015, 04:52 AM)Hearns Hello, i have an om603 with 7mm pump and a hx35w. And i feel like its really slow from 0, and instead of changing turbo i would like to make a twin charge system using a eaton m62 supercharger with a magnetic pulley.
Do some searches on here as this topic has been discussed Ad nauseam  Sleepy
RE: Om603 Twin charging help. - barrote - 08-31-2015
well , u´re from sweden ?
what u really need is a dieselmeken superpump , with 7.5 mm element , or 8mm.
twin set up , im in favour of that, i belive 2 gt25 or gt22V, i like the idea!!!!
i have one M90 laying around to compound with a big turbine like u say, but honestly i´m happy now.
605 with a hybrid GT23V.
