Correct location for EGT probe? - Printable Version
+--- Thread: Correct location for EGT probe? (/showthread.php?tid=6745)
Correct location for EGT probe? - ho55 - 09-16-2015
Whats the best / correct location for an EGT probe on the OM606.962?
I have it mounted in the blank plug from the removed EGR pipe at the moment.
RE: Correct location for EGT probe? - Hario' - 09-16-2015
Anywhere before turbo, nearest to where it would see all gas flow is best (for averaged cylinder temp).
RE: Correct location for EGT probe? - barrote - 09-16-2015
egt well , yes it is where i have mine!!! and many other .....
RE: Correct location for EGT probe? - Hario' - 09-17-2015
I drilled & tapped directly into the iron (605)
[Image: photo4.jpg]
RE: Correct location for EGT probe? - 50harleyrider - 09-18-2015
Nice turbo adapter Hario. It looks like it has more flexibility than fixed one like DPUK sells. Where can I buy one similar?
RE: Correct location for EGT probe? - Hario' - 09-18-2015
Mine:
http://www.superturbodiesel.com/std/showthread.php?tid=6734
Ohh, I just saw you are in the US of A..
I uploaded the flange drawings herehttp://www.superturbodiesel.com/std/showthread.php?tid=4939 get them laser/water/plasma cut for real cheap, then buy 2.off: 2" ID weld-els from your local steel merchant, then buy: a 2.5"(IIRC) ID V-band adapter from your friendly parts store and get an even friendlier welder friend to mig it together for you for beers.
That is what I did.
Smile
(09-18-2015, 06:54 AM)50harleyrider Nice turbo adapter Hario. It looks like it has more flexibility than fixed one like DPUK sells. Where can I buy one similar?
