Where to buy vacuum actuator - Printable Version
+--- Thread: Where to buy vacuum actuator (/showthread.php?tid=6891)
Where to buy vacuum actuator - TurboTim - 11-23-2015
Looking to get rid of this CAN system and run a vacuum actuator on my HE351VE turbo. Anyone got one they want to sell of there turbo or does anyone know a website to buy vacuum actuators?
RE: Where to buy vacuum actuator - Hario' - 11-23-2015
Can't just use a pneumatic actuator but with vac? With other end open to atmospheric to provide potential difference across the piston?
RE: Where to buy vacuum actuator - TurboTim - 11-24-2015
I dont think you can. I think the plunger is bottomed out plus it would be pulling the wrong way then.
RE: Where to buy vacuum actuator - Hario' - 11-24-2015
(11-24-2015, 09:29 AM)TurboTim I dont think you can. I think the plunger is bottomed out plus it would be pulling the wrong way then.
Use double acting ones?
http://uk.rs-online.com/web/p/pneumatic-roundline-cylinders/2645065/?origin=null|fp&cm_sp=featureproducts-_-FeaturedProductsContent-_-2645065
RE: Where to buy vacuum actuator - Druk - 11-24-2015
Why vacuum? Just use a pressure wastegate actuator. Tapped off the pressure side of the turbo.
https://www.google.co.uk/search?q=turbo+wastegate+actuator&biw=1280&bih=579&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwji4r63yanJAhVBfg8KHb9zD0EQsAQIRA&dpr=1.5
Converted the vacuum system on a 606 to pressure and it works great.
[Image: alda003_zps76a6c195.jpg]
