om603 to om606 and keep cruise control working - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: om603 to om606 and keep cruise control working (/showthread.php?tid=7004) |
om603 to om606 and keep cruise control working - PedroFerreira - 01-24-2016 someone know if is possible make the swap and keep cruise control working? RE: om603 to om606 and keep cruise control working - benzguy - 01-24-2016 What chassis? W124? W210? RE: om603 to om606 and keep cruise control working - PedroFerreira - 01-24-2016 is an w124 RE: om603 to om606 and keep cruise control working - mcwfxx - 01-25-2016 (01-24-2016, 09:46 PM)PedroFerreira is an w124 Have a look at Baldur's ECU, it does cruise with the electronic om606/Bosch pump. https://controls.is/dsl1.html The thread about it here: http://www.superturbodiesel.com/std/showthread.php?tid=6975 Ive just bought.one not.fitted yet so can't comment on how well it works but no reason it shouldn't be fantastic! Baldur is great at answering questions, very helpful indeed. RE: om603 to om606 and keep cruise control working - barrote - 01-25-2016 Once u swap the 606 engine on that thing , u have to use the same pump , so all the functions in the car will be working. i belive there´s a second speed pick up in the pan , but u can swap the 603 pan in the 606 , like this u dont have to drill anything. u can keep the flywheel for the 606 , or if it is auto works same .... u can use the convertor, is direct swap. regards. RE: om603 to om606 and keep cruise control working - mcwfxx - 01-25-2016 Sorry, i completely misunderstood your post!.... |
