fuel line size - Printable Version
+--- Thread: fuel line size (/showthread.php?tid=7362)
fuel line size - yota4life - 08-17-2016
What's the fuel line size from the fuel filter to the sides of the ip the clear ones. Mine cracked ordered the wrong size. And haven't been able to fined the size anywhere online.
RE: fuel line size - NZScott - 08-17-2016
Don't know what engine you're talking about but if it's a 617 (which most 'muricans seem to have) try slipping 5/16" over the barbs but leave the clear hose still on the barb.
RE: fuel line size - zeeman - 08-18-2016
(08-17-2016, 10:46 PM)yota4life What's the fuel line size from the fuel filter to the sides of the ip the clear ones. Mine cracked ordered the wrong size. And haven't been able to fined the size anywhere online.
They are 6mm, I heat up the banjo fitting with a heat gun and push the tubing on and use a pex tubing crimp clamp. Works great and is tight.
RE: fuel line size - Tobulus - 08-18-2016
If you dont heat it up, you dont need the clamps. Thats the way truck brake piping is done.
