OM 606 Deck Height - Printable Version
+--- Thread: OM 606 Deck Height (/showthread.php?tid=8339)
OM 606 Deck Height - zeeman - 05-05-2020
I have a 606 block in the machine shop to be bored for new pistons. They just called and suggested that it needs to be surfaced to clean up the head gasket surface.
What is the allowed amount that can be taken off to be safe? If it is an issue we can always resize the rods to make up the difference.
RE: OM 606 Deck Height - barrote - 05-06-2020
A lot... if needed. Just to clear a gasket .1mm sufice and u can use a stock gasket. But u should acess CR
RE: OM 606 Deck Height - zeeman - 05-06-2020
barrote A lot... if needed. Just to clear a gasket .1mm sufice and u can use a stock gasket. But u should acess CR
Are there any thicker head gaskets available?
RE: OM 606 Deck Height - AlanMcR - 05-07-2020
A6060160520 Cylinder head gasket 1.85mm (vs. 1.65mm)
