STD Other Trucks, semis, vans, transporters and mogs. turbo conversio camper
10-07-2009, 10:48 AM #3
(10-07-2009, 05:03 AM)brianhymet Is there a possibility to use hand controled variable boost.
It should be very easy using a system like the attached picture. Being in Holland you should have access to a wide selection of variable vane turbos.
The hand cable pulls on the vane lever and the actuator (a normal wastegate actuator) prevents boost from passing a safe level. Using VNT turbo with an electronic controller will allow finer control of pressure due to their longer vane control lever.
This post was last modified: 10-07-2009, 10:50 AM by ForcedInduction.
Messages In This Thread
turbo conversio camper - by brianhymet - 10-07-2009, 05:03 AM
RE: turbo conversio camper - by winmutt - 10-07-2009, 05:33 AM
RE: turbo conversio camper - by ForcedInduction - 10-07-2009, 10:48 AM
RE: turbo conversio camper - by Hymermofiel - 03-28-2010, 12:22 PM
RE: turbo conversio camper - by ForcedInduction - 03-28-2010, 11:54 PM
RE: turbo conversio camper - by desmotre - 05-02-2010, 12:51 PM
