STD Tuning Brakes Best, Easiest Brake Upgrade W124 300TD
04-24-2015, 11:03 AM #12
u wont find much easier than that w203 c320 , it is almost bolt on . if u want i can guide u throug the steps.
unless u can find a better choice/price in a W124 E400. wich i can´t see how.
for start u check the calipers, usually they are marked with disk diameter and with, big numbers. in this way u can check out wich ones are better. big does not mean better. the big the diameter the beter. disk with has to do with cooling abilities.
in this case a 320/88 is far better than 29/60.
regards
regards
Messages In This Thread
Best, Easiest Brake Upgrade W124 300TD - by ak47is1337 - 04-20-2015, 05:23 PM
RE: Best, Easiest Brake Upgrade W124 300TD - by raysorenson - 04-20-2015, 09:13 PM
RE: Best, Easiest Brake Upgrade W124 300TD - by ak47is1337 - 04-22-2015, 01:29 AM
RE: Best, Easiest Brake Upgrade W124 300TD - by ak47is1337 - 04-22-2015, 04:55 PM
RE: Best, Easiest Brake Upgrade W124 300TD - by raysorenson - 04-22-2015, 07:20 PM
RE: Best, Easiest Brake Upgrade W124 300TD - by barrote - 04-23-2015, 11:58 AM
RE: Best, Easiest Brake Upgrade W124 300TD - by ak47is1337 - 04-23-2015, 02:35 PM
RE: Best, Easiest Brake Upgrade W124 300TD - by ak47is1337 - 04-23-2015, 02:38 PM
RE: Best, Easiest Brake Upgrade W124 300TD - by barrote - 04-24-2015, 05:53 AM
RE: Best, Easiest Brake Upgrade W124 300TD - by ak47is1337 - 04-24-2015, 07:00 AM
RE: Best, Easiest Brake Upgrade W124 300TD - by tjts1 - 04-24-2015, 11:02 AM
RE: Best, Easiest Brake Upgrade W124 300TD - by barrote - 04-24-2015, 11:03 AM
RE: Best, Easiest Brake Upgrade W124 300TD - by ak47is1337 - 04-25-2015, 03:27 AM
RE: Best, Easiest Brake Upgrade W124 300TD - by Duncansport - 04-27-2015, 12:21 PM
RE: Best, Easiest Brake Upgrade W124 300TD - by SurfRodder - 05-16-2016, 09:25 PM
RE: Best, Easiest Brake Upgrade W124 300TD - by SurfRodder - 09-25-2016, 10:55 AM
RE: Best, Easiest Brake Upgrade W124 300TD - by atypicalguy - 12-08-2018, 08:38 AM
RE: Best, Easiest Brake Upgrade W124 300TD - by ak47is1337 - 04-27-2015, 02:21 PM
RE: Best, Easiest Brake Upgrade W124 300TD - by capflya - 07-20-2015, 12:24 PM
RE: Best, Easiest Brake Upgrade W124 300TD - by ak47is1337 - 07-20-2015, 12:33 PM
RE: Best, Easiest Brake Upgrade W124 300TD - by hents99 - 07-20-2015, 04:10 PM
RE: Best, Easiest Brake Upgrade W124 300TD - by -Mackan- - 05-15-2016, 06:27 AM
RE: Best, Easiest Brake Upgrade W124 300TD - by Mh95e300d - 05-15-2020, 01:05 PM
RE: Best, Easiest Brake Upgrade W124 300TD - by m1tch - 09-06-2015, 05:56 AM
RE: Best, Easiest Brake Upgrade W124 300TD - by JoeB - 05-24-2016, 06:15 PM
RE: Best, Easiest Brake Upgrade W124 300TD - by atypicalguy - 12-08-2018, 08:50 AM
