STD Tuning Engine tomnik elements!
tomnik elements!
tomnik elements!
Pages (2): Previous 1 2
Petar
7.5mm M pump
459
03-10-2015, 03:51 PM #51
(03-10-2015, 03:35 PM)Joystick So what type pump is a om606 turbo pump? And wich type is a 606 non turbo pump?
Both are M pump. But in the W210 the mechanical governor was replaced with the EDC governor.
[Image: 606.962_pump01.jpg]
EDC and mechanical pumps share the same elements but the difference is there is no governor on the pump, it is controlled by the ECU. It is only a simple solenoid that moves the rack and the rack position sensor in the pump.  Wink
The 606 turbo pump has bigger 6mm elements versus 5.5 elements in the older pumps.
Those elements can be swapped right over to older mechanical pumps and they work perfectly   Smile
This post was last modified: 03-10-2015, 03:54 PM by Petar.
Petar
Joystick
03-10-2015, 06:10 PM #52
Ah Thanks. And exactly what is a governor?
My pump goes to dieselmeken anyways so no 6mm elements here Wink
Joystick
Kenny1813
03-26-2015, 11:53 AM #53
(03-10-2015, 06:10 PM)Joystick Ah Thanks. And exactly what is a governor?
it's a mecanical system to prevent over rev and control the amount of fluel injected depanding how much you press on the "gas" pedal. (short explanation)
- 1992 W201 black/grey soon with Turbo OM602        -
- 1983 Porsche 944 n/a                                            -
- 2001 Toyota Echo, my daily and tough 350 000km    -
Kenny1813
03-26-2015, 05:55 PM #54
(03-10-2015, 03:51 PM)Petar
hy petar, do u happen to know how is the rack position measured?
does it have anything to do with the imput voltage suplied to the electroactuator? or it is a completely dif circuitry?
Petar
7.5mm M pump
459
03-27-2015, 03:13 PM #55
(03-26-2015, 05:55 PM)barrote
Haven't seen the guts of those in person but from what i gathered on the internet it is NOT a simple potentiometer. It is a variable inductance sensor called HDK. Actually there are two of them because inductance varies a lot with many factors such as tempetature. So there is one that is fixed to provide a reference value for measuring and another one that measures the rack position. You CAN'T just connect 5V to it and get a variable output, you need to feed it with high frequency AC voltage and measure the current draw. Designing a circuit that will accurately do this is not easy.
The actuator is pretty much indepedent of the sensor, it is a simple solenoid driven with PWM DC power.
This guy made his own controller for electronic pumps but only works for VE pumps since those have a potentiometer rack position sensor, and that couldn't be easier to read. But he is trying to figure out the HDK sensor and once he does this will be plug and play.
http://dmn.kuulalaakeri.org/dmn-edc/
This post was last modified: 03-27-2015, 03:14 PM by Petar.
Petar
bricktron
'77 240D
174
03-28-2015, 12:28 AM #56
once that signal is deciphered, it sounds good for controlling a variable vane turbo (or even a supercharger).
bricktron
