STD Maintenance General Towing an '83 300SD?
Lapoint
11-06-2008, 07:16 AM #1
Will I damage the transmission if I tow it two blocks, in neutral, with the rear wheels on the ground? I doubt I will exceed 20mph while towing.
Lapoint
11-06-2008, 02:02 PM #2
Lapoint Will I damage the transmission if I tow it two blocks, in neutral, with the rear wheels on the ground? I doubt I will exceed 20mph while towing.
Probably not. Go slow.
11-07-2008, 05:27 AM #3
75 miles at up to 30mph is the limit for flat towing an automatic. So spoketh my owners manual.
w108om617
11-14-2008, 01:33 PM #4
hello be safe if you move a car automatic gear box whithout any engine working
be safe remove the rubber part between transmission and rear differential to be ok on the road
w108om617
