STD Tuning Engine Whats this in my M pump?
02-04-2011, 10:27 PM #1
Poop. I've been getting ready for a few months to swap the pumps out tomorrow. Looks like I will simply be adjusting the timing for now if it needs it. What do you guys think these are? I was getting ready to "touch" my pump and I spied one of these puppies on top of the banana looking thing in the governor. I found 2 more in there. Everything seems to function ok on the pump. I was able to turn it without issue. Going to see if the seller will ship me another one.
This is my pinky for comparison.
Also the washer behind 2k in this image was loose.
[Image: attachment.php?aid=893]
Check out the loose pin right above 2k :
[Image: attachment.php?aid=4087]
This post was last modified: 02-04-2011, 10:44 PM by winmutt.
E300TSC
Turbo-Supercharged
321
02-05-2011, 06:49 AM #2
They look like the wheels that ride on the cam... Maybe? Put a mic on them and see if they're slightly different in diameter. Are they bearings?
E300TSC
02-05-2011, 06:57 AM #3
2K will only have tension when the engine is running.
02-05-2011, 08:31 AM #4
(02-05-2011, 06:49 AM)E300TSC They look like the wheels that ride on the cam... Maybe? Put a mic on them and see if they're slightly different in diameter. Are they bearings?
They do seem to be slightly different in size, I could see that with my eye.
dude99
02-16-2011, 08:53 PM #5
did you ever figure this out? You had me curious..
dude99
02-16-2011, 11:05 PM #6
Waiting for replacement.
