7,5 mm Element design for high performance engine
GTG At dieselmeken workshop today 20121110
http://www.facebook.com/dieselmeken#!/me...341&type=1
Development goes on, this is phase 2, 7,5mm performance maxed out
OBS Element on cyl 5 was changed, bad quality.
One glad dieseltech.
One 7,5mm testpump, this one goes up in dyno soon. Result will be shown.
(11-10-2012, 01:58 PM)winmutt I predict the engine cant take it!
(11-10-2012, 03:36 PM)mantahead hi,
is that pump running on steroids?
A little testdrive before I changed to better pump This is with 225 tyres...
(11-15-2012, 09:05 AM)Ksteen2 when are you giong to post a new film with new pump?
I got pump from dieselmeken maybe in february but now I testid it. I have master power R6164. I went to dyno and got only 194kw from wheels. max boost was already at 3500grm 2,5bar. to 3500grm there is lot of black smoke and then the boost stays to 4500 and then go lower. and then there is not much black smoke. It seems like it gets too much diesel with low grm and too few diesel in high grm. With my wastegate I must get more than 3,0 bars. but there is not enough gases. It seems like settings in pump are all wrong. EGT is max 550.
Any ideas?
(11-15-2012, 10:44 AM)m2rkz I got pump from dieselmeken maybe in february but now I testid it. I have master power R6164. I went to dyno and got only 194kw from wheels. max boost was already at 3500grm 2,5bar. to 3500grm there is lot of black smoke and then the boost stays to 4500 and then go lower. and then there is not much black smoke. It seems like it gets too much diesel with low grm and too few diesel in high grm. With my wastegate I must get more than 3,0 bars. but there is not enough gases. It seems like settings in pump are all wrong. EGT is max 550.
Any ideas?
Any ideas?
(11-15-2012, 11:02 AM)EDH_Performance(11-15-2012, 10:44 AM)m2rkz I got pump from dieselmeken maybe in february but now I testid it. I have master power R6164. I went to dyno and got only 194kw from wheels. max boost was already at 3500grm 2,5bar. to 3500grm there is lot of black smoke and then the boost stays to 4500 and then go lower. and then there is not much black smoke. It seems like it gets too much diesel with low grm and too few diesel in high grm. With my wastegate I must get more than 3,0 bars. but there is not enough gases. It seems like settings in pump are all wrong. EGT is max 550.
Any ideas?
there is no such thing as "the motor gets to much fuel", you simply need more air![]()
And this sounds like a fuelfeed problem! Have you changed the fuel lines and mounted big feed pump?
Any ideas?
Are you running stock feed pump? (The one that sits on the pump)
(11-15-2012, 11:17 AM)m2rkz If dieselmeken didn't do with this anythind then yes. Where I can get better feed pump?
Any ideas?
Any ideas?
(11-15-2012, 11:22 AM)EDH_Performance(11-15-2012, 11:17 AM)m2rkz If dieselmeken didn't do with this anythind then yes. Where I can get better feed pump?
I am very impressed that the stock fuelfeedpump made 194kw!!!!!!!!!!!!!!
You need big feedpump and atleast 10mm fuel lines ALL the way into the pump! Remove the stock fuel heater, and run the lines directly from feedpump to dieselpump...Maybe you need to uppgrade banjobolt on dieselpump for enough flow! Rememeber a good highflow dieselfilter
Holley makes a good feedpump or you can use the bosch 044 pump!
(11-15-2012, 12:09 PM)m2rkz(11-15-2012, 11:22 AM)EDH_Performance(11-15-2012, 11:17 AM)m2rkz If dieselmeken didn't do with this anythind then yes. Where I can get better feed pump?
Do you have any pictures of installing bigger feed pump?
(11-15-2012, 11:24 AM)erling66(11-15-2012, 10:44 AM)m2rkz I got pump from dieselmeken maybe in february but now I testid it. I have master power R6164. I went to dyno and got only 194kw from wheels. max boost was already at 3500grm 2,5bar. to 3500grm there is lot of black smoke and then the boost stays to 4500 and then go lower. and then there is not much black smoke. It seems like it gets too much diesel with low grm and too few diesel in high grm. With my wastegate I must get more than 3,0 bars. but there is not enough gases. It seems like settings in pump are all wrong. EGT is max 550.
Any ideas?
Take some photos of your engine setup, then it is easier to give you some advise.
Any ideas?
(11-15-2012, 12:21 PM)m2rkz in winter we gonna add eaton m62 with electronic clutch too to get 1 bar pressure already from 2000grm. Do you think is it good idea?
(11-15-2012, 12:21 PM)EDH_Performance impressive buildHow many cc is your pump giving?
m62 is with electronic clutch and then if more than 2000grm it turns off...
m90 and m112 is without clutch and it's not good.
m62 witch clutch is quite cheap too and it is ok for 1 bar in 2000grm.
(11-15-2012, 12:32 PM)m2rkz m62 is with electronic clutch and then if more than 2000grm it turns off...
one more question.
But original feed pump is installed to dieselpump. And between them is gasket. Then I must remove the origanal feedpump or I just install one more fuelpump under the car?
I don't know. I order it in February. I think I will send the pump back and then dieselmeken test it again.
one more question.
(11-15-2012, 02:29 PM)Savitas(11-15-2012, 12:32 PM)m2rkz m62 is with electronic clutch and then if more than 2000grm it turns off...
one more question.
What about IP timing? Have you tried to change it a few degrees?
one more question.
(11-15-2012, 12:21 PM)EDH_Performance impressive buildIts à 140cc pump. Its good for 400+ hpHow many cc is your pump giving?
I have tried a 140cc pump form dieselmeken, with just stock feed pump! The car behaved just as you descibe it! Pulling fine at low rpm, but not at high Uppgrade feedpump and your problem is solved;p
(11-15-2012, 04:13 PM)EDH_Performance I have tried a 140cc pump form dieselmeken, with just stock feed pump! The car behaved just as you descibe it! Pulling fine at low rpm, but not at highUppgrade feedpump and your problem is solved;p
(11-16-2012, 04:17 AM)erling66 Hi m2rkz.
Nice engineBut I am not so sure about your intake manifold
; maybe there is some horsepower to gain from making a manifold similar to what Jeemu has?
(11-16-2012, 07:00 AM)m2rkz(11-16-2012, 04:17 AM)erling66 Hi m2rkz.
any pictures of that intake?
And why is original om603 diesel filter bad?
(11-15-2012, 04:59 PM)m2rkz7mm 140cc cant get same power than 8mm 140cc(11-15-2012, 04:28 PM)jeemu Max cc isint all about it
You think 140cc is good enough for exampe 550hp with this settings? If I will put better feed pump and 10mm hoses and better fuelfilter?
(11-16-2012, 01:45 PM)jeemu(11-15-2012, 04:59 PM)m2rkz7mm 140cc cant get same power than 8mm 140cc(11-15-2012, 04:28 PM)jeemu Max cc isint all about it
(11-16-2012, 02:34 PM)dieselmeken7,5mm 140cc cant get same power than 8mm 140cc(11-16-2012, 01:45 PM)jeemu(11-15-2012, 04:59 PM)m2rkz You think 140cc is good enough for exampe 550hp with this settings? If I will put better feed pump and 10mm hoses and better fuelfilter?7mm 140cc cant get same power than 8mm 140cc
Its 7,5mm 140cc.
Its 7,5mm 140cc.
(11-16-2012, 03:30 PM)jeemu(11-16-2012, 02:34 PM)dieselmeken7,5mm 140cc cant get same power than 8mm 140cc(11-16-2012, 01:45 PM)jeemu 7mm 140cc cant get same power than 8mm 140cc
Its 7,5mm 140cc.
Its 7,5mm 140cc.
Pump bench you can result you want.
Only that matters is how much and how fast, Dieselmerken just dont want to understand my guestion, asked many times case closed. myy opinioin is at ewerybody can do what they want.
(11-16-2012, 04:42 PM)jeemu Pump bench you can result you want.
Only that matters is how much and how fast, Dieselmerken just dont want to understand my guestion, asked many timescase closed. myy opinioin is at ewerybody can do what they want.
Hp is hp, but think about the driveability? 7.5mm in a dialy driver is ok, but very sensetive in the trottle! dont't wanna think about 8 or 8.5mm.... I am now speaking if you drive a Manual transmission, NOT automatic!!!
(11-17-2012, 07:17 AM)EDH_Performance Hp is hp, but think about the driveability? 7.5mm in a dialy driver is ok, but very sensetive in the trottle! dont't wanna think about 8 or 8.5mm.... I am now speaking if you drive a Manual transmission, NOT automatic!!!
I would go for 180cc 7,5mm with outside alda! I have driven MANY long trips with my car, no problem at all! You could go 8mm, but the price is high! Gørans pumps is good quality!! I have personally been in his workshop and he showd us every step under the build...try to get the other pumpbuilders to do that
Any ideas?
Any ideas?
605 with 550hp, Mynä 8mm, 10,5inch wheels with 255 tires
My woman go daily store shoping
(11-17-2012, 05:12 PM)jeemu 605 with 550hp, Mynä 8mm, 10,5inch wheels with 255 tires
(11-17-2012, 04:18 PM)Siekkinen(11-15-2012, 10:44 AM)m2rkz I got pump from dieselmeken maybe in february but now I testid it. I have master power R6164. I went to dyno and got only 194kw from wheels. max boost was already at 3500grm 2,5bar. to 3500grm there is lot of black smoke and then the boost stays to 4500 and then go lower. and then there is not much black smoke. It seems like it gets too much diesel with low grm and too few diesel in high grm. With my wastegate I must get more than 3,0 bars. but there is not enough gases. It seems like settings in pump are all wrong. EGT is max 550.
Any ideas?
There is something wrong with it. I got same results from om603 with 80mm3, 1.5 bars (holset hx35) and of course a stock feedpump.
Any ideas?
(11-16-2012, 02:34 PM)dieselmeken That depends on The duration of The element. Do you know how many degrees it takes for The 8 to inject 140cc?
