supercharger?
supercharger?
There's much more info on turbos. I think the consensus is that the Holset line, 40 and higher is the way to go. But what about superchargers? Much less info.
I'll be starting my STD project by purchasing parts, but I don't have much reference for superchargers for the 606.692. Here are some ideas:
-Supercharger off the Crossfire or SLK32/C32?
-E55/S55/Sl55 supercharger
-GM supercharger off an Impala, Buick
-Eaton MP90--what model car did these come on?
Of course, the idea is to get one for $400 or less, and that seems possible with the SLK32 superchargers.
The m90 would have come off 99+ GM 3800 in Pontiac's, Buick's, and Chevy's. Pre 99's would be a smaller m62 supercharger. I have one of each just not shur what I'm gonna do with them. I've heard the m90 was on some thunderbird v6's with an intercooler. Oh but an mp90. Not shur if it was used on a production car.
Find a m90 supercharger from a ford thunderbird super coupe. Those style chargers are flipped around and use a top plate to feed the air into an intercooler. That makes it a bit easier when it comes down to fabrication as you wouldn't need to make an adapter to get the charged air out of it as you would with a s/c from a GM 3800.
There were 2 different setups from Ford; one was a 3.8 v6, and the other was a 5.0 v8. I would think there might be a difference between the 2 blowers, but not sure. Just so you know both were called "Supercoupe".
