who offers the 60 trim turbo rebuild?
i have my old garrett turbo as a core.... if i wanted to buy a 60 trim unit where would i find it? none of the rebuilders i've seen advertising mention this option. i could rebuild by myself but i understand that this change requires balancing.
Send the turbo to Performance Techniques in San Bernardino.
Call them, ask for James and that you have a Mercedes Turbo you want to upgrade to a 60 trim.
http://turbocharged.com/main.htm
I used a guy here in the states, in Waco, Texas. He has had some write ups in DieselPower magazine. Majestic turbo, ask for john.
JM
Any decent turbo shop should be able to figure it. That is, as long as they are not "rebuild to stock" only mechanics
nice, thanks guys.
(10-10-2013, 11:15 AM)DeliveryValve Send the turbo to Performance Techniques in San Bernardino.
(10-11-2013, 12:40 AM)mike-81-240d(10-10-2013, 11:15 AM)DeliveryValve Send the turbo to Performance Techniques in San Bernardino.
What was the price if you don't mind me asking? Do you think it could keep up with a 8mm meken pump? With the help of a intercooler and W/M injection that it.
(10-11-2013, 12:40 AM)mike-81-240dConsidering most people with 8mm pumps are running hx40's, I think that little Garrett would explode(10-10-2013, 11:15 AM)DeliveryValve Send the turbo to Performance Techniques in San Bernardino.
(10-12-2013, 09:24 AM)MFSuper90You can buy brand new turbo clones all day for cheap $. Like anything else, In turbo world, you get what you pay for... Sometimes you get lucky and steal one, I traded up for mine but out the door prices are usually about the same across the board.(10-11-2013, 12:40 AM)mike-81-240dConsidering most people with 8mm pumps are running hx40's, I think that little Garrett would explode(10-10-2013, 11:15 AM)DeliveryValve Send the turbo to Performance Techniques in San Bernardino.
$800? I have less than $400 wrapped up in my hx30 and That's after I rebuilt it
(10-12-2013, 12:05 PM)Austincarnut You can buy brand new turbo clones all day for cheap $. Like anything else, In turbo world, you get what you pay for... Sometimes you get lucky and steal one, I traded up for mine but out the door prices are usually about the same across the board.Mine is genuine, but it was used and needed rebuilt. I believe I got a pretty good deal
(10-11-2013, 12:40 AM)mike-81-240d ...
(10-12-2013, 05:11 PM)DeliveryValveThis correct it was 400$ something. The only think to add... Lol I don't think any Dieselmeken pump is mild. I do have a 6mm pump and even with 20psi I have max fuel turned wayyyy down. Egts still through the roof. Spooling is good. An alternative too is 60 trim super or something. The same shop can give you even more compressor wheel if needed. I probably should have done that not knowing how beastly even the 6mm pump is :-) I'm sure I'll upgrade someday not sure to what.(10-11-2013, 12:40 AM)mike-81-240d ...
Unless the price has changed, it should be about $400.00. I think for a 617 and a mild Meken Pump, it will work. Ask lgreeley83, he has a 60 trim and a mild Meken Pump that he is dialing in.
