OM616 crackling sound under load in low/mid RPMs
I'm not sure what to make of it, I originally thought maybe something was rattling around but I can't locate anything in the engine bay that would do it, and the conditions to reproduce it seem to be engine related.
To produce the noise:
-RPMs in the low-mid to mid range (no tach on the 240D, sorry)
-Under medium load - don't have to go WOT but do need to be giving it some pedal, on flat ground.
-Not speed related - happens under similar loads and RPMs in all gears
The noise itself:
-Sharp crackle, like whacking a piece of walnut against a steel block
-Random pattern - not directly related to RPM of the engine, like dropping water into a hot pan of lard
-Can't quite tell where it's coming from, other than engine bay, and can't really pinpoint as it only happens under load and not standing still in the same RPM range.
I recently did a valve adjustment and it has been driven at least a couple thousand miles between the adjustment and when the noise started. Oil and coolant levels are good with good fluid in both. Engine is running warmer than I'd like but not overheating, and the noise happens on everything from a cold start to fully warmed up.
Any ideas? Start replacing parts until it goes away?
If I nobody has ideas, my course of action will likely be, in this order, until the problem goes away:
-Do diesel purge
-Replace both fuel filters
-Inspect timing
-Inspect timing chain
-Check IP timing, correct if necessary
-Do another valve adjustment
-Inspect injectors and prechambers for visually evident damage, R&R prechambers if damaged
-New injector nozzles / rebuild injectors
id say its the chain.... it will probably live for a long time.. but still, its a sign
Oh cheeses... Do you have air bubbles in the fuel lines going to the filter? Have you had the injectors tested? Pump timing?
And last but not least; could you record the noise?
But my first suspicion would be air or worn injectors...
(05-16-2014, 05:50 AM)stan I'm not sure what to make of it, I originally thought maybe something was rattling around but I can't locate anything in the engine bay that would do it, and the conditions to reproduce it seem to be engine related.
The noise itself:
-Do diesel purge
-Inspect timing
can you record the noise for us to hear, it may be the fastest and cheapest way to go
The noise itself:
-Do diesel purge
-Inspect timing
here's a video of the noise. really prominent at about 17 secondsunknown engine noise: http://youtu.be/fZDMPRdEDms
(07-01-2014, 06:58 PM)stan here's a video of the noise. really prominent at about 17 secondsunknown engine noise: http://youtu.be/fZDMPRdEDms
its marked as private
(07-01-2014, 08:07 PM)stan fixed now
can you get it to happen at a standstill? powerbraking...have you tried a stethoscope at all to pinpoint it?
(07-01-2014, 09:29 PM)Austincarnut can you get it to happen at a standstill? powerbraking...have you tried a stethoscope at all to pinpoint it?
