STD Tuning Engine 606 diesel 3.0ltr info
gary andrews
4x4 builder
48
06-18-2014, 02:27 PM #1
hi i am a newbee .what I'm after is simple answers as new with diesels.what i want to do is transplant the 606 from 99 e class .would like it as simple as can be i.e. no electrics,want to fit larger turbo heading for a round 350-400hp with not much lag. what parts do i need i.e. turbo pump,and what do i need to do to the engine to achieve what i want .sorry if this has been done before but I'm a crap reader but i weld good cheers gary
c250 std at mo
gary andrews
c250 std at mo
06-19-2014, 09:46 AM #2
(06-18-2014, 02:27 PM)gary andrews hi i am a newbee .what I'm after is simple answers as new with diesels.what i want to do is transplant the 606 from 99 e class .would like it as simple as can be i.e. no electrics,want to fit larger turbo heading for a round 350-400hp with not much lag. what parts do i need i.e. turbo pump,and what do i need to do to the engine to achieve what i want .sorry if this has been done before but I'm a crap reader but i weld good cheers gary
you will want the injection pump off an om603 300d and probably a holset turbo hx40 and you will need to have the pump built and tuned for that power level.
gary andrews
4x4 builder
48
06-23-2014, 02:56 AM #3
cool so I've got my hx40 ,603 pump tuned ,what else do i need the do to the engine i.e. ignition and what power would that return cheers
c250 std at mo
gary andrews
c250 std at mo
cho
06-23-2014, 05:20 AM #4
(06-23-2014, 02:56 AM)gary andrews cool so I've got my hx40 ,603 pump tuned ,what else do i need the do to the engine i.e. ignition and what power would that return cheers
as you went from electric pump to mechanical you will have to fab
linkage,set a few gauges to monitor temps ...powah? ... 450+ SmileBig GrinTongue
depending of car transplanted you may have to fab engine/motor mounts..etc....
edit: search for dieselpumpuk's videos on youtube ....
This post was last modified: 06-23-2014, 05:24 AM by cho.
cho
gary andrews
4x4 builder
48
06-23-2014, 04:44 PM #5
sounds good how much hp with a hx35
c250 std at mo
gary andrews
c250 std at mo
cho
06-24-2014, 01:32 AM #6
(06-23-2014, 04:44 PM)gary andrews sounds good how much hp with a hx35
not sure but guys used om605 and hx35 and produced 380hp....fwiw
cho
06-25-2014, 07:15 AM #7
Get a HX35 cheap from ebay, but make sure it has an exhaust housing no bigger than 12cm2, this number is stamped in the exhaust flange entry to the scroll.
gary andrews
4x4 builder
48
06-26-2014, 05:13 PM #8
hario,was thinking the same did you do your pump on yours if so where as your only down the road from me cheers
c250 std at mo
gary andrews
c250 std at mo
