what are the symptoms of a bad ip?
I have a couple cars that are giving me fits at the moment, what would indicate that the ip is to blame?
IPs seldom fail. What kind of problems are you experiencing?
Without knowing the symptoms exactly could be anything from bad fuel to dirty junk in the ip to sticking delivery valves, or could be timing, stuff like that
One car has an idle issue, will start at wide open throttle and after a little warmup it can be run at any normal rpm, but wont idle, foot off throttle, car dies.
Second makes little to no power, I haven't been able to look at it much, but I did change fuel filter. I'd like to tear it appart and replace all fuel lines, I may try a different lift pump too. It seems better once it warms up, but still hardly makes any power.
I forget to ask... What year and models are these cars?
And did the problems start suddenly or was it a gradual and progressive type of thing?
The car that dies came as a non runner, I think glow plugs may be dead but so is my multimeter so I cant verify. 87 300sdl
The other is an 82 300sd that started as an intermitant problem uppon startup and gradually became worse.
The one that has little to no power probably has a clogged ALDA line.
Just had to clean the soot out of my buddies 300SD, it was the slowest thing id ever driven before we fixed the alda
the 2 symptoms I have witnessed were
worn DV's - you have to change these, no cleaning helps /significant shakes is the sympt./
messed elements (via upper nuts) - back to adjustment table /no able to start,uneven fuel,severe shakes/
