biodiesel friendly rubber
Hi,
I just finished replacing all fuel lines (including injector return and all vent lines) with viton lined Parker hose.
Though not necessary for WVO, I wanted to do this so I could run B100 when it's convenient to get. There's a regional station nearby my work that's known for making quality bio and it's taxed so FI can rest easy that I'm still paying for my share of pavement
I'm curious to know if other seals are prone to failure when running B100. do the MW pumps hold up well? Gas cap seal?
-Thanks, Christian
I've run B100 for a couple years now in my 82 CD after switching to Viton fuel lines. The gas cap seal deteriorated though. I replaced it with a BD compatible one from MercedesSource (yes I shopped that site before I found other more reasonably priced outfits). No problems with the IP.
(02-25-2010, 10:49 PM)Section106 I've run B100 for a couple years now in my 82 CD after switching to Viton fuel lines. The gas cap seal deteriorated though. I replaced it with a BD compatible one from MercedesSource (yes I shopped that site before I found other more reasonably priced outfits). No problems with the IP.
Hydrogenated, N Buna rubber is also resistant to BioDiesel and blends...
Not all types of Viton are resistant to BioDiesel allegedly....
(03-14-2010, 03:05 PM)Alastair E Hydrogenated, N Buna rubber is also resistant to BioDiesel and blends...
I've been running B100 for about 1000 miles now- everything seems to be holding up fine. I still have a couple regular rubber couplings from aux saddle tanks to the main tank that are holding up fine (The walls are about 1/4" thick)
also recently found out Samco has released a new line of mandrel shaped tubing that's rated for continuous B100 use but the US reps don't seem to know much about it yet. (it's not their profuel line)
