STD Tuning Engine 606 swap into GD300
606 swap into GD300
606 swap into GD300
tinker
03-04-2010, 01:19 PM #1
Hi all
Big project here and lots of questions,
I am hoping to avoid some pitfalls by asking here first.
I am installing a 606T from a1999 E300 into a1983 GD300 (Gwagon)
The truck started with 617 and now has a dead 603 (1987) in it.
The plan is to swap the mechanical IP from the 603 onto the 606 and hopefully run the thing without the EDS.
List of issues:
1. The throttle linkage hits the 606's oil filter housing. I have seen the 603's filter swapped over (thanks Flash) and it fits with a little grinding of the intake manifold. Is this the best way to go? Is there a linkage from another app. that will work? We don't need cruise control?
2. I will be closing off the EGR and plan on using the 606's turbo with a simple mechanical boost control. Any recommendations ?
3. The AC compressor from the E300 hits the steering box. With the bracket and compressor from the 603 it fits in but the bracket has an idler pulley and I am not sure what length theserpentine belt will end up and if I can find one.
4. I will use thermo switches and relays to control the cooling fans, Is there anything
else that eliminating the EDS will leave inoperable? I hope to have all the original gauges working.
5. I am not sure about the tack wiring, The engine in there now has a pickup on the pulley with a 3 pin connector, the 606 uses a pickup on the flywheel that has a coaxial two wire plug. Any thoughts here?
6.I think I will lose the open throttle cut out for the AC but this shouldn't be a problem.
7. What is a good location for the EGT sender in the 606's exhaust manifold? Is there a probe that people recommend?
Any thoughts and recommendations greatly appreciated.
Thanks
Danny
tinker
Hi all
List of issues:
Thanks
Danny
Syncro_G
0-60 in 29 sec
280
03-04-2010, 06:55 PM #2
Hi Danny,
Good questions! I've been talking with Jeff and Seth about it -- I'm close by and curious - I'm hoping to stop by to take a look at the progress.
Have you tried posting this on the P3 gwagen forum? There's a handful of guys who've done this swap from the 603 to 606 in the 460 Gwagen who might have good answers to the questions on parts fitment (#1, #3).
-Christian
oops, just saw you did post on p3.
This post was last modified: 03-04-2010, 11:32 PM by Syncro_G.
'84 G-Wagen turbodiesel
'75 240D 4-Speed
Syncro_G
Hi Danny,
-Christian
'75 240D 4-Speed
tinker
03-05-2010, 01:56 PM #3
Hi Christian
Yes I did post over On P3 getting a little discussion going.
I have had the engine in to see fitment, it is back on the stand now for modifications.
You are most welcome to come by. Call first
Danny
tinker
Hi Christian
Danny
