STD Tuning Engine I did it 95 Turbo 606
  • 1 Vote(s) - 4 Average
Pages (2): Previous 1 2
Bangaway
606 Turbo > Porsche Turbo
129
05-05-2013, 09:47 PM #51
Great work! Are you running a straight pipe or what? Can't wait for the vids.
Bangaway
95e300dez
95E300td
89
05-18-2013, 11:03 PM #52
So have been driving the car quite a bit know couple of issues to sort out.
First is that I can't get the linkage to give me the extra travel required for full throttle.
Second I have the car idling perfect when the ELR is not connectedat 6-700 rpm. When I connect the ELR the idle jumps to 900 and when I put it in gear it surges at 6-700 rpm not hunting but like the ELR is over reacting. I was wondering on a 95 if the is something I can adjust to prevent this.
95e300dez
Bangaway
129
05-28-2013, 09:44 PM #53
Do you have any updates--like vids of your car moving with the new pump?
Bangaway
95e300dez
95E300td
89
05-28-2013, 10:36 PM #54
Yeah I have a 3 inch exhaust but still working out the bugs my elr is disconnected and the car runs smooth just a lower idle which I prefer. No videos yet need to get a friend to come for a ride and video a good run. The trans is still my week link need to take it easy or she won't last long.
(05-28-2013, 09:44 PM)Bangaway Do you have any updates--like vids of your car moving with the new pump?
95e300dez
stripy
06-27-2013, 10:09 AM #55
clean setup!!
can you put out some more details on the oil return line?
im doing this myself and dont know where to put it on the block!
stripy
clean setup!!
Bangaway
129
06-27-2013, 07:28 PM #56
Yeah I'd like to see the oil lines too.
Bangaway
95e300dez
95E300td
89
06-27-2013, 11:53 PM #57
I will get some pictures when I get home on vacation. I will also post a video then it won't be a full throttle pull want to save the trans.
95e300dez
95e300dez
95E300td
89
07-15-2013, 04:31 PM #58
Well I have been enjoying the upgraded pump but just a little to much. I am now getting some good blow by. If I pull the dipstick when it is running oil will come up the tube and spill out. It still runs like a raped ape but I get whit smoke at stop lights and long stops in traffic looks like it is time for new rings. I tried marvel mystery oil to remedy maybe a stuck ring but no luck. I think I am out of options except to pull the motor and do new ring unless someone has any suggestion.
95e300dez
97e300
(its a 98 now)
109
08-04-2013, 11:55 PM #59
Hows your car doing, man?
97e300
95e300dez
95E300td
89
08-19-2013, 11:21 PM #60
So I pulled the motor and trans last week. I have tore the motor down and all looks real nice even the bearings. I think the rings where just not seated good enough for 25lbs of boost and had to many miles. I am going to re-ring and new gaskets. I am also trying to find some aftermarket rods to support more power. I have sourced a good 722.6 so now will be looking for a e420 speedo and a shifter from a 129. I have a k29 turbo sitting in the garage and was thinking of a compound setup with the hx35 with a quick spool valve and the K29 switzer turbo for some real good numbers and less black smoke. I could do the valve and try to get 10lbs of boost by 2500 rpm and 30 by 4500 with the K29. The K29 has a split scroll and would do good with a nice quick spool valve on it also set for 30lbs.
95e300dez
97e300
(its a 98 now)
109
08-20-2013, 12:38 AM #61
Please post pics of progress as you do so. I too am planning on turboing my 912. Glad to hear your engine didn't go thermonuclear. If you find some aftermarket rods, perhaps they'd be willing to give a little package deal for 12 (I'd love to upgrade my rods as well). If not, post/pm how much they're charging. I was thinking to compensate for lack of oil channels in pistons, it would be a good idea to have them coated. How much power do you reckon your engine is pushing?
97e300
95e300dez
95E300td
89
01-24-2014, 07:11 PM #62
Ok so for a update I found a 98 motor for piston and rods. I searched for rods everyone wanted close to 1500 for a set of custom rods. I put new rod bearings and Deves rings in the motor. I also replaced the valve seals and lapped the valves.
I am going with the compound setup I will use one side of my HX35 12cm housing. The low pressuare turbo will be a k29 with a 20cm housing it is a 64mm compressor and a 72 mm turbine. I will vent the exhaust with a 60 mm wastegate to the second side if the K29. Looking to get less smoke down low and a little more top end.
95e300dez
95e300dez
95E300td
89
01-26-2014, 11:48 PM #63
[img]<a href="http://s108.photobucket.com/user/2benchanted/media/IMAG0074.jpg.html" target="_blank"><img src="http://i108.photobucket.com/albums/n1/2benchanted/IMAG0074.jpg" border="0" alt=" photo IMAG0074.jpg"/></a>[/img]
Doing some fitting and new log manifold building.
95e300dez
01-27-2014, 05:28 PM #64
(01-26-2014, 11:48 PM)95e300dez [Image: IMAG0075.jpg]
[Image: IMAG0074.jpg]
Looks fancy Smile
Looks fancy Smile
10-21-2015, 12:02 PM #65
(01-26-2014, 11:48 PM)95e300dez [img]<a href="http://s108.photobucket.com/user/2benchanted/media/IMAG0074.jpg.html" target="_blank"><img src="http://i108.photobucket.com/albums/n1/2benchanted/IMAG0074.jpg" border="0" alt=" photo IMAG0074.jpg"/></a>[/img]
Hello man any updates on this? Or did I miss somthing..
95e300dez
95E300td
89
11-03-2015, 12:30 PM #66
So I got it together with better valve springs and compound turbos it spun the number 1 rod bearing that I had just replaced. I have a line on another crank so I will put it back together and try again. The car was real fast with the setup I had but now I have a he221 for my small turbo should be real good out of the hole.
95e300dez
11-05-2015, 08:37 AM #67
(11-03-2015, 12:30 PM)95e300dez So I got it together with better valve springs and compound turbos it spun the number 1 rod bearing that I had just replaced. I have a line on another crank so I will put it back together and try again. The car was real fast with the setup I had but now I have a he221 for my small turbo should be real good out of the hole.
Out the hole LOL!
he221 is 6cm housing? Same as stock turbo?
share some pictures would you man! Also you have pm
Edit: They come in 5/6/7/8.5cm
This post was last modified: 11-05-2015, 08:40 AM by Hario'.
Out the hole LOL!
Mh95e300d
12-24-2018, 02:38 PM #68
Hello. Any update on the setup?
I have 94 w124 e300d (n/a motor) and planning around 300hp (safe limit for this engine with least possible black smoke). Looking forward to your suggestions.
Thanks
Mh95e300d
Thanks
atypicalguy
12-27-2018, 10:25 PM #69
Yeah! The world wants to know whether the rod bearing ever got unspun and how the compound he221 and k29 went! The hx35 was far too large for a good high pressure turbo, and the 221 should have been perfect. The 64mm compressor on the k29 is also a bit too small, actually, for good mass flow at PR of 2-3. So you might have painted yourself into a high boost corner there, as it needs to boost way higher to achieve good mass flow at higher rpm (assuming you still want a smokeless setup). hx52 is probably perfect - I think it is around 70mm compressor inlet. 60mm wastegate sounds perfect.
atypicalguy
 7 Guest(s)
 7 Guest(s)
