STD Tuning Drivetrain Transmission swap on a M117
Saterbonden
05-02-2010, 07:29 AM #1
Hi. I wonder if anyone know if it is possible to bolt on a manual transmission on a M117 engine from a w126 who used to have a auto-transmission.
I've heard that the flywheel and clutch from a 300E w124 might fit so you can put on a manual transmission but I have no Idea it's just something I heard.
Saterbonden
MB TECH
05-02-2010, 09:22 AM #2
if I am not mistaken the 107 chassis came with a 117 with a manual option, the clutch and flywheel part numbers can be looked up the parts catalog. I will try to load it here at home if not I will look it up during the week.
1979 450SEL 6.9 - stock
1960 220SE
2005 S55 AMG - stock
2006 SLK55 AMG - stock
MB TECH
1960 220SE
Saterbonden
05-02-2010, 11:05 AM #3
Ok sounds good and I forgot to say it's a 500sl engine don't know from what year it is tho.
Saterbonden
Kozuka
I'm_Badass
334
05-02-2010, 01:08 PM #4
You must find a V8 gear box, they have a different bell housing from inline models. Or take a look at the franken 5-speed thread and cut up an auto.
Kozuka
Saterbonden
05-02-2010, 07:01 PM #5
Oh that was a nice thread. So if i put this as basic as I can, if I manage to find a flywheel that fits on the m117 engine I can "simply" get a transmission and a clutch that would fit for that and cut off the bell housing from the auto-transmission and weld it on the manual transmission, it might work?
Well that's what I tought would be most simple for me whit my tiny knowledge after reading that thread. hehe Tongue
Saterbonden
Kozuka
I'm_Badass
334
05-02-2010, 10:28 PM #6
(05-02-2010, 07:01 PM)Saterbonden Oh that was a nice thread. So if i put this as basic as I can, if I manage to find a flywheel that fits on the m117 engine I can "simply" get a transmission and a clutch that would fit for that and cut off the bell housing from the auto-transmission and weld it on the manual transmission, it might work?
That or dig deep for the $1800+ to find a V8 manual transmission. Even in Europe.
Kozuka
Syncro_G
0-60 in 29 sec
280
05-06-2010, 09:31 AM #7
My iron 5-speed has a mix of casting numbers starting with either 115 or 117.
The oral history is that it was originally mated to a V8 in an SEC.
The bell housing is identical to the M110 and OM617 bell housings
so if the history for this transmission is true, I would think the V8 has the same bolt pattern.
This post was last modified: 05-06-2010, 09:34 AM by Syncro_G.
'84 G-Wagen turbodiesel
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
