STD Tuning Engine New 60X finnish ST
New 60X finnish ST
New 60X finnish ST
MTUPower
287
03-26-2008, 08:43 PM #1
[Image: _small.jpg]
[Image: _small.jpg]
Parallel identical turbos fed by three cylinders each. One external wastegate operating both turbos. Oil sump and hence no oil pan. Instead of oil pan an A/W intercooler. Turbos in series with supercharger and supercharger operates all the time. Combined max pressure about 5bar. Additional A/W cooler in the intake manifold.
Engine will also be mounted really back (~40cm) in the chassis and I'd bet that's why valve cover has been made lower
MTUPower
[Image: _small.jpg]
[Image: _small.jpg]
GREASY_BEAST
03-26-2008, 10:24 PM #2
that is one crazy engine to be sure! Someone will certainly be having some fun.
GREASY_BEAST
03-26-2008, 11:10 PM #3
holy schnikies. 5bar, what are they using to keep the valves tight and the head on?
03-27-2008, 09:10 AM #4
I just noticed those turbos dont look very identical?
MTUPower
287
03-27-2008, 09:44 PM #5
winmutt I just noticed those turbos dont look very identical?
MTUPower
03-28-2008, 08:07 AM #6
Thats because the turbine inlets are positioned differently so you are seeing the smaller part of the lower turbine snail.
Don't worry, I thought the same thing for a bit. Wink
HoleshotHolset
03-28-2008, 09:25 AM #7
Dang - there must be something in the water in Finland.
I've seen some very interesting work come out of that country.
Beers,
Matt - part Finn and proud of it. Smile
'07 W211 OM642
HoleshotHolset
Beers,
'07 W211 OM642
Telecommbrkr
Soon to be mod'ing......
97
03-29-2008, 09:05 PM #8
It looks to me that this would be a full on drag race engine only, you'd have to put an IC for any other use. Anyone know what IP they're using? I can't tell where the lines go after they dissapear down beside the intake.
Mods are in the works...
Telecommbrkr
bgkast
VGT-Intercooled
325
03-29-2008, 11:27 PM #9
Telecommbrkr It looks to me that this would be a full on drag race engine only, you'd have to put an IC for any other use.
There looks to be an air/water intercooler incorperated into the intake manifold.
bgkast
03-30-2008, 11:00 AM #10
Sure does. In and out lines and an o2 sensor. Good eye! I thought it was just the intake manifold itself.
Telecommbrkr
97
03-30-2008, 08:30 PM #11
AAhh yes, now I notice the two REALLY BIG BLUE fittings on either end of the intake.... Wink
Telecommbrkr
HoleshotHolset
03-31-2008, 02:31 PM #12
They might be using water injection. A great many purpose-built diesel drag racers and pullers run without an IC of any kind and just spray a ton of water down the intake under boost.
Due to the expansion properties of water turning to steam, this alone is good for 30-50hp on a Cummins 5.9L B-series engine. To make the mix a little 'hot' - some use various concentrations of methanol or just dump windshield washer fluid in the reservoir. This is good for 60-80hp. You have to be careful with the methanol, though - its flash point is very low - so it preignites well before the diesel fire gets going...effectively advancing the ignition timing quite a bit. This effective timing advance along with the increased cylinder pressures can and will degrade the head gasket if it isn't properly taken care of. 12mm+ head studs and an o-ring'd cylinder head will take care of that.
To take it one step further - the engine can be prepared for fire rings. To do this, a head gasket that has had its OEM fire rings removed with water jet or laser cut is necessary. Grooves are cut into the head/block and then a stainless steel ring is set in place.
Beers,
Matt
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
03-31-2008, 06:47 PM #13
HoleshotHolset They might be using water injection. A great many purpose-built diesel drag racers and pullers run without an IC of any kind and just spray a ton of water down the intake under boost.
In the most recent edition of Diesel Power, one of the article trucks said they use around 1 gallon in a single 1/4mile race.
HoleshotHolset
04-01-2008, 09:59 AM #14
Wow - one gallon sounds like a lot. I know people that go through a quart or two in a 1/4-mile pass or a single sled pull. My Dad's truck will empty the reservoir (2-quart) in two or three good pulls on the highway...he's running the two biggest nozzles that come with the kit and it's still not quenching. (link)
Beers,
Matt
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
04-01-2008, 02:12 PM #15
Yes it is a lot, but this guy is running 100psi compounds and revving his 5.9 to 4000rpm.
HoleshotHolset
04-01-2008, 03:28 PM #16
4000rpm is pretty good for a common-rail, or VP44 ISB, but that's old hat for a 12-valve B-series. Folks commonly let the clutch out at 6500rpm with those during competitive events. :twisted:
Beers,
Matt
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
SteveM
04-02-2008, 01:53 PM #17
Incredible stuff those Finns are capable of. I am particularly interested in the flywheel / clutch setup they are using. Does anyone know what they are using in terms of flywheels and clutch/pressure plate?
SteveM
SteveM
SteveM
04-02-2008, 02:00 PM #18
AFAIK they have been using autos. There are after market stage 2 clutches avail for 123/124/201 etc.
SteveM
04-02-2008, 02:52 PM #19
Looking at the first picture in this thread, it looks to me like they are set up with some kind of aftermarket clutch setup, unless that is something they are just using to attach to a dyno.
The reason I'm asking is that some day I will be in need of a flywheel which is NOT made of cast iron. I'm hoping to find someone who makes either steel or aluminum flywheels.
Thanks for the tips on the clutches and pressure plates. I have seen the "Spec" units. They look like they would get the job done.
SteveM.
This post was last modified: 02-06-2009, 10:00 AM by winmutt.
SteveM
SteveM.
04-03-2008, 06:25 AM #20
SteveM The reason I'm asking is that some day I will be in need of a flywheel which is NOT made of cast iron. I'm hoping to find someone who makes either steel or aluminum flywheels.
Any race shop should be able to make a flywheel to whatever specs you want. All it is is a chunk of metal machined down and holes drilled in it. Even a well equipped machine shop should have no problem making one. It probably wouldn't cost more than $300-400 to make a one off to your specs and get a starter ring pressed on.
06-16-2008, 01:41 PM #21
Videos <!-- l --><a class="postlink-local" href="http://www.superturbodiesel.com/std/viewtopic.php?f=16&t=107">viewtopic.php?f=16&t=107</a><!-- l -->
06-17-2008, 09:05 AM #22
Holy bejesus. Wow.
Holy bejesus. Wow.
bgkast
VGT-Intercooled
325
06-17-2008, 08:13 PM #23
What's with the supercharger sound? It changes its whine with no change in engine RPMs in the first video.
bgkast
12-10-2008, 05:23 PM #24
Added the pictures again as they changed their old format.[attachment=331][attachment=332]
[Image: full]
[Image: full]
This post was last modified: 01-04-2009, 01:15 AM by winmutt.
[Image: full]
[Image: full]
oel_brenner
12-11-2008, 09:54 PM #25
bgkast What's with the supercharger sound? It changes its whine with no change in engine RPMs in the first video.
I was trying to figure that out also.. maybe it is changing RPM but doing so very fast, but the rotational mass / flywheel would have to be almost nothing.
And is that sound the turbos ? or what ?
OK so I just watched it several more times.. and I think he IS poking the "throttle" quickly
and it is changing RPM but it is doing so VERY quickly.... that supercharger is wound tight..
cars
1991 W126 350SDL turbodiesel
1987 W124 E300D turbodiesel
1987 W126 300SDL turbodiesel
1984 W107 SL300D turbodiesel
1974 W115 /8 300D diesel
trucks
boats
oel_brenner
cars
trucks
boats
12-12-2008, 05:14 AM #26
Look at the clutch in the second picture. Its so tiny, they must be pushing past the 7000rpm+ range the drag engines have been doing. I'd love to see what transmission/transaxle they will use.
GREASY_BEAST
12-12-2008, 07:17 PM #27
That is a work of beauty.. it sounds good too.
GREASY_BEAST
