STD Other Projects Captain's '82 300D Purists Must Die Prius Repellent
  • 6 Vote(s) - 3.83 Average
Pages (10): Previous 1 5 6 7 8 9 10 Next
01-07-2013, 02:57 AM #301
Cant get the coolant temp gauge to work. It's making me Angry !
01-07-2013, 03:30 PM #302
Mine bounces around so I never know temp, I know how you feel
01-07-2013, 03:35 PM #303
Use to work perfect in both cars. I don't understand... its a simple circuit
01-07-2013, 03:43 PM #304
Bad gauge? Faulty connection? Or bad sender? Only things I can think of.[/align]
01-07-2013, 04:32 PM #305
90% of the time it's a ground. The gauge grounds through the plug in the head right? then to the block, then ground strap, then chassis. Hot side ot harness, fuse box, gauge cluster. cluster grounds to dash support to chassis.
Raarasutra
01-07-2013, 07:41 PM #306
I just read through all 7 pages, and I am very inspired!
I wish I could spend more time working on my 300D... I will be rereading all of this once mine is roadworthy so I can let the real fun begin Big Grin
Raarasutra
01-15-2013, 01:56 AM #307
(01-07-2013, 03:43 PM)DeliveryValve Bad gauge? Faulty connection? Or bad sender? Only things I can think of.[/align]
See Below
(01-07-2013, 04:32 PM)Simpler=Better 90% of the time it's a ground. The gauge grounds through the plug in the head right? then to the block, then ground strap, then chassis. Hot side ot harness, fuse box, gauge cluster. cluster grounds to dash support to chassis.
I think you are right. Driving it around in the dirt, over bumps the cluster was doing all kinda of wacky things. Lights were turning on and off... I duuno where to look though. Guess I'll check the cluster ground and thewn the hot side. The engine is grounded to the chassis in the factory location and also back to the battery in the trunk with 1/0 gauge welding wire, all soldered and crimped connections. Thanks for the ideas guys!
(01-07-2013, 07:41 PM)Raarasutra I just read through all 7 pages, and I am very inspired!
Thanks for the kind words. This build has taken way to long but it's totally worth it!
Got her on the road tonight!!!!
I really only got the bare minimum done to drive it, so no water plumbing yet for intercooler, no fans on the radiator (using A/C aux fan) and haven't played with the pump yet...
Surprisingly it runs strong and isn't really slow at all. She gets up and goes. Don't know what boost is, or oil pressure, or coolant temp, or mph.... lol, I only have RPM at the moment! Exclamation
Feel free to follow me on Instagram for the latest pics. Captain___America (That's 3 underscores)
On first test, the trans stalled up to 2k rpm, but again I dunno what kind of boost I'm building there. Driving around it feels like the torque converter locks at 2500rpm Smile
This post was last modified: 01-15-2013, 02:10 AM by Captain America.
See Below
01-15-2013, 08:36 AM #308
WOOHOO!!!
As for grounds, my trunk tail light ground rusted out and made everything weird when the signals couldn't complete their normal route-don't forget to check that one too.
WOOHOO!!!
01-15-2013, 01:24 PM #309
Cool. Thanks! On the bright side, the reverse lights don't blow the fuse anymore, lol dunno what changed there haha. Seems like everything I own is riddled with electrical issues haha
01-21-2013, 12:31 AM #310
Car was driving pretty good. Then an oil line blew off. Motor seems ok, turbo needs a rebuild.... Off to performance Techniques..
[Image: b5d8e1ac627411e29c2822000a1fbe4c_7.jpg]
[Image: 5c90502a636511e2871d22000a1f92db_7.jpg]
01-21-2013, 08:03 AM #311
Well that sucks. Time for a flared line I guess. Mine never blew off (similar setup)
01-21-2013, 12:15 PM #312
I should have re torqued the clamps after a few heat cycles, all of them were only snug... a flare would help like the stock lines have the little bubble at the end. Had to cut 2 lines down to size so lost the flare at the end.
01-23-2013, 12:49 AM #313
Got the turbo to Performance Techniques today. Wont know till its apart but as long as the turbine shaft isnt damaged, James said hes got extra compressor wheels and center housings if needed that he'd give me for no charge. Pretty awesome if you ask me! Going to inquire about a ball bearing upgrade though.
01-24-2013, 02:06 AM #314
Ouch, Lol. Looks like I've got some Dirty Diesel Algae Problems. .. Don't think it should be black, eh?
[Image: 49f4367c65d411e28ddc22000a9f15db_7.jpg]
Pulling the tanks to clean them... 27 gal aux fuel tank Big Grin
[Image: 2949809c65db11e28ac522000a9f141e_7.jpg]
01-24-2013, 04:10 PM #315
That's an awesome aux tank. Do you just drive for a month between fillups?
If you're going to upgrade your turbo, you might as well go VNT....
01-24-2013, 08:56 PM #316
Never tested it because the fuel gauge was untrustworthy ...
IDK, vnt seems like a pain in the ass. This Turbo spools by 2k and will support more power than I could ever hope to make with a 617 ... (upwards of 350)
02-16-2013, 03:50 PM #317
Hmmm, so whats happened? A LOT!
Got the turbo back, 325$ later, lol. Everything is new...
Then I looked for a new fuel tank sending unit. @ 200$, I decided to just take it apart and clean it... Here it is soaking in mineral spirits. Worked good to clean it off
Bought a turbo blanket, first thing that happened when snugging it up was one of the rivets broke. So had to re-rivet the hook on..
THEN I went to the King of the Hammers race Big Grin
Oh man... there are trucks there worth over $250k and the Mercedes got the most attention lol. I got thumbs up, fuck yeahs, and right ons everywhere I went. ppl were amazed.
First I aired down to 20 PSI and it felt like I was driving a boat haha
[Image: th_2013-02-09_0034271.png]
Made it up a hill that a lot of 4x4s have trouble with...
[Image: th_2013-02-09_1222051.png]
[Image: th_2013-02-09_0033101.png]
Spectators...
[Image: th_2013-02-09_0035301.png]
I was out playin in the sand dunes and a bunch of people stopped me because they wanted pictures and video haha
[Image: th_2013-02-09_1220571.png]
[Image: th_2013-02-09_1220251.png]
My buddy loves my car. He bought a '82 300D non turbo (ouch haha)
She cleans up kinda nice! Heart
Couple nights ago I decided to time the IP..
It was at 22°?
Now she is 27ish Runs fuggin awesome!
Still need to play with IP fuel and plumb the intercooler... Pretty happy now thoughExclamation Big Grin
Heres a IP drip timing video
Mercedes 617 Lope
This post was last modified: 02-16-2013, 04:27 PM by Captain America.
Spectators...
It was at 22°?
Mercedes 617 Lope
02-26-2013, 02:25 AM #318
Burnouts on command!
[Image: th_IMAG0111.jpg]
Posing with our Ford Raptor at work
[Image: th_IMAG0138.jpg]
[Image: th_IMAG0139.jpg]
Lucas Oil Off Road Regional Series race
[Image: th_IMAG0148.jpg]
On my third radiator so I'm going aluminum. Fits perfect. Converting it form an open radiator to closed.
[Image: th_IMAG0151.jpg]
[Image: th_IMAG0156.jpg]
[Image: th_IMAG0158.jpg]
[Image: th_IMAG0159.jpg]
Cut the radiator cap neck off
[Image: th_IMAG0166.jpg]
Welded a cap that will have a vent port in it
[Image: th_IMAG0170.jpg]
02-26-2013, 07:50 PM #319
So is that vent port going to the reservoir or..? I'm a little confused lol, I haven't heard of open vs. closed before. Also, where did you get that thing and how difficult was it to make fit?
03-08-2013, 03:29 AM #320
(02-26-2013, 07:50 PM)sassparilla_kid So is that vent port going to the reservoir or..? I'm a little confused lol, I haven't heard of open vs. closed before. Also, where did you get that thing and how difficult was it to make fit?
Yes the top of the radiator will be vented to the stock expansion tank, in the same way the stock radiator is.
Open system: Has the radiator cap on the radiator
Closed system: Cap is on an expansion tank
They use a closed system when the radiator is not at the highest point. The fill point must be highest in the system. So in older cars where the top of the radiator is the highest, that is where the cap is and is an open system.
In newer cars they sit the radiator down in the chassis and use an "expansion tank" at the highest point and the cap goes there. Closed system
Both types of systems work great from what I've experienced.
I got the radiator from the place I use to work. Pro Comp Electronics (Made in china) and its a standard chevy radiator measuring 19" tall X 27" wide overall
Got my fan shroud started
3000 series .050" thick sheet aluminum, sheared and bent on a harbor freight press brake lol. Turned out bitchin
[Image: PhotoGrid_1362703974663.png]
Just need to mount the shroud to the radiator and cut a 16" hole in it
This post was last modified: 03-08-2013, 03:59 AM by Captain America.
06-12-2013, 01:58 PM #321
Just got another benz and im fuckin jealous of this thing man!
06-13-2013, 02:09 PM #322
Love this car Capt.
Keep up the good work
Love this car Capt.
lgreeley83
Mr. Rumbles
07-08-2013, 12:42 AM #323
Been awhile let's see a video!
lgreeley83
07-08-2013, 02:20 PM #324
I think it needs a welded diff first
07-08-2013, 02:34 PM #325
Its mostly a driver so I wouldn't want to wear out tires and look like a jackass driving around a parking lot, lol. A limited slip would be nice though!
There has been much done since the last update so I need to get on updating this thread haha
02-14-2014, 01:32 AM #326
I'm So lazy to post now... lol
lgreeley83
Mr. Rumbles
02-14-2014, 07:28 AM #327
That things bad. Lol
lgreeley83
02-14-2014, 11:32 AM #328
I'm curious if the XXL prechambers did anything good? bad? melty?
02-14-2014, 12:46 PM #329
(02-14-2014, 11:32 AM)Simpler=Better I'm curious if the XXL prechambers did anything good? bad? melty?
Have been driving it this way a week now and nothing melty yet but gawd it has lots of power. Who could have known a 300D could be quick? My VDO pyro is super slow so I need a new gauge before I up the fuel further. I'm not done yet
02-14-2014, 03:14 PM #330
How much oomph did you get from reaming the pre chambers?
02-14-2014, 04:17 PM #331
(02-14-2014, 03:14 PM)sassparilla_kid How much oomph did you get from reaming the pre chambers?
I've got arms like fucking popeye those things are hard as hell.
02-14-2014, 08:07 PM #332
(02-14-2014, 04:17 PM)Simpler=Better
(02-14-2014, 03:14 PM)sassparilla_kid HI'm not doneCool much oomph did you get from reaming the pre chambers?
Lmao! I have nothing to compare to. I put the XXL chambers in with new injectors from Greezer. And yes, Simpler=Better drilled and reamed them. I just did the finish work. i do know one thing... The poor 617 make a shit ton more power as it is and im
02-16-2014, 04:42 PM #333
What size did simpler drill them out too?
This post was last modified: 02-16-2014, 04:42 PM by MFSuper90.
02-16-2014, 04:58 PM #334
(02-16-2014, 04:42 PM)MFSuper90 What size did simpler drill them out too?
3 front holes to .156" rear two and bottom to .125”
Stock (broken) 1985 prechamber on the left and big baller Simpler=Better ported chamber on the right
[Image: IMG_20140111_101408.jpg]
This post was last modified: 02-16-2014, 04:59 PM by Captain America.
02-16-2014, 05:07 PM #335
I have to say that cap'n has more hours into those PCs than I do, I just hogged em' out and "let" him deburr them-that's the PITA part.
02-16-2014, 05:34 PM #336
(02-16-2014, 05:07 PM)Simpler=Better I have to say that cap'n has more hours into those PCs than I do, I just hogged em' out and "let" him deburr them-that's the PITA part.
They look bitching though right!?! Fuck dude, making so much power now that it ripped the rubber on the driveshaft center support! I had to change it last night
02-16-2014, 05:47 PM #337
Holy tits, those things are massive!
I'm not gonna make the drip hole bigger tho
So you drilled them with a carbide bit then reamed them to the correct size with a carbide reamer?
02-16-2014, 05:48 PM #338
That's HUGE. Triple the area maybe?
02-16-2014, 05:56 PM #339
Have to look back at messages with Simpler=Better and Mr. OM616 but OM616 basically told me in one of the last messages that he didn't think we could go too big haha. He did not reccomend opening up the bottoms hole, but oh well. My 300 sings and I still have fuel to add. I mean I MOVES!!!!
I also fogot to mention the burn tube was opened to 9/16" over the tiny hole that was in the chambers I pulled from this motor. I need to get a rolling video up stat!
This post was last modified: 02-16-2014, 05:57 PM by Captain America.
lgreeley83
Mr. Rumbles
02-16-2014, 06:53 PM #340
Wonder what FI would say :-)
lgreeley83
02-16-2014, 07:25 PM #341
(02-16-2014, 05:47 PM)MFSuper90 Holy tits, those things are massive!
(02-16-2014, 05:48 PM)raysorenson That's HUGE. Triple the area maybe?
(02-16-2014, 06:53 PM)lgreeley83 Wonder what FI would say :-)
Fuck that guy!?!
Fuck that guy!?!
02-16-2014, 07:31 PM #342
So carbide bits an dreamers or just regular old bits and reamers? Sorry to be a PIA, I'm just trying to get my shit in order so I can get them ordered and get er done.
So did you use a different washer for the injector since you opened up the burn tube?
lgreeley83
Mr. Rumbles
02-16-2014, 07:37 PM #343
Lol I remember reading early discussions where everybody thought the car would explode or whatever other assortment of ideas. Glad it's working out. Ill be doing this .... someday..
More videos!
lgreeley83
More videos!
02-16-2014, 08:07 PM #344
(02-16-2014, 07:31 PM)MFSuper90 So carbide bits an dreamers or just regular old bits and reamers? Sorry to be a PIA, I'm just trying to get my shit in order so I can get them ordered and get er done.
No sir. I've found different years had different sizes. The '85 chambers has close to the same as the reamed chambers Simpler=better used while mine were much smaller. I used heat shields supplied by Mercedes Source.
(02-16-2014, 07:37 PM)lgreeley83 Lol I remember reading early discussions where everybody thought the car would explode or whatever other assortment of ideas. Glad it's working out. Ill be doing this .... someday..
More videos!
Yes, more videos soon! As I stated, I was told that the holes could not be too big.... I plan to get a legit EGT ASAP then I will turn the fuel up more and go from there. As it stands. I could be happy where the fuel is at, but I always like moar lol
More videos!
capflya
Dreaming of a VNT
309
02-16-2014, 10:29 PM #345
MOAR FUEL! Big Grin
capflya
MOAR FUEL! Big Grin
02-17-2014, 11:49 AM #346
A reamer is only good for taking off a small amount of material, and runs at a low RPM. So to get the XXL holes, it took multiple steps. IIRC it was 1/8" on everything, then .156" on the front 3. The burn tubes were roughed with a 1/2" but and then a 9/16" reamer, IIRC. I forget the details, but they're all the same across 5 chambers which is what matters.
He may still melt the PC tips-there's significantly less material, and Merc reduced the hole size to make for a smoother burning quieter engine. But we will never know until one way when something goes bang Smile
So, uh where's the video huh!?!??!!
This post was last modified: 02-17-2014, 11:51 AM by Simpler=Better.
02-17-2014, 03:30 PM #347
Ima need to grab some chambers from the yard soon I guess
OM616
10mm MW
572
02-17-2014, 04:04 PM #348
(02-16-2014, 07:25 PM)Captain America
Fuck that guy!?!
LOL... There are enough people who have done this mod to some degree that it would be nice to add whats been done and the results to the Prechamber Mod thread
http://www.superturbodiesel.com/std/Thre...lame-Front
OM616
Fuck that guy!?!
lgreeley83
Mr. Rumbles
02-17-2014, 06:40 PM #349
Yeah that's a good read.
lgreeley83
02-18-2014, 09:47 AM #350
(02-17-2014, 04:04 PM)OM616
Fuck that guy!?!
Yes sir, and I plan to add pictures and everything. Just have been super busy working on race trucks and b.s. lol
Fuck that guy!?!
 4 Guest(s)
 4 Guest(s)
