STD Tuning Engine IP timing, Myna 603 pump on 606 block??
Diesel-Frank
08-23-2010, 09:13 AM #1
hi! how to set the pumptiming on a om606, the pump is a myna from a om603 engine.
when the tap is in the center of the inspection hole on the pump, and the crankshaft is at 15 degrees AFTER TDC (haynes manual), how many degrees BEFORE TDC starts the pump injection??
do i need special tools??
Diesel-Frank
HughF_UK
08-23-2010, 09:27 AM #2
I got mine fitted without special tools, I just set the engine 15 atdc (haynes manual here too) and with the notch held in the hole by a screwdriver Smile I got the pump slid into the advance mechanism/gear/cog with some help from my dad to hold the cog engaged into the chain.
I would like to find a way to now check the advance, but not sure how the spill port method works, I'm used to the Bosch VE 'Rear-entry' method and have dti and adapters for this.
hugh
HughF_UK
hugh
Alastair E
Moderator?--Nah...
266
08-23-2010, 10:02 AM #3
I believe the spill timing is 24 degrees BTDC is equal to the pointer-in-line with governor housing at 15 degrees After TDC....
I plan to confirm this when I remove the electronic pump from my 606 I'll check its 'spill-timing' point before I remove it....
[Image: 300TDnoplate.jpg]
Alastair E
jeemu
457
08-23-2010, 12:50 PM #4
Timing debend when that pump is made. Is that 7 or 8mm?
jeemu
Alastair E
Moderator?--Nah...
266
08-23-2010, 04:58 PM #5
I think HughF pump is still 5.5mm, He was testing out his 606 before getting pump modified...
--Not sure about the other guy...
Alastair E
HughF_UK
08-24-2010, 07:00 AM #6
Jeemu,
Mine is a stock UK spec 603 N/A pump...
Hugh
HughF_UK
Jeemu,
Hugh
Diesel-Frank
08-25-2010, 08:44 AM #7
(08-23-2010, 12:50 PM)jeemu Timing debend when that pump is made. Is that 7 or 8mm?
i think it is 7mm, but not sure. and they have changed to the newer cam, and external ALDA. myna told me the pump can handle 580hp on om606, and 510hp on om603
myna modified the pump for about a month ago.
Diesel-Frank
muuris
OM605
318
08-25-2010, 09:52 AM #8
As the pump is that new, set timing at the crank to 20 BTDC and install pump with the locking tool in the insp hole. Mynä changes the timing mark position inside the pump.
muuris
tomnik
08-25-2010, 11:00 AM #9
any information about this "new cam"?
If custom made, will those be for sale?
More lift and/or modified profile?
Tom
tomnik
Tom
jeemu
457
08-25-2010, 01:49 PM #10
Like muuris say. Timing is 20 BTDC.
I have also new cam my ip.
tomnic: my friend can make what design cam you want.
jeemu
tomnik
08-25-2010, 02:04 PM #11
(08-25-2010, 01:49 PM)jeemu my friend can make what design cam you want.
first I should know what to change?
profile?
cam lift?
Next: still use the 7mm elements that originally are designed for 7mm cam lift?
Modification of the stock cam or completely new?
Tom
tomnik
profile?
cam lift?
Tom
jeemu
457
08-25-2010, 02:21 PM #12
(08-25-2010, 02:04 PM)tomnik
profile?
cam lift?
Tom
Dont know about those cams. That i know at there is few desing of those.
jeemu
profile?
cam lift?
Tom
tomnik
08-26-2010, 05:49 AM #13
(08-25-2010, 09:52 AM)muuris As the pump is that new, set timing at the crank to 20 BTDC and install pump with the locking tool in the insp hole. Mynä changes the timing mark position inside the pump.
timing still is 24 deg but only the marks are changed?
jeemu: maybe you could measure the total cam lift next time when the delivery valves are out?
Tom
tomnik
Tom
muuris
OM605
318
08-26-2010, 06:21 AM #14
I meant marks are changed from MB stock. I believe the actual injection timing is as the marks say. Haven't checked, though.
muuris
tomnik
08-26-2010, 07:29 AM #15
(08-26-2010, 06:21 AM)muuris I meant marks are changed from MB stock. I believe the actual injection timing is as the marks say. Haven't checked, though.
if timing mark now is 20 deg for BOD it's either because of increased pre lift adjustment or bigger supply bore or different position of supply bore compared to stock.
Nothing unusual using the 7mm elements.
But both increased bore and increased pre lift adjustments will reduce the effective stroke.
It gets interesting when the different position of the marks result from a different cam...
Tom
tomnik
Tom
Diesel-Frank
08-29-2010, 07:49 AM #16
thanks for good help! super forum!
what size of the intercooler for the w124??
2,5 or 3" in/out??
height, width and thickness?
Diesel-Frank
2,5 or 3" in/out??
ajarvis8
10-29-2010, 07:18 AM #17
Hey guys,
I'm kinda confused. I have an om606 with a stock 603 IP, and I have got the timing screwed up. When I have the injection pump locking tool in, the engine should be at 24 BTDC? I was under the impression it was supposed to be 14 ATDC.
Help me, I need it!
Thanks in advance.
ajarvis8
Hey guys,
Help me, I need it!
Thanks in advance.
10-29-2010, 11:19 AM #18
I believe only if you had Myna build the injection pump!
muuris
OM605
318
10-29-2010, 04:51 PM #19
Yes of course, as I wrote the 20 BTDC as a reply to the original question. Stock pumps are timed as manuals say, ATDC.
muuris
ajarvis8
10-30-2010, 08:36 AM #20
Thanks just double checking, I am having timing issues with my 606 with a 603 pump.
This post was last modified: 10-30-2010, 09:11 AM by ajarvis8.
ajarvis8
George3soccer
11-01-2010, 10:51 AM #21
Where in Nj are you located? Also what chassis is this 606 in.
George3soccer
ajarvis8
11-02-2010, 07:50 AM #22
Lake hopatcong. I'm not that far from you at all. The 606 is on a test stand sitting on the floor in my garage. I am planing to drop it in my 1990 jeep Comanche.
ajarvis8
George3soccer
11-02-2010, 12:26 PM #23
Nice nice. I have a few friends out in moristown, Jefferson, and Wharton.
George3soccer
