STD Maintenance General HELP!-om617 turbo fuel injector removal
Silberpfeil
Slowly Sideways
85
09-12-2010, 04:59 AM #1
I realize in advance this has probably been answered before but could not find it readily trying to search for it.
Do you need a special tool or what tool is needed to remove the fuel injectors on a om617 (84 300d)???
About how long does this take?
How can you tell the condition of your fuel injector pre-chambers?
Is a visual inspection effective/what do I look for if it is???
Anyone have plans/schematic for a pop tester???
Thanks as always in advance,
John
This post was last modified: 09-13-2010, 01:39 PM by Silberpfeil.
Silberpfeil
John
09-12-2010, 09:32 AM #2
(09-12-2010, 04:59 AM)Silberpfeil Do you need a special tool or what tool is needed to remove the fuel injectors on a om617 (84 300d)???
17mm wrench and 27mm deep socket.
Quote:About how long does this take?
About 15 minutes.
Don't forget that you'll need new crush heat shields and new return hose.
Quote:How can you tell the condition of your fuel injector pre-chambers?
You can see the atomizing ball and glowplug, but you can't see the head or the piston.
Quote:Anyone have plans/schematic for a pop tester???
Contact bgkast
http://www.superturbodiesel.com/std/inje...ml#pid1715
This post was last modified: 09-12-2010, 09:33 AM by ForcedInduction.
About 15 minutes.
Contact bgkast
Silberpfeil
Slowly Sideways
85
09-13-2010, 03:07 AM #3
Thanks a lot Forced!--appreciate the help.
BUT... if I can't see the head or the piston of the prechamber how do I determine if they need replacing???
Also-- Is removal and cleaning of the prechambers recommended??
What would I use?
Is brake cleaner OK or too caustic??
Thanks again guys.
Silberpfeil
What would I use?
Thanks again guys.
09-13-2010, 08:17 AM #4
(09-13-2010, 03:07 AM)Silberpfeil BUT... if I can't see the head or the piston of the prechamber how do I determine if they need replacing
If the engine runs well, they don't.
Quote:Also-- Is removal and cleaning of the prechambers recommended??
They are non-wear items and don't need to be removed unless a problem is suspected.
Quote:What would I use?
A special socket is needed to remove the collar along with a slide hammer to pull the chambers out.
Quote:Is brake cleaner OK or too caustic??
With it in the engine, its far too combustible and you could cause damage when starting the engine. Out of the engine thats fine, they're high quality steel that can stand up to pretty much anything.
09-13-2010, 01:13 PM #5
Dental pics for pulling the return lines off.
1/2 socket extension
1/2 torque wrench
(09-12-2010, 09:32 AM)ForcedInduction
About 15 minutes.
Contact bgkast
1/2 torque wrench
About 15 minutes.
Contact bgkast
Silberpfeil
Slowly Sideways
85
09-13-2010, 01:57 PM #6
(09-13-2010, 08:17 AM)ForcedInduction [quote='Silberpfeil' pid='17604' dateline='1284365231']BUT... if I can't see the head or the piston of the prechamber how do I determine if they need replacing
Well, that's the thing it still is intermittently idling rough. Also has some nailing and occasional light smoke on start up even after two recent valve adjustments. Obviously I know the main culprit is worn nozzles (which I will replace), but I thought I would do as much as possible to get it "well".
Also, I believe the number five injector is sometimes "stuck". Now an old timer told me he would spray WD40 to remove deposits when he pulled injectors. Is there a 'solvent' that I should spray when removing the injectors? Should I soak them in something overnight?
And.... Is it worth rebuilding the injectors when I pull them? (seal kit etc...)
This post was last modified: 09-13-2010, 02:03 PM by Silberpfeil.
Silberpfeil
rdirtycar
flash gordon
145
10-26-2010, 06:12 AM #7
There's no reason to clean the injectors if you're replacing the nozzles. All the carbon gets tossed with the old nozzles. Rebuilding injectors is one of the most nerve racking things I've done to a car. The little injector tips can't touch anything and heart surgery can tolerate more dust. A lot of compressed air and calm nerves help. Tweezers, a pop tester, heat shields, some laquer thinner to degrease, soup cans, 1500 and 2000 grit paper to polish the sealing surfaces, and I mean polish or they WILL leak, a piece of glass, mmo on a kabob skewer for assembly lube, five separate little containers to keep the parts from getting mixed up between the injectors. I wore earphones because if youre doing it right compressed air blown through the injector housings is deafenig. This job is awful but very worthwhile. Throttle response, starting and not to mention engine longevity are the benefits. Unatomizrd fuel is bad for the cylinder walls I hear. Expect the new nozzles to be a bit noisy at first as they get settled in the injector housings. New fuel return line please. Party time.
Oh and a big exhaust fan because it's pretty unhealthy.
This post was last modified: 10-26-2010, 06:13 AM by rdirtycar.
rdirtycar
10-27-2010, 05:48 AM #8
(10-26-2010, 06:12 AM)rdirtycar There's no reason to clean the injectors if you're replacing the nozzles.
There is. The body still has a grime on the interior surfaces and it will remove exterior grime that could transfer onto the nozzle body from your hands. Besides, whats the hassle tossing them in the ultrasonic bath for 10 minutes every decade or two?
This post was last modified: 10-27-2010, 05:50 AM by ForcedInduction.
10-27-2010, 08:52 AM #9
Clean is faster.
Clean is faster.
10-27-2010, 02:36 PM #10
Is this a decent tester?
http://www.peachparts.com/Wikka/DieselInjectorTester
Silberpfeil
Slowly Sideways
85
10-27-2010, 10:54 PM #11
(09-13-2010, 08:17 AM)ForcedInduction A special socket is needed to remove the collar along with a slide hammer to pull the chambers out
#1 Where would you guys recommend getting these two (2) tools from? Any help would be appreciated!
#2 Any recommendations on a source for a R&R kit for the injectors?
Many thanks in advance,
John
This post was last modified: 10-27-2010, 10:56 PM by Silberpfeil.
Silberpfeil
John
11-01-2010, 03:20 PM #12
1. I have the collar tool for rental. $75deposit + $10(6pack of beer) + shipping both ways.
2. C Sean Watts on fruitparts.
This post was last modified: 11-01-2010, 03:21 PM by winmutt.
