STD Tuning Engine Electric Fuel pump
Electric Fuel pump
Electric Fuel pump
Pages (3): 1 2 3 Next
12-23-2008, 10:53 AM #1
How about it? That would deliver a smooth fuel flow and constant pressure to the injection pump.
I've used electric oscillating pumps on other things (transfer pumps) and they are junk at best. I had the Cummins pump in mind but it is only set to pump 15psi and has a 5psi high flow pressure. I want to run 25-30 psi across the RPM range.
[Image: lift_pump.gif]
GREASY_BEAST
12-23-2008, 02:04 PM #2
I like it. It would also be good to replace the banjo fitting on the return line with one that releases at a higher pressure (like 20-30psi).
GREASY_BEAST
tomnik
12-24-2008, 05:50 AM #3
GREASY_BEAST I like it. It would also be good to replace the banjo fitting on the return line with one that releases at a higher pressure (like 20-30psi).
The old style banjos can be disassembled. Pull the spring and stretch it (to 25-28 mm expanded length).
Tom
tomnik
Tom
totaldisaster
lightly modded OM606
211
01-17-2009, 05:59 AM #4
what is the biggest resistor in the fuel supply?
Didn't you upgrade your main fuel filter to that oversized baldwin?
totaldisaster
01-17-2009, 06:29 AM #5
I did and the Baldwin is working great, but I want to get rid of the stock pump's pulses and variable fuel pressure/output.
Patrick
Greaser
8
01-17-2009, 10:42 PM #6
(12-23-2008, 10:53 AM)ForcedInduction How about it? That would deliver a smooth fuel flow and constant pressure to the injection pump.
I have two pumps on my Dodge CTD. I run 27psi until I put my foot on the pedal. I have a stock pump in the tank and a BD Diesel transfer pump on the side of the Engine Block. I did this because my first VP44 IP starved and died. This works great! Im thinking of adding a pump to my 240D, it dies sometimes trying to pump veg oil.
1966 Chevelle 427BB
1980 VW Diesel Pickup
1983 240D 3.0 TD 4spd
2002 Dodge Quad 4x4 CTD
Patrick
1966 Chevelle 427BB
Lincolnlock
01-18-2009, 11:04 PM #7
Just buy a Holley blue pump. They are way cheaper and flow quite a bit more than the crappy cummins pumps that are prone to failure.
Lincolnlock
01-19-2009, 10:40 AM #8
The downside is the decent aftermarket pumps are all $200-350.
The FueLab pump is brushless, and $350. http://fuelab.com/prod.php?pk=1
oel_brenner
01-19-2009, 08:43 PM #9
(01-18-2009, 11:04 PM)Lincolnlock Just buy a Holley blue pump. They are way cheaper and flow quite a bit more than the crappy cummins pumps that are prone to failure.
only $135 here
http://store.summitracing.com/egnsearch....2&D=307782
probably get it cheaper somewhere else , have to shop it around
lincolnlock,
you are having no trouble using the Holley unit with diesel ?
but that fuelab pump looks like a nice unit.
lots of $$ tho
This post was last modified: 01-19-2009, 08:44 PM by oel_brenner.
cars
1991 W126 350SDL turbodiesel
1987 W124 E300D turbodiesel
1987 W126 300SDL turbodiesel
1984 W107 SL300D turbodiesel
1974 W115 /8 300D diesel
trucks
boats
oel_brenner
only $135 here
lincolnlock,
lots of $$ tho
cars
trucks
boats
01-19-2009, 09:27 PM #10
"maximum pressure of 14 psi" is the deal killer. Our engines need to be around 30psi.
Telecommbrkr
Soon to be mod'ing......
97
06-14-2009, 04:57 PM #11
Is there a difference between flow and pressure requirements for our engines? I found these pumps at a very reasonable price, and others are using these with the OM617 with positive results.
http://www.autoperformanceengineering.co...pumps.html
225 LPH seems like sufficient, no?
This post was last modified: 06-14-2009, 04:58 PM by Telecommbrkr.
Mods are in the works...
Telecommbrkr
06-14-2009, 06:23 PM #12
Reciprocating pumps suck. They are loud, vibrate, pulse the fuel flow and are cheap for a reason.
I wouldn't spend under $100 for a decent electric fuel pump to replace the stock mechanical unit. I've had my eye on the ones used to feed the 7.3L Powerchokes.
This post was last modified: 06-14-2009, 06:26 PM by ForcedInduction.
Telecommbrkr
97
06-16-2009, 10:00 PM #13
(06-14-2009, 06:23 PM)ForcedInduction Reciprocating pumps suck. They are loud, vibrate, pulse the fuel flow and are cheap for a reason.
I take it these pumps might not be good?Big Grin
(06-14-2009, 06:23 PM)ForcedInduction I wouldn't spend under $100 for a decent electric fuel pump to replace the stock mechanical unit. I've had my eye on the ones used to feed the 7.3L Powerchokes.
Do you have a part number, or any specs on what this pump is putting out?
Telecommbrkr
GREASY_BEAST
06-16-2009, 10:20 PM #14
Not to be a fly in the unguent, but why is pulsing bad? That said, I have a solution in the works that doesn't pulse. Maybe it will be done by the end of the summer. Hint: it works by virtue of boundary-layer adhesion.
GREASY_BEAST
cell
11-21-2009, 11:35 PM #15
(06-16-2009, 10:20 PM)GREASY_BEAST Not to be a fly in the unguent, but why is pulsing bad? That said, I have a solution in the works that doesn't pulse. Maybe it will be done by the end of the summer. Hint: it works by virtue of boundary-layer adhesion.
tesla turbine? Big Grin
cell
Syncro_G
0-60 in 29 sec
280
11-22-2009, 12:38 AM #16
So is the idea here to replace the mechanical lift pump or to supplement it?
I've been thinking about adding a supplemental pump (my gas-based chassis has the harness and spot next to the tank for a pump) I have a good gas pump but I don't think it will perform well with the more viscous diesel/oil.
'84 G-Wagen turbodiesel
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
DervTuning
11-23-2009, 12:36 PM #17
For the last ~20K miles, I am using a Bosch external electric pump for a petrol engine. I forget the listing, but it is for a CIS application, raises the pump pressure to just above the regulator at the outlet banjo, and has no problems otherwise. Current draw is <5 amps since the pressure is low as compared to a CIS car, and is quiet as well.
Benefits are numerous. Idle is improved in terms of smoothness, since the fuel pressure is near constant compared to the very pulsed output from the factory pump. "Throttle" response and tip in are also improved for better drive-ability. Best of all is a noticeable increase in high rpm performance, and more power overall. It is subtle at first, but noticeable, becoming more and more apparent as the rpms increase. To note, this is with the 5.5mm elements on a w123 MW pump.
DervTuning
GREASY_BEAST
11-24-2009, 06:39 PM #18
(11-21-2009, 11:35 PM)cell tesla turbine? Big Grin
Precisely, I found someone's Mechanical Engineering PhD thesis that discusses the design parameters of such a device, and I used these to size one for this application. I have all the parts, possibly even a usable motor, although it might not be powerful enough. Unfortunately, I have had zero time to build it, and probably won't get around to it for quite some time. If/when I do I will post results.
Its good to hear someone had some success replacing the lift pump, however I cannot imagine how/why it would affect a difference in power output, unless there is an air leak somewhere, or the elements are creating sufficient vacuum on the downstroke at high rpm to vaporize the fuel... Recall that fuel isn't compressible in liquid form.
GREASY_BEAST
11-24-2009, 09:19 PM #19
(11-24-2009, 06:39 PM)GREASY_BEAST Recall that fuel isn't compressible in liquid form.
Not significantly in the low pressure fuel system anyways.
11-25-2009, 09:51 PM #20
(06-16-2009, 10:00 PM)Telecommbrkr
The powerstroke high pressure pump is a 40-60 psi spec. Big money though, unless you rip them out of a yard. Its like 2-300 bucks. For that I would spend some more and get an adjustable FASS or RAPTOR pump.
Ian White
machinemanjr
22
11-30-2009, 01:16 AM #21
Try using an all purpose Carter. I had a Carter on my dodge (because the delphi pump is trash) but I upgraded to the FASS DDRP (fass direct dodge replacement pump) I have been very happy...
My $0.02...
Ian White
My $0.02...
E300TSC
Turbo-Supercharged
321
06-25-2010, 07:57 AM #22
Thought I'd revive this discussion since I've been thinking about this on my car now.
Some things to think about:
1. What is the max fuel flow required for a given set of elements at max power/RPM?
My rough calculations indicate a need for 100+ gal/hr at 6000 RPM with larger than stock elements @ max power. Anyone have a stroke length or actual CC rating for these pumps at max?
2. What is the correct pressure to achieve adequate element filling at high RPM's?
Forced is saying 30 which sounds fair. I also think we could use the trucks as a model - my F250 pump puts out around 65 PSI. Anyone know the GPH spec. for the PSD pump?
3. How do we regulate the pressure?
Do we modify the stock relief valve or plug the relief port and use an external bypass regulator? The PSD guys have been modifying their fuel systems with external regulators and removing the "ball and spring" type stock regulators with good results. Only thing is that these regulators are pretty expensive.
Also consider that we will have to wire in oil pressure switches and relays for safety to shut the pump off when the engine quits. I can also see adding a curcuit to the GP relay to get the engine going before the oil pressure comes up.
All in all, it's looking like a $500 upgrade once it's all said and done. But it may be required if the existing system doesn't meet the engine's fueling requirements.
E300TSC
Alastair E
Moderator?--Nah...
266
06-25-2010, 08:40 AM #23
Yup, 100gall/hr should do it......
Ive seen somewhere (did try and find it....) that a pump flow of 170ccm per 1000 strokes, per element at WOT and Full delivery is what one of the Finnish guys was running on his 605 Super-Turbo, pushing summit like 450 BHP--Think thats what it was anyway, Defo 170ccm/1000 though.....
Its always a good idea to get rid of that pulsing from the standard lift-pump, fuel-press is all over the place on std installation, and while this doesnt seem to make a Huge difference to a Standard engine it'll prolly affect a Tuned motor quite badly.....
[Image: 300TDnoplate.jpg]
Alastair E
06-25-2010, 02:21 PM #24
Pumps:
http://www.retrotekspeed.com/products/fu...pumps.html
Regulator:
http://www.retrotekspeed.com/products/fu...lator.html
I'd use the 70152 pump and 10671 regulator
Pumps:
Regulator:
Einar
06-26-2010, 04:00 AM #25
Would this be a good idea on a standard engine(603A), could I Use a standard pump from petrol(same as used on single pump 300E), normal work-pressure is about 70 PSI(5 bar) and I think maximal pressure is about 100 PSI(7 bar), what will regulate the pressure?
I think this would help start engine after been driving empty, but it may have other positive features on a standard engine too?
Einar
Kozuka
I'm_Badass
334
06-26-2010, 04:24 PM #26
You can use a Walbro GL392 ($120) (Diesel Truck Forums Get About A Year Out Of These) or you can use a Fuelab fuel pump ($350 but made for high pressure diesel) you must use a fuelab fuel pressure regulator because these pumps produce 100+ psi.
Kozuka
tomnik
06-27-2010, 04:44 AM #27
(06-25-2010, 07:57 AM)E300TSC Thought I'd revive this discussion since I've been thinking about this on my car now.
purging the IP and important: cooling. These points are against plugging the stock overflow valve.
I don't have a good feeling with gasser pumps. Diesel has higher viscosity and the pump is running all the time (against pressure).
I have a "tooth gear" pump from CDIs on my table. This is a small "hydraulic" pump that I will drive as a test with a wiper motor, later maybe mechanically from somewhere on the engine. The pump has an adjustable pressure by-pass valve. Mechanically driven by engine rpm also makes some sense.
Tom
tomnik
Tom
Telecommbrkr
97
06-27-2010, 11:48 AM #28
Ok so I buy the pump and regulator from retrotekspeed above. I can put this setup possibly with the addition of a larger fuel filter inline anywhere between the tank and the engine, bypass the stock lift pump and filter tie the return line into the regulator and that's it?
Telecommbrkr
GREASY_BEAST
06-27-2010, 03:25 PM #29
(06-27-2010, 11:48 AM)Telecommbrkr Ok so I buy the pump and regulator from retrotekspeed above. I can put this setup possibly with the addition of a larger fuel filter inline anywhere between the tank and the engine, bypass the stock lift pump and filter tie the return line into the regulator and that's it?
Remove the stock lift pump and replace it with a cover plate, continue to use the stock fuel filter. Upgrade all high pressure hoses to fuel injection hose. But you have the right idea.
This post was last modified: 06-27-2010, 03:27 PM by GREASY_BEAST.
GREASY_BEAST
yankneck696
Build it so strong &amp; blow it up good !!!
395
06-27-2010, 03:36 PM #30
<<I have a "tooth gear" pump from CDIs on my table. This is a small "hydraulic" pump that I will drive as a test with a wiper motor, later maybe mechanically from somewhere on the engine. The pump has an adjustable pressure by-pass valve. Mechanically driven by engine rpm also makes some sense.>>
Hydraulic oil is still a thicker viscosity. Might I suggest a "Jabsco type" nibrile impellor (Marine raw water & oil/diesil transfer) type pump as the volume supplier to the gear pump with a bypass regulator? It might make the most sense. You can already get them with the right electric motor on them. I have several(for oil changes on marine engines) & 1 is rated for 100 GPH for cold oil. That would guesstimately be 150 - 174 GPH of diesel. "Globe impellor" in Brocton, MA. has nearly indestructible impellors that can pass lots of sand with very little change in performance(34' sportsfish grounded in the middle of the ICW north of the first bridge in Daytona FL with twin cummins. Had 1 engine running for 4 1/2 hours while dragging ourselves off the sandbar with 2 anchors & the windlass, traveled another 500 miles to port & pulled both impellors & could barely tell the difference). That gives you delivery, pressure & regulation. I wonder if the right "Jabsco/Sherwood" type pump might even be able to do delivery & pressure? If mechanical drive is wanted, they are simple to install in any belt system.
Options:
1: "Transfer/Jabsco/Sherwood" type pump with "Globe or Nitrile/Nibrile" impellor feeding volume to Gearotor hydraulic pump with bypass regulator (Both pumps can be run electric or belt[Applies to all])
2: Large enough "T/J/S" pump to easily supply volume & delivery pressures across the board with bypass regulator.
3: Hydraulic pump alone ( might have problems with viscosity, wear, priming & draw)
OK, there's my rant. "You may be right, I may be crazy" You know the rest...
Ed
yankneck696
Options:
Ed
Telecommbrkr
97
06-27-2010, 06:16 PM #31
(06-27-2010, 03:25 PM)GREASY_BEAST Remove the stock lift pump and replace it with a cover plate, continue to use the stock fuel filter. Upgrade all high pressure hoses to fuel injection hose. But you have the right idea.
I have recently bought a whole pile of viton rubber hose to replace my whole fuel system lines to be able to run biodiesel. Will this hose work? Will it say on the hose what pressure it's rated for? What pressure rating should I be looking for, one that exceeds the max of the pumps rated psi output?
Telecommbrkr
06-27-2010, 11:15 PM #32
Most standard "fuel hose" like you'd get at a parts counter will have a working pressure around 50psi and a burst pressure around 150psi. It all depends on the material and design/standard.
The injection system shouldn't need any more than 30psi so I doubt your viton hose will have a problem with the pressure.
Tymbrymi
Klatta Klatta
185
06-28-2010, 09:19 AM #33
Personally, I plan on using the CIS fuel pump out of my parts '90 300TE. It is a stock setup so it already has all the mounting brackets, etc. which should save some time. Also, it should have no problem running any pressure I want, and it should be CHEAP to buy even if I didn't have a parts car to snag it from.
The regulator front is something I'm still not sure about. I'll initially try using the stock "regulator". If that doesn't work, I'll probably use a setup like a DIY boost controller. That's basically all a regulator is for us diesel guys. Gassers have a regulator that will increase fuel pressure when there is no vacuum in the intake manifold (automatic "fuel enrichment" under load), which makes those aftermarket regulators expensive, and is something we don't need at all.
My $.02
(06-27-2010, 04:44 AM)tomnik I don't have a good feeling with gasser pumps. Diesel has higher viscosity and the pump is running all the time (against pressure).
Diesel is also a much better lubricant. I don't think we can say one way or the other until someone has some miles on a gasser pump. Huh
(06-27-2010, 04:44 AM)tomnik I have a "tooth gear" pump from CDIs on my table. This is a small "hydraulic" pump that I will drive as a test with a wiper motor, later maybe mechanically from somewhere on the engine. The pump has an adjustable pressure by-pass valve. Mechanically driven by engine rpm also makes some sense.
That sounds like the high pressure pump. I don't think that will work well at all. Two things, it is designed to produce 1600 bar, and my CDI has a fuel pump in the tank to provide diesel to the high pressure pump. Basically, it is probably horribly inefficient at 30psi, and I have no idea if it is self priming.
This post was last modified: 06-28-2010, 09:26 AM by Tymbrymi.
John Robbins
Tymbrymi
My $.02
John Robbins
Alastair E
Moderator?--Nah...
266
06-28-2010, 01:45 PM #34
(06-28-2010, 09:19 AM)Tymbrymi Personally, I plan on using the CIS fuel pump out of my parts '90 300TE. It is a stock setup so it already has all the mounting brackets, etc. which should save some time. Also, it should have no problem running any pressure I want, and it should be CHEAP to buy even if I didn't have a parts car to snag it from.
My $.02
Nah, The pump Tomnik has is the CDi Camshaft-Driven 'Lift-Pump' its a small internal/external gear pump intended to Feed the Rail Pump with fuel...
Its Not the Rail pump itself or the elect pump from the tank, this is the Engine-Driven pump which raises pressure prior to the rail-pump, and will be Most Suitable!
Alastair E
My $.02
Tymbrymi
Klatta Klatta
185
06-28-2010, 04:51 PM #35
(06-28-2010, 01:45 PM)Alastair E Nah, The pump Tomnik has is the CDi Camshaft-Driven 'Lift-Pump' its a small internal/external gear pump intended to Feed the Rail Pump with fuel...
All I know is that for my E320 CDI, there are only two fuel pumps... The in-tank pump, and the high pressure pump. See attached PDF for the fuel diagram for it.
.pdf
CDI_FuelPumps.pdf
John Robbins
Tymbrymi
.pdf
CDI_FuelPumps.pdf
John Robbins
tomnik
06-29-2010, 04:07 AM #36
mine is an early generation fuel lift pump like Alastair mentioned (Thx).
Your 320 is from '05 and I believe 3rd generation common rail.
The gear pump has clamping connections that are for sure not rail pressure, but it is small and has an adjustable pressure limiter integrated (and it is available here for little money).
Tom
tomnik
Tom
rdirtycar
flash gordon
145
06-29-2010, 06:34 AM #37
If the stock lift pump is removed along with the hand primer pump attached to it, how would one bleed the system after filter change, etc.?
This post was last modified: 06-29-2010, 06:36 AM by rdirtycar.
rdirtycar
Tymbrymi
Klatta Klatta
185
06-29-2010, 09:29 AM #38
(06-29-2010, 04:07 AM)tomnik mine is an early generation fuel lift pump like Alastair mentioned (Thx).
Nevermind then! Cool Sounds like it will be a good little pump if you can find a good way of driving it. Big Grin
(06-29-2010, 06:34 AM)rdirtycar If the stock lift pump is removed along with the hand primer pump attached to it, how would one bleed the system after filter change, etc.?
It should be a self bleeding affair at that point. The pump will act exactly like the hand pump. As soon as it is turned on it will start pumping fuel through the system and force all the air out. Smile
John Robbins
Tymbrymi
John Robbins
rdirtycar
flash gordon
145
06-29-2010, 04:49 PM #39
(06-29-2010, 09:29 AM)Tymbrymi
So just turn the car to "on" for a few seconds and the air will just push itself out... How does the system maintain the 30 or so PSI if its bleeding back to the tank? Is the fuel pressure held at 30 PSI by that banjo fitting you guys were talking about like a pressure regulating spring in the engine lubrication system? I assume this is the spring Forced was talking about stretching a bit to boost the pressure in the fuel feed side of the system..
This post was last modified: 06-30-2010, 11:17 AM by rdirtycar.
rdirtycar
rdirtycar
flash gordon
145
06-30-2010, 11:19 AM #40
could some sort of a adjustable fuel pressure regulator on the return line be used to adjust the fuel pressure with a turn of a screw or a knob?
rdirtycar
06-30-2010, 01:15 PM #41
Regulator:
This post was last modified: 06-30-2010, 01:16 PM by Captain America.
Regulator:
jeemu
&quot;some people do, some people talk.&quot;
457
06-30-2010, 01:24 PM #42
Hello. I have on my super turbo, Holley HP150 what i use trancfer pump.
No regulator and it is good at least 200hp/ltr.
http://www.holley.com/HolleyNews/article.asp?ID=32
jeemu
rdirtycar
flash gordon
145
07-01-2010, 06:40 AM #43
(06-30-2010, 01:15 PM)Captain America Regulator:
zing.... Is that what you use?
rdirtycar
07-01-2010, 12:56 PM #44
I use it on gas cars all day long. Never tried it with diesel though with the thicker viscosity...
I could easily try the RetroTek Speed pump and regulator since I am the one who makes them but I'm not in the "Super Turbo Diesel" category yet therefore I do not have the need for this type of setup.
if you guys want, I could try it out for ya.... when you bypass the mechanical lift pump, can it run dry? or does it get lubricated with the fuel moving through it? who sells a block off plate for it?
yankneck696
395
07-01-2010, 03:59 PM #45
<<who sells a block off plate for it? >> I've made many out of just a piece of plate steel. Or, you can gut the pump, get 2 gaskets & sandwich a piece of sheet metal between them & then bolt the pump on. I've never done a Merc like this, but many other applocations.
yankneck696
07-01-2010, 04:18 PM #46
Yeah, I know what you mean... I do it on small block Chevys, and fords all day. wasnt sure if you can run the pump dry though...?...
rdirtycar
flash gordon
145
07-01-2010, 04:28 PM #47
the fuel supply to the IP is pretty weak on mine. It bogs on the hills bad. I am planning on getting a good electric fuel pump and I'll need some sort of regulator on the return. I'm sure an adjustment from 25-75 psi is enough to tune the differences between gas and diesel out. I'll be purchasing one of these regulators for sure.
it'll probably be set to 25psi all the time. can a lighter spring be installed to account for the higher viscosity of the diesel fuel?
This post was last modified: 07-01-2010, 04:32 PM by rdirtycar.
rdirtycar
Kozuka
I'm_Badass
334
07-01-2010, 05:14 PM #48
Personally I would only use the one rated for diesel fuel which is the fuelab fpr.
(07-01-2010, 04:28 PM)rdirtycar the fuel supply to the IP is pretty weak on mine. It bogs on the hills bad. I am planning on getting a good electric fuel pump and I'll need some sort of regulator on the return. I'm sure an adjustment from 25-75 psi is enough to tune the differences between gas and diesel out. I'll be purchasing one of these regulators for sure.
Kozuka
GREASY_BEAST
07-01-2010, 05:29 PM #49
What's wrong with the FPR in return banjo? Just put a bigger spring in it to get the pressure you want.
GREASY_BEAST
07-01-2010, 06:11 PM #50
I don't see why you would have a problem...
There shouldn't be a compatibility issue everything is Viton
Here is a better link: http://www.professional-products.com/fuelregulators.php
I'm am not trying to sell these, just pointing out that they cost about $100 whereas the fuelab one costs $160
 3 Guest(s)
 3 Guest(s)
