STD Other Projects My 83 300D
My 83 300D
My 83 300D
  • 4 Vote(s) - 4.25 Average
BRABUS
02-12-2011, 07:01 PM #101
Modifying the intake manifold.
[Image: 146d52af-e6a2-4275-a526-6b378f8e3173.jpg]
[Image: 8897fbda-3b48-4346-8bd4-34be710c682f.jpg]
[Image: 37f4273e-c1b2-4b77-9a4f-6b1a1e8b0ec7.jpg]
When its welded i will grind and smooth it out on both out and inside.
But this is just a temporary solution, will make a bigger plenum on this intake someday when i get the time Smile
BRABUS
BRABUS
02-13-2011, 12:33 PM #102
Started with the exhaust manifold today.
Used mild steel with 38mm internal diameter and 42mm outer.
The pipes are cut and coned into about 35-36mm to match the flange/exhaust outlets in the head.
Tomorrow i will cut they a little shorter and start with the bends/the rest.
Here is a pic how it is right now.
[Image: 9aecdeb3-1d9f-4335-be5c-08429e2d0563.jpg]
This post was last modified: 02-13-2011, 12:35 PM by BRABUS.
BRABUS
02-13-2011, 01:36 PM #103
This kicks ass BRABUS keep on keepin on man! I cant wait to see how the plenum and the exhaust manifold turns out.
02-13-2011, 06:03 PM #104
(02-11-2011, 10:24 AM)BRABUS New intake SmileSmile Thanks DeliveryValve..
Glad it made it and it's on the engine... well sort of. How did the box survive? I am always curious on how shipping folks treat boxes.
Looking for forward to seeing more progress. Again, great job so far!
300D50
Graphite Moderator, ala RBMK
02-13-2011, 06:06 PM #105
Looks sexy!
I do wonder how real those are though...
Oh, and the intake looks awesome too! :p
This post was last modified: 02-13-2011, 06:07 PM by 300D50.
300D50
Looks sexy!
BRABUS
02-14-2011, 12:23 AM #106
(02-13-2011, 06:03 PM)DeliveryValve
The box was in great shape Smile
BRABUS
BRABUS
02-14-2011, 05:00 PM #107
Almost done with the intake manifold. A little grinding inside and its all done.
[Image: c837aad0-a9b8-48a7-93cc-5f2844cfdedf.jpg]
[Image: 6dc6019f-5f56-4e37-8e96-d0f113b33da3.jpg]
But this is only done because i want the car back in daily use(tired of driving a old nissanSmile)
When i get my modded IP i will build the plenum twice as big almost.
BRABUS
300D50
02-14-2011, 07:13 PM #108
Keep up the good work!
300D50
BRABUS
02-16-2011, 04:49 PM #109
had some time to work on the header. But i have only received 4 90degree bends. Så i couldnt do much. Will receive 30 90Degree bends and 15feet pipe later this weekend.
[Image: 5ea0c0b2-0946-4ddc-83bf-c5af241633f5.jpg]
BRABUS
BRABUS
02-18-2011, 06:04 PM #110
Removed the battery from the engine compartment, i put it with the other battery in the trunk. Got a little better space in the engine compartment now...
[Image: 5b064b46-e634-4b93-b526-a5658e2d9c9d.jpg]
Also started with the rest of the header, but did only runner 1 and 2 almost finnished. Both are 62.5cm long, all runners wil be around 75cm when they meet inside the collector.
[Image: 37a35072-a405-4eb6-bc9b-f59c2cc624ef.jpg]
BRABUS
s123
02-19-2011, 09:40 AM #111
This is a very cool car! Smart thing to do to get better weight balance and more room. What kind of cables are you using (mm2)?
s123
BRABUS
02-19-2011, 10:06 AM #112
Thanks
The power cable is 60mm2, i guess it wil work.
But i dont know if it would knock out the 250A auto Fuse..
BRABUS
Thanks
s123
02-19-2011, 10:13 AM #113
Spent to much time on Facebook, found my self looking for the 'Like' button..... Hey I like this!!
This post was last modified: 02-19-2011, 10:15 AM by s123.
s123
BRABUS
02-19-2011, 02:58 PM #114
Worked with the header som hours today.
But once again i used all the bends, i hope my dealer have received the last ones i ordered by monday.
All runners are 62cm +-2-3mm. Now only need bends to finnish cyl3,wastegate,egt bung and collector. Then my welder can weld it all togheter Smile
Here are some pics
[Image: 4c640a45-9321-4078-bbc2-22a0878e539a.jpg]
[Image: db5171a0-68d3-4c71-8ed4-0f9713eb46c7.jpg]
[Image: f7293baa-dbfa-4db4-b4bb-613f48f8bdd5.jpg]
BRABUS
Here are some pics
mike-81-240d
more like mike-84-300d now
427
02-19-2011, 06:26 PM #115
How did you go about mounting the driving/ fog lights to the front bumper? Did you drill directly into the bumper, or make a bar type thing? Heart
Oh boy I hope you went with 3000, 4300, or 5000k bulbs. Big Grin
mike-81-240d
BRABUS
02-19-2011, 06:42 PM #116
The lights is mounted on a plate/bracket thats is between the bumper and the license plate. With only 2 bolts to hold the lincense plate/ lights. Off course the lights are 4300k.
BRABUS
ID240D
02-19-2011, 08:11 PM #117
Great work can't wait to see the finished product
1983 300D 246,000 with lots of goodies (Sasha)
1980 300TD 200K Third row seat
We live in a world that goes faster every day and it seems there's a lack of time for each one of us
ID240D
dieselboy
Rotatin 5500 times a minute
680
02-20-2011, 03:00 AM #118
It's a pita making a header for a 5cyl huh? I'm curious as to what you are doing for the collector. I was making a header for my t5 Volvo but that's being put off for awhile.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
BRABUS
02-20-2011, 05:33 AM #119
Thanks.
First time making a collector for 5cyl, so i thougt it maybe would be a challenge.
But will see when i start at it tommorrow, i have dreamed about it last night how i should make it Smile hahaha
This post was last modified: 02-20-2011, 05:34 AM by BRABUS.
BRABUS
Thanks.
02-20-2011, 07:59 AM #120
(02-20-2011, 05:33 AM)BRABUS Thanks.
I had thoughts of having the fifth pipe come up the middle. But I assume space and pipe material limitations is hindering that idea.
Again looking good and an inspiration to others looking to build a custom header. Can't wait to see it completed!
dieselboy
680
02-20-2011, 11:24 AM #121
From what I've seen is people will do a 6-1 collector then use #6 for the waste gate.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
BRABUS
02-20-2011, 03:38 PM #122
Dieselboy. That wont work so good on this setup. because collector will be for twin entry.
5cyl will go inn between cyl 1 and 2.
Give me some days and i will show you how its turns out..
BRABUS
BRABUS
02-21-2011, 04:44 PM #123
Modified the header today. The turbo now sits lower and i a better position than before.
But i need to lift the engine 12" to remove or install the header Smile
[Image: f466c382-abe2-4ea4-aa37-6ecb3616c1ee.jpg]
[Image: 591c2490-2ff1-40ef-a277-021c73cadf1e.jpg]
BRABUS
02-21-2011, 05:11 PM #124
HE351VE? Also, how do those spring LSD clutches work out?
This post was last modified: 02-21-2011, 05:14 PM by winmutt.
BRABUS
02-21-2011, 05:15 PM #125
HX40G OR HX40S dont remember Smile with exhaust housing 13.
BRABUS
BRABUS
02-22-2011, 04:40 PM #126
The header is almost finished, i need to get my welder to tig weld it. Then i will make the pipes for the wastegate and mount a bung for manifold pressure and egt.
[Image: 472f00ab-2765-48ac-91e1-b8f4c5cafbcb.jpg]
[Image: 8f898e84-c5d6-41bd-9eed-b42564637213.jpg]
BRABUS
02-22-2011, 05:19 PM #127
I wish we had a smiley face that was drooling.
Those headers are bitchin.
I cant wait to possibly listen to this thing run!
Videos when finished pleassseeee
02-23-2011, 01:29 PM #128
Divided turbo flange? 5 Cylinder?
BRABUS
02-23-2011, 03:34 PM #129
Yes. divided 5cyl
BRABUS
Yes. divided 5cyl
02-23-2011, 05:42 PM #130
I guess that wont hurt anything, just kind of odd? Is that turbo divided as well?
BRABUS
02-24-2011, 12:20 AM #131
yes the turbo is divided also. maybe odd. but it works!
BRABUS
BRABUS
03-05-2011, 10:13 PM #132
Me and 4 buddies are currently moving to a new garage. We have drove 2 times with big semies full of parts,engines,tires and tools. And also moved all 13 cars and the dragster we had in the old garage.
We also have to make new wiring to the lights and heaters in the new garage, also try to get the ice/water out of the garage and seal the wall where it meets the concrete.
So there will be some weeks until i get to weld together the header, and continue with this car.
But i have received some new parts and waiting for moreSmile
Also installed this : Smile
[Image: 5caa120d-392e-470e-acdf-72141793e8b7.jpg]
BRABUS
George3soccer
03-06-2011, 02:52 PM #133
Please let me know how you got that rpm tach wired up.
Mb 1984 w201 om603 swap.
Mb 1986 w201 190E 2.3-16v
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
BRABUS
03-06-2011, 03:55 PM #134
Welded a wire on one of the three stator pins inside the alternator. The gauge is meant for alternator signal But the alternator on my car had a very small pulley/wheel. So i can calibrate it all the war down to where its should be in the rpm range. Gonna find another pulley and see how it works.
BRABUS
04-01-2011, 12:23 PM #135
Hope your move goes well!
BRABUS
04-01-2011, 05:22 PM #136
almost done moving. But now i also started on my apartment. New kitchen and bathroom and so on Smile
But i my welder has started on the manifold, so there will be updates soonSmile
BRABUS
BRABUS
04-07-2011, 04:10 PM #137
Exhaust manifold welded. execept the wastegate runners.
The final position of the turbo Smile
[Image: 9e4e6f8f-51e4-4c86-9f31-aa912e2acc3f.jpg]
Here is a video of start up. without turbo
[Image: th_36481208-c07c-4b77-b35c-52f0f485b4c5.jpg]
Here i have tacked the pipes to the wastegateSmile The last wastegate pipe will be cut and the wastegate will be mounted 2" nearer the front of the car.
[Image: e6d75bae-e0d2-4495-90af-f241b32009bb.jpg]
[Image: e48f75e3-8c21-4291-b1c8-30ad8a266f31.jpg]
BRABUS
BRABUS
04-08-2011, 05:38 PM #138
exhaust manifold DONE!
[Image: 5edb87c3-32e2-402d-8eaa-87ec9e0b7aac.jpg]
[Image: 596eb971-c19d-4721-b8f1-2863676aae42.jpg]
BRABUS
04-08-2011, 06:04 PM #139
unreal Big Grin
unreal Big Grin
04-08-2011, 07:23 PM #140
How dose that waste gate work?
04-08-2011, 07:27 PM #141
Id like more info about the wastegate too.
dieselboy
680
04-08-2011, 08:16 PM #142
It's just an external gate. A huge external gate.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
BRABUS
04-09-2011, 09:36 AM #143
Done!
Only need to wrap the downpipe now.
[Image: c774c2bd-e142-4173-a75b-0a8deff2c2e6.jpg]
[Image: 9c357045-6535-4df4-b46a-047385681265.jpg]
[Image: th_3beab7d5-07a5-4844-a448-b131db4e6567.jpg]
BRABUS
Done!
mike-81-240d
427
04-09-2011, 10:03 AM #144
(04-09-2011, 09:36 AM)BRABUS Done!
Is it just headers/downpipe in the video, or is the exhaust hooked up?
mike-81-240d
BRABUS
04-09-2011, 10:51 AM #145
Only downpipe on the video
BRABUS
04-09-2011, 11:34 AM #146
Where dose the waste gate hook back in to the exhaust? I can see that it relives both sides of the divided exhaust housing but it has to dump back in the the exhaust some where?
George3soccer
04-09-2011, 04:03 PM #147
Unless the wastegate has its own downpipe.
Sounds amazing bro.
Mb 2004 w203 C230k
George3soccer
Sounds amazing bro.
Mb 2004 w203 C230k
BRABUS
04-09-2011, 05:45 PM #148
Wastgate has its own downpipe also called SCREAMER pipeSmile
BRABUS
dieselboy
680
04-09-2011, 06:44 PM #149
Sounds great!!
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
Sounds great!!
-Jesse
70 f250 390
66 Volvo amazon
04-09-2011, 07:26 PM #150
^^^ditto^^^
^^^ditto^^^
 3 Guest(s)
 3 Guest(s)
