STD Tuning Drivetrain 5 Spd for 80 300D in a 300CD
Oil Burner
Turbo Everyting!!!
83
10-21-2010, 05:08 PM #1
I have been reading all the threads in this section and there is allot of information but I am confused...you guys like the numbers and abreviations. Huh
Can I get a few questions awnsered.
1. Is there a 5 spd Man Trans with OD that will bolt to a 83 300D
2. What do you do for the Pedal assembly? Conversion or buy erupean parts?
4. Has anyone actually accomplished this conversion if you have what did it take: parts and cost.
Thanks you guys, you know your MB stuff I will give you that
This post was last modified: 10-27-2010, 08:58 AM by winmutt.
Oil Burner
10-21-2010, 06:50 PM #2
(10-21-2010, 05:08 PM)Oil Burner 1. Is there a 5 spd Man Trans with OD that will bolt to a 83 300D
Yes, an extremely rare one. All that exist in the USA came as part of a complete vehicle that was a special import.
Quote:2. What do you do for the Pedal assembly? Conversion or buy erupean parts?
Any pedal assembly from a 240D.
Quote:4. Has anyone actually accomplished this conversion if you have what did it take: parts and cost.
Conversion is easy, same as doing a 4-speed but cutting the driveshaft a few inches shorter and using a different support crossmember.
This post was last modified: 10-21-2010, 06:53 PM by ForcedInduction.
10-25-2010, 11:08 AM #3
89 300d?
89 300d?
Oil Burner
Turbo Everyting!!!
83
10-25-2010, 08:31 PM #4
(10-25-2010, 11:08 AM)winmutt 89 300d?
Meant 1980 300CD
Oil Burner
Meant 1980 300CD
