STD Tuning Engine OM613 OM648 OM628 & 629
diesel2fast4u
11-03-2010, 01:27 AM #1
Hi, I know that this is mayby not the right forum but I cannot find anything about these engines.
OM613 & 648 I6 CDI's : How are the internals of these engines? Comparable to 606 or weaker?
OM628 & 629 V8 cdi's : Anybody saw what these engines look like inside?
Thanks,
Raf
Grand cherokee WK (OM642)
diesel2fast4u
Thanks,
Raf
11-03-2010, 01:58 AM #2
(11-03-2010, 01:27 AM)diesel2fast4u OM613 & 648 I6 CDI's : How are the internals of these engines? Comparable to 606 or weaker?
The last good diesels Mercedes designed. Basically identical except for an electronic turbo and piezo injectors on the 648
Quote:OM628 & 629 V8 cdi's : Anybody saw what these engines look like inside?
Not as good as the I6, but not designed around emissions/cost like the V6.
The 629 has piezo injectors.
The Finns are scared of them because they aren't as cheap, they need electronics and they don't revv to insane RPMs like the IDI engines.
HoleshotHolset
11-03-2010, 07:00 AM #3
(11-03-2010, 01:58 AM)ForcedInduction The Finns are scared of them because they aren't as cheap, they need electronics and they don't revv to insane RPMs like the IDI engines.
Are they RPM limited because they're common-rail DI's, or because they're electronically limited (with the OEM ECM/calibration) to x,xxx RPM?
'07 W211 OM642
HoleshotHolset
'07 W211 OM642
11-03-2010, 09:34 AM #4
Because they're direct injection.
HoleshotHolset
11-03-2010, 10:31 AM #5
(11-03-2010, 09:34 AM)ForcedInduction Because they're direct injection.
OK. Why is that a limiting factor? I'm not trying to be a snot, just curious since I've seen plenty of DI's rev to 5-6k RPM.
'07 W211 OM642
HoleshotHolset
'07 W211 OM642
diesel2fast4u
11-03-2010, 01:26 PM #6
LOL I wouldn't say Finns are scared of anything... I think they are the benz tuners by far untill somebody proves otherwise.
I don't see alot of high HP CDI engines.
I can find OM606 here compleet for 2500 usd, OM613, 3500 usd and V8 OM628 for 4500 usd ...
Why is the V8 weaker? just engine design or weaker rods, crank?
It's true that the electronics are harder to figure out but on the other hand it's going to be easy to control smoke, torque & VGT/VNT
Thanks,
Raf
diesel2fast4u
Thanks,
Raf
HoleshotHolset
11-03-2010, 01:35 PM #7
I6's have 7 main bearings and each conrod has its own crankshaft throw and conrod bearing. This layout is very, very strong...and still smooth as glass with the crank throws (and therefore the combustion events) offset at 120° angles.
Even fire Vee configuration engines often share crankshaft throws - so there's two conrods per throw and fewer main bearings.
'07 W211 OM642
HoleshotHolset
'07 W211 OM642
jeemu
457
11-03-2010, 03:51 PM #8
(11-03-2010, 01:27 AM)diesel2fast4u Hi, I know that this is mayby not the right forum but I cannot find anything about these engines.
Thanks,
Raf
Friend has OM629 on his car. 400hp/900nm pretty fun daily driver.
jeemu
Thanks,
Raf
11-03-2010, 06:50 PM #9
(11-03-2010, 03:51 PM)jeemu
Thanks,
Raf
Pictures pleeeassseee
Video!! pleeeeeaaaassssssseeee!!
Thanks,
Raf
jeemu
457
11-06-2010, 06:14 PM #10
(11-03-2010, 06:50 PM)garage
Thanks,
Raf
Not photos or vid for now.
But we are scared of those because those cost too much and dont rev high Big Grin
jeemu
Thanks,
Raf
JTY
11-10-2010, 04:39 AM #11
We finnss are not scared of anything Cool
Few high HP CDI's cooking around, maybe some photos next year Tongue
- MB r129 500SL AMG (JDM) -94
- MB w123 250E-TT (JDM) -85
JTY
blackslide
09-10-2012, 07:32 AM #12
Got a spare S210 chassis + OM613 + 722.626, waiting for a tuneup. But I'm beginning to lean on the side of a OM648 + 722.90x.
A) Rail pressure on OM648 is 1600bar, probably can take even a few hundred more (higher rail pressure probably partially contributes to finer fuel dispersion)
B) 722.90x gearboxes are newer (Generally less mileage), and are running at about the same pricetag
C) The chassis needs some work, so I might use it for something else, and get a totally different chassis for a project
At least I'm very positive about the changes CDI engines have brought to the diesel world.
(I have prior been a "Gasoline junkie", now heavily transforming to "Dieselmania")
blackslide
gstardiag
08-09-2016, 10:06 PM #13
Some years has goneSmile
What are modern thoughts about om613 /om642 ?
My regards
gstardiag
My regards
bqik
08-15-2016, 04:05 PM #14
(08-09-2016, 10:06 PM)gstardiag Some years has goneSmile
My regards
om642 or om648?
www.blacksmokeracing.com
Smile
bqik
My regards
om642 or om648?
Smile
blackslide
11-13-2016, 06:43 AM #15
My regards
OM613/OM48 haven't changed. Still the best diesels around. OM642 is a much inferior V-6 design. Partly for the inherent weakness in the layout, partly because it has been designed with cost reductions in mind.
The V8 CDIs have a totally different ECU from the rest. The software is encrypted, etc. thus making it a worse base for tuning. Someone could get into it, for money..
blackslide
My regards
starynovy
11-13-2016, 08:05 AM #16
628 has this TEMIC ECU which is not documented as BOSCH EDC ECUs.. it is definitely hard to tune propertly, stupid shit tune is easy to do on this but.. Big Grin
starynovy
