STD Tuning Engine Software-Computational fluid dynamic/thermodynamic
Silberpfeil
Slowly Sideways
85
01-17-2011, 01:07 PM #1
I need a recommendation for professional level (top of the line-PC based) computational fluid dynamic/thermodynamic software. This would be used to design custom turbo/intake and exhaust systems. Also possibly used for internal engine modification but primarily for intake and exhaust.
Silberpfeil
ConnClark
01-17-2011, 07:30 PM #2
(01-17-2011, 01:07 PM)Silberpfeil I need a recommendation for professional level (top of the line-PC based) computational fluid dynamic/thermodynamic software. This would be used to design custom turbo/intake and exhaust systems. Also possibly used for internal engine modification but primarily for intake and exhaust.
I take it your new to this field. Be prepared for a steep learning curve.
expensive option http://www.ansys.com/ (masters degree helpful)
cheap option http://www.openfoam.com/ (phd helpful)
You'll also want some serious computer hardware. (Maybe more than one machine in a cluster)
ConnClark
300D50
Graphite Moderator, ala RBMK
01-17-2011, 11:59 PM #3
Oooh! OpenFOAM looks awesome!
Time to see if my hunch about it taking 3D wireframes/solids is correct... Smile
300D50
Spaceraver
01-18-2011, 04:28 AM #4
Solidworks does do CFD http://www.solidworks.com/sw/products/cf...ftware.htm
If you can get your hands on the Premium package it can do almost anything
I wouldn't mind getting an STD..Tongue
Spaceraver
300D50
01-18-2011, 04:34 AM #5
I've got solidworks with COSMO at the college, need to bug my brother on how to use sw though... I'm Inventor, he's SW, leads to some interesting dynamics when we try to share ideas, haha.
300D50
ConnClark
01-18-2011, 01:53 PM #6
The problem with doing CFD simulation is you often have to calibrate the conditions of your simulation to a known test verified in a wind tunnel to make sure what your getting out is sane. Its often far more than setting up a case and just hitting the run button.
Edit: Also setting up a good mesh before hand is critical to getting good results
This post was last modified: 01-18-2011, 01:54 PM by ConnClark.
ConnClark
Robert_UAH
01-18-2011, 04:43 PM #7
Open Foam is a serious pain in the a$$. It seems to be mainly for research to me. Solidworks will do internal flow if you get the right package. I am working on getting CFDesign software for my FSAE team.
Robert_UAH
ConnClark
01-19-2011, 08:15 PM #8
Yes OpenFoam is a pain in the ass. But you can do far more with it than you'll ever be able to do with solidworks.
ConnClark
mcneil
01-19-2011, 09:30 PM #9
ConnClark is being too nice to you guys about using CFD in a amateur/semi-pro project.
Most of those solvers require the user to make significant assumptions about the boundary layer properties, the more accurate of which require good knowledge of the gas properties.
But with combustion products, you're going to be lucky if you guess the viscosity within an order of magnitude. Then there's viscosity temperature dependence.. I have no idea how you'd measure this property, but I would expect it to be a significant factor since you're dropping a couple hundred degrees from the turbine exit to the exhaust tip.
There's some literature out there published either by CFD software makers or some university researchers about the accuracy of CFD in predicting friction drag losses in internal flows. I've seen some good papers done by Fluent on properties of combustion products, but they were all gas not diesel. Maybe you could use them as a starting point and then calibrate.. yeah, um.. I'm not really going anywhere with this.
My point is that you'll spend more time determining gas properties and adjusting boundary layer models in an attempt to get a non-absurd solution than you will spend designing the piping. Check my reasoning with a pipe loss hand calc. Start with 10 feet of 3" straight pipe and see what 3 or 4 bends do to head loss and pumping power.
This post was last modified: 01-19-2011, 09:31 PM by mcneil.
1983 300SD - 350k miles, disassembled for a head R&R
2010 Golf TDI - The wife's car
mcneil
300D50
01-20-2011, 02:07 AM #10
So far, I like it.
I'll start messing with more this weekend.
300D50
So far, I like it.
