STD Other Projects Norwegian W123 240D with 245 hp
  • 1 Vote(s) - 5 Average
Einar
01-21-2011, 05:54 AM #1
[Image: kr%e5b%f8l4.jpg]
[Image: 05_01_0.JPEG]
Turbo pressure 2.5 bar, 245 hp and 397 Nm
Differential from w116 280S, transmission from som 7-series BMW, lowered compression ratio, turbo fram scania DS9, double IC from Fiat(welded together), modified dieselpump, oilinjectors for piston cooling, waterinjection.
Einar
Jtn190D
MERCEDES DIESEL POWER!
192
01-21-2011, 08:52 AM #2
(01-21-2011, 08:08 AM)OM617a I'll believe the dyno.
Not that I believe it but how do you know that number isn't a dyno number?
Jtn190D
dieselboy
Rotatin 5500 times a minute
680
01-21-2011, 11:49 AM #3
Hater!!
.5 liter short of our cars modified damn good and you don't belive it?
Lower compression, 40psi of boost, etc... Sounds about right to me.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
Hater!!
-Jesse
70 f250 390
66 Volvo amazon
bonden_85
01-21-2011, 01:38 PM #4
The text says 245hk and 397Nm dyno'd on crank
It also says:
Manual gearbox from BMW 7-series
Rear axle from w116
Turbo from a 9-litre Scania engine
bonden_85
It also says:
Rear axle from w116
casioqv
OM602 Turbo
116
01-21-2011, 01:42 PM #5
Wow, this is impressive! I've always thought the OM616 would be a cool engine to build up.
Thanks for the translation Bonden Smile
This post was last modified: 01-21-2011, 01:43 PM by casioqv.
-Tyler
No mercedes (for now)
casioqv
-Tyler
dude99
01-21-2011, 02:36 PM #6
how did he fit the intercooler in there? Is the Rad moved back?
dude99
jeemu
457
01-21-2011, 03:52 PM #7
That is nice, but 100hp more is better Smile
jeemu
muuris
OM605
318
01-21-2011, 04:34 PM #8
(01-21-2011, 09:07 AM)OM617a Because I haven't seen a dyno graph. Like any figure, its open to exaggeration or interpretation.
If its "at the crank", take away 35% from the quoted number for drivetrain losses and you have a far more realistic 157hp.
Hello Forced,
I can draw you a dyno graph. What's so unbelievable about 100hp/l in old diesel, almost any engine can do that with just big turbo and fueling.
You calculated drivetrain losses two times and use such a huge factor for rwd? If it was at the crank, the losses have already been calculated. If it wasn't, you should use a factor closer to 15% for normal manual transmission rwd.
They are 35% in rwd car only for Yankee (muscle) cars Big Grin
muuris
Hello Forced,
jeemu
457
01-21-2011, 04:52 PM #9
(01-21-2011, 04:34 PM)muuris They are 35% in rwd car only for Yankee (muscle) cars Big Grin
If we used same factor here would be almost 1000hp diesel Mercedes Big Grin
jeemu
01-21-2011, 05:24 PM #10
I love my Yankee!
I love my Yankee!
jeemu
457
01-21-2011, 05:51 PM #11
(01-21-2011, 05:34 PM)OM617a
(01-21-2011, 04:34 PM)muuris You calculated drivetrain losses two times and use such a huge factor for rwd?
Because thats what it actually is.
Stock; 125hp, 87whp= 30%
Mine 165hp, 115whp= 30%
Okay, I'll happily admit I was 5% off.
So i have over 700hp on my om605 Cool
jeemu
01-21-2011, 08:22 PM #12
Thats bad ass!
Is the tranny a 5speed or a 6speed?
I sure wish i could read that article in english! What magazine is that??
Thats bad ass!
dieselboy
680
01-21-2011, 08:57 PM #13
Ahahaha.
Mr Smartass in cryarado is butthurt.. I have my name in my sig. Your just scared because your a troll and from what I've researched have pissed of alot of people. Don't be surprised if you get gearboxed.
This post was last modified: 01-25-2011, 03:06 AM by dieselboy.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
Ahahaha.
-Jesse
70 f250 390
66 Volvo amazon
muuris
OM605
318
01-22-2011, 01:46 AM #14
(01-21-2011, 05:34 PM)OM617a Because thats what it actually is.
Next you'll tell us a 4wd has 70% losses, right?
I had 360hp at the wheels with the previous 7mm pump, that would make over 500hp at crank. Dyno showed my car had about 10% losses which correlates to about 400hp. Car has been weighed and quarter mile end speed correlates nicely to the 400hp.
You know, drivetrain losses aren't a solid factor. They can be big even in fwd car if the joints are bust, wheel alignment isn't correct, the car is heavily pushed against dyno (for better grip) etc. That's why the losses are measured, not just thrown 30%. That's only for the muscle cars, so they wouldn't be disappointed to the dyno results.
This post was last modified: 01-25-2011, 09:47 AM by winmutt.
muuris
bonden_85
01-22-2011, 04:03 AM #15
(01-21-2011, 08:22 PM)garage Thats bad ass!
In the bottom left corner of the pic it says:
"Norsk-Motorveteran"
There isn't that much interesting stuff in the text, they're telling a short story about that car appearing at some 1/4 mile race where it turned some heads Big Grin
bonden_85
01-22-2011, 02:05 PM #16
I worked on a an 07 Miata it dynod at 140 RWHP we dismantled the trans and rear diff and sent out all of the gears and bearing for friction reducing coating's when reassembled with synthetic racing fluids it made 180 RWHP
Drive train loss is more dependent on what is done and what fluids are used! on hot rod magazine TV a few years back they took a Challenger and replaced all of the drive train fluids with synthetic and picked up 20hp on there dyno
As for every one who doesn't like what F.I. has to say ignore what he says stop feeding the flames please!
This post was last modified: 01-22-2011, 02:09 PM by willbhere4u.
OM616
10mm MW
572
01-22-2011, 04:45 PM #17
Anyone know what the tube with a muffler looking thing at the end by the battery is?
I mean what’s the thing that is on the passenger finder?
OM616
Einar
01-22-2011, 05:05 PM #18
I wondered too, maybe a old airfilter like the G?
Einar
01-23-2011, 10:57 AM #19
Quote:Don't be surprised if you get gearboxed.
And what exactly would that prove? That somebody is stupid enough to get within range of a 12ga? Yeah, go for it. At the least I can get a few bucks at RMR for it.
(01-22-2011, 01:46 AM)muuris Next you'll tell us a 4wd has 70% losses, right?
No, 4wd is closer to 40% depending on the tire type.
Quote:Dyno showed my car had about 10% losses
Please, show us your engine dyno compered to your chassis dyno.
Quote:How much heat will your transmission and final drive produce?
The fact that the transmission requires a cooler should suggest it produces quite a bit of heat, especially the torque converter. The diff is easily air cooled since its at its highest heat production at highway speeds, though some have integral fins on the back cover for added cooling.
yankneck696
395
01-29-2011, 08:13 AM #20
Back on subject...
I personally think 245HP out of a 616 engine is surely possible. Do all the right stuff (nitrided crank, ARPs everywhere, maybe custom rods, ceramic everywhere, squirters, elements & injectors, a bit of lightening of the rotating assembly, big/compound turbos, custom intake & exhaust manifolds, intercooler, custom pistons, prechamber mods, etc...) & it should survive. OK, on the 400HPvideo we have all seen, that comes out to 133.33333333... HP per liter. a 616 engine at that power would be 320HP. So, with all of the above, I think he can do more boost & fuel to get more HP than what is in the article without grenading. The math is simple & irrefutible.
We don't even know if it might be a billet crank/rods. To just say "Impossible" is wrong.
As an example, http://turbobyholset.com/gregs-ford-mustang-svo-dyno/
1986 Ford Mustang SVO 2.3L 4 cylinder 8 valve iron block/head, Holset HX35W turbo, ported head, custom turbo manifold, custom Spearco intercooler. Running 22psi, 290rwhp/322rwtq (on a mustang dyno).
If a gas engine of the same vintage can do it WITH the torque numbers there, surely a well modded 2.4 liter Diesel can do it.
Ed
yankneck696
Back on subject...
Ed
01-29-2011, 08:43 AM #21
(01-29-2011, 08:13 AM)yankneck696 If a gas engine of the same vintage can do it WITH the torque numbers there, surely a well modded 2.4 liter Diesel can do it.
No, the two engines are not even remotely related.
G@s engines produce significantly more HP/L due to their ability to revv very high which reduces the torque needed to produce the number.
This post was last modified: 01-29-2011, 08:43 AM by ForcedInduction.
01-29-2011, 08:47 AM #22
(01-29-2011, 08:43 AM)ForcedInduction
Funny, I thought it was the flame front of gas over diesel that allowed for more HP/L even though diesel has more energy per unit.
yankneck696
395
01-29-2011, 08:50 AM #23
<<No, the two engines are not even remotely related.
G@s engines produce significantly more HP/L due to their ability to revv very high which reduces the torque needed to produce the number.>>
Would it be possible (with billet crank, rods & a gun drilled cam) thereby reducing reciprocating massthat the 240 engine can rev a bit higher than usual?
What about the simple math of HP per liter? I would like to hear your opinion about that. How come the 3.0 can do 133 per liter before grenading & the 2.4 cannot do aproximately 100 HP per liter? It is actually safer than the exploded engine.
Ed
yankneck696
Ed
01-29-2011, 09:31 AM #24
(01-29-2011, 08:47 AM)winmutt Funny, I thought it was the flame front of gas over diesel that allowed for more HP/L even though diesel has more energy per unit.
Gas engines have lower energy in their combustion, thats why they need more of them (RPM) to make power since horsepower is just a representative math number for torque over time.
Quote:Would it be possible (with billet crank, rods & a gun drilled cam) thereby reducing reciprocating massthat the 240 engine can rev a bit higher than usual?
Mass isn't the problem, its piston velocity. If you want to revv high you need to reduce the stroke. Thats why torque monster engines like the Cummins 5.9 have a low RPM, it has a stroke 17% larger than the bore diameter (oversquare) compared to a 61x's 1.7%. Or a Cummins ISX that revvs out at 2500rpm, 23% oversquare. Or the Wärtsilä-Sulzer RTA96-C (worlds largest engine) that revvs out at 102rpm, 60% oversquare.
Comparatively, the Honda S2000 has a 5% shorter stroke than the bore diameter (undersquare) and the Kawasaki Ninja 400R has a 33% shorter stroke which allows them to revv very high. In contrast to the Wärtsilä-Sulzer, an F1 engine can revv to 21,000rpm, they're 47% undersquare.
I think thats enough examples.....
Here is a piston speed calculator.
http://www.csgnetwork.com/pistonspeedcalc.html
Note that a 5.9 Cummins at its 3200rpm redline and a 15.0L Cummins ISX at 2500rpm have nearly the same piston speed as a 61x at 4800rpm! (14meters per second)
Quote:What about the simple math of HP per liter? I would like to hear your opinion about that.
For similar engine types its a decent gauge of relative performance. When you get into extremes like comparing a Cummins to a Kawasaki though, it gets a bit "unscientific". Big Grin
Quote:How come the 3.0 can do 133 per liter before grenading & the 2.4 cannot do aproximately 100 HP per liter?
Displacement is not the issue. The 616 is not strong internally like the 617a.
Given how much MB beefed up the 617a, I'm surprised the 616 even made it to 100hp/l without bending a rod or breaking the crank.
This post was last modified: 01-29-2011, 09:44 AM by ForcedInduction.
yankneck696
Build it so strong &amp; blow it up good !!!
395
01-29-2011, 09:48 AM #25
<<For similar engine types its a decent gauge of relative performance. When you get into extremes like comparing a Cummins to a Kawasaki though, it gets a bit "unscientific".>>
I am comparing a 240 to a 300. No cummins or ricers.
<<Displacement is not the issue. The 616 is not strong internally like the 617a.>>
Again, with a nitrided or billet crank, billet rods, ARPs everywhere, it would be as strong, or possibly stronger. Am I correct on that? Common sense would say so.
<<Mass isn't the problem, its piston velocity. If you want to revv high you need to reduce the stroke.>>
The 3.0 & 2.4 do have the same stroke, right? Also, when it comes to getting RPMs, the drag racers lighten up all of the reciprocating assembly to gain RPMs, right? It also frees up horsepower/torque as the combustion does not have to rotate the extra mass.
Ed
This post was last modified: 01-29-2011, 09:52 AM by yankneck696.
yankneck696
Ed
01-30-2011, 10:55 PM #26
(01-29-2011, 09:48 AM)yankneck696 Again, with a nitrided or billet crank, billet rods, ARPs everywhere, it would be as strong, or possibly stronger. Am I correct on that? Common sense would say so.
Yes but such extreme would be completely pointless since you could get a stock 617a for the cost of ARP studs alone.
Quote:The 3.0 & 2.4 do have the same stroke, right? Also, when it comes to getting RPMs, the drag racers lighten up all of the reciprocating assembly to gain RPMs, right?
No. Lightening mass only reduces internal power consumption and allows it to revv to maximum speed quicker, RPM is still limited by the flame front speed (piston velocity).
This post was last modified: 01-30-2011, 10:57 PM by ForcedInduction.
yankneck696
395
01-31-2011, 06:38 AM #27
(01-30-2011, 10:55 PM)ForcedInduction
People have done crazier things for less reason.
I thought it was the stroke as bore... Now, I'm confused
yankneck696
01-31-2011, 09:01 AM #28
Stroke is what determines piston speed, flame front velocity is what determines maximum rpm no matter the stroke.
That why Finns like Jeemu can't get any more power above 6000-someodd rpm, combustion can't keep up. The only option to go higher is to make "anti-stroker" crank and rods.
This post was last modified: 01-31-2011, 09:03 AM by ForcedInduction.
