STD Tuning Engine Prechamber Mod "Flame" Front
  • 6 Vote(s) - 4.33 Average
Pages (8): Previous 1 2 3 4 5 6 8 Next
dieselboy
Rotatin 5500 times a minute
680
02-05-2011, 06:29 PM #151
Tell you guys what. I have a dyno date in march. I'll take my spares and mod them ad see if I can do a before and after without touching the pump.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
02-05-2011, 06:38 PM #152
(02-05-2011, 05:49 PM)Volker407 So you say prechamber atomization is better altough common rail has higher injection pressure (3-4 times higher than our OM61Xs got) and can superheat through pre-injections
Yes. IDI injects and vaporizes all the fuel at the same time. Common rail still has separate injections which means the fuel still has less time "in heat".
This post was last modified: 02-10-2011, 05:02 PM by winmutt.
jeemu
457
02-05-2011, 07:31 PM #153
Om616. If you need some information, shoot at pm.
Big holes= big power Cool
jeemu
led-panzer
02-05-2011, 07:32 PM #154
I don't know what you think being a martyr is going to solve. It would seem jeemu could solve this whole argument by posting a dyno before and a dyno after the mods.
1985 300D 280,000 miles RIP
led-panzer
02-06-2011, 09:12 AM #155
(02-05-2011, 11:18 AM)OM616 Implying that the members that posted information that you disagree with are liars is nothing but confrontational. If we can not trust what a member says, then what is the point. I mean heck, anyone that has any skill with a graphics program can create a dyno sheet that supports anything.
I say enough. Statements that contradict solely for the sake of contradiction are aggressive, and deter members from posting. Unless you have something relevant to "CONTRIBUTE" to a thread, don't.
While this is very true, I recommend everyone stay on topic here.
What I think would prove to be beneficial here is some simple testing. Why doesn't someone rig up a testing station? Lets stop talking theoretical and half assed tests, lets start talking scientific experimentation. I would think a pop tester rigged with some prechambers that are mounted into a jar that is similar in size to that of a piston would provide some interesting results. Video record the differences.
This would be a real contribution that would far surpass anything that has been contributed in this thread so far. Jeemu has more power without fully knowing whats going on. I have a half cocked theory that more holes would be better. Forced thinks its a bad idea period.
Less talk more walk here people. The point of this board is to do more than the others.
This post was last modified: 02-06-2011, 09:15 AM by winmutt.
02-06-2011, 10:15 AM #156
Joking, but I wonder sometimes if the "Flame Front" refers to the "flaming" going on in this thread?
DieselSchlepper
02-06-2011, 12:48 PM #157
I would Rig up the injector, pop tester, prechamber, and a glow plug get the plug hot and inject the fuel use a slow motion camera and see if there is any noticeable difference with the burn time between the two prechamber? just stand back lol
tomnik
02-06-2011, 02:19 PM #158
without an air temperature of ?? > 200-400deg C ?? in the jar you won't see fire...
Tom
tomnik
Tom
erling66
SuperDieselVan
294
02-06-2011, 03:05 PM #159
Not trying to be "negative", bu I can't see how this test will provide any useful information. You will need to create the same conditions you have during compression and combustion. The only way to do that(for people with normal equipment) is to use an engine in a car. If you don't have access to a dyno, you can do a road test.
I normally use the same uphill, try to test during same temperature and humidity. and for example use third gear and time acceleration from 2000-5000rpm with WOT. Not perfect but it will tell you if the engine has more power.
I hope someone will do that(I can't, we have ice on the roads now) and tell us about it. We will take your word for it(well most of usSmile ) when you tell us if it helped or not
erling66
02-06-2011, 11:08 PM #160
(02-06-2011, 03:05 PM)erling66 Not trying to be "negative", bu I can't see how this test will provide any useful information.
If you were testing for flame front yes. I think just seeing how the fuel mists and is dispersed would be very interesting. I believe that FI is right about Jeemu's bigger holes, that Jeemu is wasting fuel as it is being sprayed on the piston and walls and not misting in the middle. There is no doubt in my mind he is seeing more power from more fuel but I think more holes are the solution not bigger ones.
Somewhere I read a detailed thread/doc on the injectors, the angle of injection, the rotation of the pintles etc and the specific reasons they were changed. One of the items the thread/doc impressed was that fuel on the cylinder walls and piston head is essentially wasted. Even without firing the fuel in my suggested test you should be able to clearly see the difference. A simple example of my idea is the garden hose sprayer. One jet, lots of pressure. 6 jets, a shower. 32 jets, a fine mist. We definetely want a fine mist.
An additional problem to my idea is the physical integrity of the pc itself, which is where Jeemu's solution *might* be the only correct one.
If I had a pop tester this video would already be shot Big Grin
This post was last modified: 02-06-2011, 11:08 PM by winmutt.
02-07-2011, 04:32 AM #161
(02-06-2011, 09:12 AM)winmutt What I think would prove to be beneficial here is some simple testing. Why doesn't someone rig up a testing station? Lets stop talking theoretical and half assed tests, lets start talking scientific experimentation. I would think a pop tester rigged with some prechambers that are mounted into a jar that is similar in size to that of a piston would provide some interesting results. Video record the differences.
That wouldn't show anything useful since there is no combustion, or even airflow. You would also have to pump 37 stokes/second to simulate 4500rpm.
(02-06-2011, 10:15 AM)DieselSchlepper Joking, but I wonder sometimes if the "Flame" Front refers to the "flaming" going on in this thread?
Yeah. I thought that was pretty obvious given the person who typed it.
jonbobshinigin
02-07-2011, 11:27 AM #162
(02-05-2011, 06:29 PM)dieselboy Tell you guys what. I have a dyno date in march. I'll take my spares and mod them ad see if I can do a before and after without touching the pump.
This sounds good :-) At least seems to be the most conclusive thing thusfar!
1987 300TDT - 260,000 Miles
jonbobshinigin
casioqv
OM602 Turbo
116
02-07-2011, 12:28 PM #163
(02-05-2011, 06:29 PM)dieselboy I have a dyno date in march.
Let's hope that dyno has some way of measuring diesel engine rpm... if so I might do my D24T just for fun.
-Tyler
No mercedes (for now)
casioqv
-Tyler
300D50
Graphite Moderator, ala RBMK
02-07-2011, 12:29 PM #164
It better, most dyno's can read a tach amp signal...
300D50
dieselboy
680
02-07-2011, 02:50 PM #165
Actually I have 2 dyno dates in march. I hope my 10mm elements show up before the 2nd one.
Does anyone have the tool to remove the precup or has anyone made a tool? It doesn't look to hard to make. But if I had a pic it would make making it alot eaiser.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
casioqv
OM602 Turbo
116
02-07-2011, 02:52 PM #166
(02-07-2011, 02:50 PM)dieselboy Does anyone have the tool to remove the precup or has anyone made a tool?
You can rent it on PeachParts, or buy it from MercedesSource. You need a slide-hammer with a special attachment to pull the pre-chamber, and a separate tool to remove and re-torque the locking collar that holds it in. Maybe you can copy the design from the MercedesSource photos?
This post was last modified: 02-07-2011, 02:57 PM by casioqv.
-Tyler
casioqv
-Tyler
02-07-2011, 02:59 PM #167
(02-07-2011, 02:50 PM)dieselboy Actually I have 2 dyno dates in march. I hope my 10mm elements show up before the 2nd one.
I have the shimano crank bolt and the lock ring tool. Security deposit + shipping + 6 pack.
casioqv
OM602 Turbo
116
02-07-2011, 03:02 PM #168
(02-07-2011, 02:59 PM)winmutt I have the shimano crank bolt
The pre-chamber puller is the same threads as a bicycle crank puller?
-Tyler
casioqv
-Tyler
300D50
02-07-2011, 03:03 PM #169
When didya order em? how much?
300D50
02-07-2011, 03:09 PM #170
(02-07-2011, 03:02 PM)casioqv
22m * 1. Yes. $9 at any bicycle shop.
02-07-2011, 03:19 PM #171
(02-07-2011, 12:28 PM)casioqv
WOT Performance in riverside can do diesels all day Tongue
dieselboy
680
02-07-2011, 03:41 PM #172
I'm going to a socaps meet at Fontana sunrise ford on Sunday the 8th. Since the bronco transmission is in 2 pieces im taking the merc.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
02-07-2011, 03:56 PM #173
Pulling the prechamber is the easiest part, its removing and torquing the collars without fucking up the slots thats difficult.
MTUPower
287
02-07-2011, 10:45 PM #174
(02-05-2011, 07:31 PM)jeemu Om616. If you need some information, shoot at pm.
PM box is full... waiting to send one.
MTUPower
02-08-2011, 01:17 AM #175
I think Kent's tools are pretty cool..
http://www.mercedessource.com/node/8478
http://www.mercedessource.com/node/8479
02-08-2011, 05:42 AM #176
(02-08-2011, 01:17 AM)Captain America I think Kent's tools are pretty cool.
Just the typical rip-off price for Mercedes$ource.
02-08-2011, 09:41 AM #177
diesel911 over at peachparts makes a good tool. I have an early variation of his tool but similar to the current version.
http://www.peachparts.com/shopforum/show...p?t=282469
02-08-2011, 10:14 AM #178
(02-07-2011, 03:56 PM)ForcedInduction Pulling the prechamber is the easiest part, its removing and torquing the collars without fucking up the slots thats difficult.
With the right tool its a cinch. I ruined three sockets making a home made tool. The secret is the angle of the dog ears and the ability to lock them in.
Motorhead
02-10-2011, 12:50 AM #179
Man this is a great site, I remember about a year ago there was some heated discussion about pc's but not like this, imho I think there can be some tunning advantages screwing around with the pc and I agree the best way to find clues to this question is on the dyno.
One thing I have access to is both chassis & engine dynos so there may be some testing on hot bulb changes going on in the I.E. for the SoCal crew, keep this thread going!
Motorhead
dieselboy
680
02-10-2011, 01:42 AM #180
Where we talking? I wanted to compare stock to modified with my stock injection pump and then stock vs modified with my 10mm pump.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
BRABUS
02-10-2011, 07:00 AM #181
Hi
Anyone know what threads on the pre-chamber puller ?
BRABUS
Hi
02-10-2011, 10:08 AM #182
22mm x 1. You want to use the shimano crank puller, available at your local bike store. Walmart didnt carry it last time I checked.
02-10-2011, 04:16 PM #183
(02-10-2011, 01:42 AM)dieselboy Where we talking? I wanted to compare stock to modified with my stock injection pump and then stock vs modified with my 10mm pump.
Yeah Where!?!
Yeah Where!?!
BRABUS
02-10-2011, 04:44 PM #184
(02-10-2011, 10:08 AM)winmutt 22mm x 1. You want to use the shimano crank puller, available at your local bike store. Walmart didnt carry it last time I checked.
like this?
http://cgi.ebay.com/NEW-Shimano-BIKE-TL-...5197887dfa
Thanks !
BRABUS
like this?
Thanks !
02-10-2011, 05:00 PM #185
Looks about right.
Looks about right.
gen3performance
I like the smell of No. 2......
89
02-11-2011, 03:34 AM #186
I'm as curious about this topic as everyone else here and would like to see some results.
I'll donate a set of five pre-cups from a 1981 SD to whoevers going to the dyno. Whoever wants them, just PM me.
It would be nice to see the graphs from a variety of different sized precups and just how the hp/torque curves increase or decrease or move around.
Now that I think about it, I have two sets of five I'll donate.
This post was last modified: 02-11-2011, 03:41 AM by gen3performance.
1981 300SD...Too much propane = bent rods. Junked
1980 240D...Body fell off. Saved drivetrain and junked
1985 300D...No.2 and N2O = 16.35@85mph. Sold Sad
1999 E300TD...3" exhaust with banks muffler, Hx-35, 215hp tune, IP resistor box, bad crankshaft snout Angry
2005 E320 CDI...AMG injectors, EGR removed, mapping
Vids! http://www.youtube.com/user/silverado408
Pics! http://s776.photobucket.com/albums/yy42/...rformance/
gen3performance
dieselboy
680
02-11-2011, 12:35 PM #187
I'm good I have 3 spare sets and 1 set of 4 that the 5th one broke off and fell into the cylinder.
If any one else in the SoCal area would like to dyno on march 6th pm me I'll give you the info.
It's 50$ for a run. Last time 1 run = 3 pulls.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
02-11-2011, 04:00 PM #188
I've got two spare sets that still need to be pulled ...
85-300Dt
02-11-2011, 09:16 PM #189
pulling 'em is one thing, as i understand refitting is a precision deal ..from peach
Quote:TimFreeh
10-01-2003, 10:29 AM
One other measurement that is critical is the dimension that the prechamber tip protrudes out from the head.
This post was last modified: 02-11-2011, 09:29 PM by 85-300Dt.
85-300Dt
02-12-2011, 06:54 AM #190
(02-11-2011, 09:16 PM)85-300Dt pulling 'em is one thing, as i understand refitting is a precision deal ..from peach
Not at all. The only thing you need to consider is if the head has been machined. If it has, you use a thicker seal ring.
dieselboy
680
02-12-2011, 07:46 PM #191
Nope they are key'd and bottom out.
They can only go in one way.
This post was last modified: 02-12-2011, 07:47 PM by dieselboy.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
tomnik
02-13-2011, 04:19 AM #192
there are different shims to adapt the hight position for different head thickness (dressed to seize after repair).
Tom
tomnik
Tom
02-22-2011, 03:50 PM #193
Looks like I have all three? styles of pre chamber now... '81, '82, '85 in my hands
dieselboy
680
02-22-2011, 04:17 PM #194
Yeah I was looking at the ones I pulled they have 3 different sized holes I needto buy some drill bits.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
02-23-2011, 05:33 PM #195
(02-22-2011, 03:50 PM)Captain America Looks like I have all three? styles of pre chamber now... '81, '82, '85 in my hands
Clean them up and lets see some pics for starters!
yankneck696
Build it so strong &amp; blow it up good !!!
395
02-23-2011, 06:17 PM #196
I am looking forward to real results on this. I think there is room for improvement in them.
Ed
yankneck696
Ed
02-24-2011, 01:15 AM #197
(02-23-2011, 05:33 PM)winmutt
I still need to get the tools to pull them. The '82 and '85 don't run. Im driving the '81 currently. I will pull all three, compare and come back with pics
02-24-2011, 08:48 AM #198
You can get the ring collar tool at pelicanparts the cheapest. I have one you can borrow for shipping costs both ways. I also have a 22mmx1 ring you can borrow. The ring, a washer, bolt and a slide hammer will pull em out. You will need replacement shims but they are cheap.
02-24-2011, 04:08 PM #199
Thanks for the offer.
I'm definitely gonna buy the tools
You have a link to pelicanparts? it's not working for me...
02-28-2011, 12:21 PM #200
http://www.pelicanparts.com/euro/catalog...D_pg10.htm
If you want you can buy mine. I sincerely doubt I will be using it anytime in the future.
 16 Guest(s)
 16 Guest(s)
