STD Tuning Engine Noob questions on NA 606
okto
02-04-2011, 04:00 PM #1
Seeing the amazing power results people are getting out of the OM606 is tempting me to follow down that path. But I have a few questions!
I have a 95 E300D, which has the NA OM606. I want some more power out of it, but I don't need it maxed. I know a turbo can be added to the NA motor, and I've seen references to 300HP with "bone stock internals".
Does this mean all I have to do is add a turbo and turn up the stock IP to get more power?
I like my 700-mile cruise range, so I don't want to lose that efficiency when I drive politely. ^_^ What kind of fuel efficiency numbers can I expect with a turbo'd stock-pump 606? I hear things about turbodiesels being MORE fuel efficient—truth?
One last question—the NA 606 has the resonant intake to address the lack of high-RPM torque in an NA diesel. I'm wondering if the resonance flaps are going to cause problems when being fed compressed intake air. Will they function the same way under boost, or is the resonance system going to screw things up?
Sorry for all the newbie questions. I've been lurking this forum for a while and getting lots of good info, but it seems like most of the info concerns either 617s or turbo 606es. Can't wait to start tuning a SuperTurboDiesel of my own!
1995 E300D 248,000mi and counting!
okto
95e300dez
95E300td
89
02-05-2011, 11:47 AM #2
Check out my build you will start on yours right away. I experienced better fuel mpg all together as long as you don't beat on it all the time. I can say it is fun to drive right by other cars from a stand still. As far as the pump goes I just turned up the pump like explained on this website real easy to do. I still have the flapper valves working and it doesn't seem to hurt performance but I also have not tried it with it disconected.
95e300dez
okto
02-05-2011, 02:11 PM #3
I definitely saw your thread, D.E.Z! Super inspiring. I had heard of people turbo'ing the NA before, but it's great to have pix of a completed one. I guess you're the only person that's done it and documented it?
I'll definitely be asking you some questions in a few months when it's outside weather again here. I don't have a garage, so I'm at the mercy of mother nature.
okto
mantahead
02-05-2011, 02:30 PM #4
(02-04-2011, 04:00 PM)okto Seeing the amazing power results people are getting out of the OM606 is tempting me to follow down that path. But I have a few questions!
hi
i was wondering about that flap because i am fitting an om606 inlet manifold to my om605 because my manifold is plastic and not easy worked with. I was just going to remove it but i didnt know what it was really for until i read this. I wonder what way it would work with big boost?
wayne
mantahead
hi
wayne
okto
02-05-2011, 06:36 PM #5
Not easily worked with how? Also, I don't think an OM606 crossover pipe will fit. It has tandem openings at the manifold end.
okto
muuris
OM605
318
02-06-2011, 02:14 AM #6
Not easily worked with because it's plastic and the boost pipe connection faces the turbo, as in 606 it faces downwards and goes near the IP. Much better for big IC install.
Jeemu has his manifold done by cutting 606 manifold and welding it back together. See this and this.
muuris
mantahead
02-06-2011, 08:16 AM #7
(02-06-2011, 02:14 AM)muuris Not easily worked with because it's plastic and the boost pipe connection faces the turbo, as in 606 it faces downwards and goes near the IP. Much better for big IC install.
hi,
that looks like n/a manifold, did Jeemu remove the flap inside?
wayne
mantahead
hi,
wayne
okto
02-06-2011, 11:57 PM #8
It looks like part of a 605 manifold welded to an NA 606 manifold. Seems simpler to just buy a turbo 606 manifold.
okto
jeemu
457
02-08-2011, 05:15 PM #9
There is used OM606 N/A intake manifold
just cut one cylinder off (Cylinder 4). All om605 intake manifolds are plastic
so to do some changes of those not be easy.
My new manifold is made OM606 tdo and AMW dual plenum
intake
jeemu
intake
mantahead
02-09-2011, 05:28 PM #10
(02-08-2011, 05:15 PM)jeemu There is used OM606 N/A intake manifold
intake
hi,
you can also cut of (cyclinder 6) and it will bolt straight on as stud pattern is the same.
wayne
mantahead
intake
hi,
wayne
jeemu
457
02-12-2011, 04:33 PM #11
(02-09-2011, 05:28 PM)mantahead
intake
hi,
wayne
Hi yes it can, but if use original oilfilter you cant cut 6 of.
jeemu
intake
hi,
wayne
mantahead
02-13-2011, 09:21 AM #12
[/quote]hi,
wayne
[/quote]Hi yes it can, but if use original oilfilter you cant cut 6 of.
[/quote]hi,
i was wondering why you cut off (cyclinder 4). I have not tried my manifold to engine yet as it will not fit as the manifold is too long and hits the inner wing. I was working of gasket pattern. Thanks, it looks like im going to have an oil filter issue.
wayne
mantahead
[/quote]hi,
wayne
[/quote]hi,
wayne
mantahead
03-04-2011, 06:37 PM #13
[/quote]hi,
wayne
[/quote]hi,
you can if you grind the back of the manifold runner and cut the hexagon nut of the top of the oil filter cap. I have it fitted.
mantahead
[/quote]hi,
wayne
[/quote]hi,
 4 Guest(s)
 4 Guest(s)
