STD Tuning Drivetrain Moving the starter?
Moving the starter?
Moving the starter?
02-10-2011, 01:17 PM #1
So fha772 pointed on the 280 that you can apparently use a different backing plate and swap the starter position. I looked at a few engine pics this morning and with the oil cooler moved there might be enough room to do this with a 617 as well. I did notices that on the left side (viewing from back) there is a bit of a slope and may not be possible. If anyone has a 617 out of the car and doesn't mind playing around with this some, see if it looks like fitment is possible.
Some pics from PP:
[Image: 5109063238_e8f60dedd6_b.jpg]
[Image: 5109066022_31b45db772_b.jpg]
[Image: 5108467447_cfc8a374a6_b.jpg]
[Image: 5128893189_788eee6082_b.jpg]
Anyone have better pics or actual blueprints?
Some pics from PP:
300D50
Graphite Moderator, ala RBMK
02-10-2011, 02:09 PM #2
I've got an NA 617 on the stand, get me the measurements you want.
300D50
dieselboy
Rotatin 5500 times a minute
680
02-10-2011, 02:20 PM #3
I've got 2 617's (turbo) in the garage too.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
02-10-2011, 02:30 PM #4
I also have 617 in storage I can take pics of.
Rudolf_Diesel has my other 617 and he has an intermediate plate that I gave him (probably doesn't matter if were talking about moving the starter. He might already have measurements.
This post was last modified: 02-10-2011, 02:30 PM by DeliveryValve.
02-13-2011, 10:46 PM #5
Please take measurements. If this is not a pipe dream....
02-14-2011, 07:10 AM #6
these guys moved the starter to down low on the left with the stock setup still intact-
He said he used the stock starter too, and there was plenty of room down there.
Are we talking moving the starter so its on the opposite side high where the oil filter would be? If thats the case, I think a stock starter would hit the injection pump on a 617
This post was last modified: 02-14-2011, 07:14 AM by JB3.
02-14-2011, 10:29 AM #7
(02-14-2011, 07:10 AM)dropnosky these guys moved the starter to down low on the left with the stock setup still intact-
Well the idea is to see if you can mount the 201/124 5spd on a 617 simply by swapping the backing plate and starter. Its an pipe dream for now...
02-14-2011, 02:00 PM #8
(02-14-2011, 07:10 AM)dropnosky ...
That might be so. But when I briefly explored this idea in the past and measured, it was something like 9 inches from the intermediate plate to the starter bracket and something like 7 inches from the intermediate plate to the IP back cover. But I think the IP is mounted higher and might clear the starter if you use an '85 cali version. I look at it more later when I get a chance.
dieselboy
680
02-15-2011, 01:08 AM #9
I played around a little with one today. I have. Adapter plate off of the engines so I flipped it over and set it on the back of the block backwards. You would definitely have to put it down lower. The filter housing is in the way big time. It looks like it may clear the ip.
I took pics but I couldn't find my tape or a ruler lol. So here are a few pics. I'm still sorta unclear of what it is that you are asking.
[Image: 2a281bce.jpg]
[Image: cb8beeb8.jpg]
[Image: 20b68b0c.jpg]
You can see the oil filter housing is clearly in the way if you were to flip the plate.
[Image: ad7041c4.jpg]
I'll bring my tape home tomorrow and measure the distance you have to put a starter in there.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
02-15-2011, 07:26 AM #10
I think it is alot easier to make a remote oil filter than it is to make a dropnosky transmission Big Grin
02-15-2011, 09:00 AM #11
(02-14-2011, 02:00 PM)DeliveryValve ... But I think the IP is mounted higher and might clear the starter if you use an '85 cali version. ..
Oops I just thought about this, by putting the Federal starter on the other side effectively makes it like a Cali version. The solenoid will be upside down.
(02-15-2011, 01:08 AM)dieselboy I'm still sorta unclear of what it is that you are asking.
There is general consensus that the oil filter housing is in the way. Which you've shown with your pictures. The other issue is whether or not the starter will clear the IP. I think it will, because the IP is mounted slightly higher.
Regarding the oil filter housing, a remote filter will get it out of the way. But I am inclined to keep the stock filter housing. I would be interested in block adapter and hose adapters that will effectively raise the filter housing up so it will clear the starter and still keep a stock look.... That is if I am going to install a 6 speed manual trans or maybe build up a 722.5 overdrive or adapt 722.6......
This post was last modified: 02-15-2011, 09:09 AM by DeliveryValve.
300D50
02-15-2011, 09:25 AM #12
I'm tooling up to do a run filter adapter plates, would be trivial to add the bypass port as well to keep the stock housing.
If needed, I could even do an "exotic" top exit plate for the block one, if it's needed to clear the starter. Wouldn't be too hard, just a little more time and stock.
300D50
02-15-2011, 09:32 AM #13
(02-15-2011, 09:25 AM)300D50 I'm tooling up to do a run filter adapter plates, would be trivial to add the bypass port as well to keep the stock housing.
It really depends on what type of filter your using. If your using something like an Amsoil setup. Then no.. If your using it to remote the stock filter somewhere else. Then yes.
02-15-2011, 09:35 AM #14
(02-15-2011, 09:00 AM)DeliveryValve Regarding the oil filter housing, a remote filter will get it out of the way. But I am inclined to keep the stock filter housing. I would be interested in block adapter and hose adapters that will effectively raise the filter housing up so it will clear the starter and still keep a stock look.... That is if I am going to install a 6 speed manual trans or maybe build up a 722.5 overdrive or adapt 722.6......
Is there enough room under the hood to raise it that much? What about the 280 starter?
02-15-2011, 09:38 AM #15
(02-15-2011, 09:35 AM)winmutt ..
Oh yeah it will clear. Your not raising it much. The filter housing top will still sit lower then the valve cover. The issue is really is if the block adapter will be thin enough so it will not protrude out to the starter.
This post was last modified: 02-15-2011, 09:40 AM by DeliveryValve.
SurfRodder
Jackass Extraordinaire
611
02-19-2011, 01:14 AM #16
I am definitely interested in this as well... so what you guys are basically talking about doing is pulling the adapter from a gasser to put the starter on the other side to facilitate the newer trans? That would be totally awesome if that worked! I'd def. have no problem ditching the oil tower and going remote if it gave be more gears to grab.
OBK# 62
SurfRodder
OBK# 62
02-23-2011, 05:36 PM #17
It gives me an excuse to start looking for 280s with missing trans.
03-04-2011, 10:46 AM #18
Stagger Lee sent us some pics!
03-05-2011, 02:29 AM #19
(03-04-2011, 10:46 AM)winmutt Stagger Lee sent us some pics!
Nice. Looks like it will work.
(02-15-2011, 09:38 AM)DeliveryValve
Hey 300D50, you think you can make an adapter that will just raise the filter housing a bit to clear the starter?
Heck I wouldn't mind if the housing is outward a bit also so I can easily reach that damn #5 glow plug!
This post was last modified: 03-05-2011, 02:34 AM by DeliveryValve.
300D50
03-05-2011, 02:06 PM #20
Conceptually, yes, I could. Was thinking about it since the discussion started.
The only limiting factors would be vibration causing fatigue in the adapter if the housing is raised up too far.
Just need to know the clearances involved.
300D50
03-05-2011, 04:14 PM #21
(03-05-2011, 02:06 PM)300D50 Conceptually, yes, I could. Was thinking about it since the discussion started.
Perhaps making it out of mild steel? Yes clearance would have to be determined.
300D50
03-05-2011, 06:50 PM #22
Steel is an option, aluminum is easier to work with and doesn't rust. Trade-offs suck...
300D50
Syncro_G
0-60 in 29 sec
280
03-06-2011, 01:51 AM #23
It seems that if you're fabbing an adapter plate, that the V8 trannies with a starter blister on both sides of the bell would fit with little headache.
Any reason not to consider those?
'84 G-Wagen turbodiesel
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
tantank79
T3-45
109
04-28-2011, 10:58 PM #24
I just looked under the hood of my 280 only to find the M110 starter in the same spot as the OM617 started. Is there some other factory MB engine plate with a starter hump on the driver side, that could bolt to the OM617? I've heard some of the V8s had a provision for the starter on either or both sides.
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
-Brian
1983 300TD
1982 240D
1981 280TE
