STD Tuning Engine OM606 MAF Sensor
OM606 MAF Sensor
OM606 MAF Sensor
gen3performance
I like the smell of No. 2......
89
02-11-2011, 02:41 AM #1
So I'm doing some winter mods to my 99 E300TD and I've got a question.
Is there a way to eliminate the mass air flow sensor on the 606? From what I understand the MAF only controls the EGR of the engine...just wondering if this is correct.
I have had my ECU remapped and also had the EGR function disabled with the remap...can I just remove the MAF totally without problems? Or do I need to install some resistors in its place? Any information on this will be greatly appreciated.
1981 300SD...Too much propane = bent rods. Junked
1980 240D...Body fell off. Saved drivetrain and junked
1985 300D...No.2 and N2O = 16.35@85mph. Sold Sad
1999 E300TD...3" exhaust with banks muffler, Hx-35, 215hp tune, IP resistor box, bad crankshaft snout Angry
2005 E320 CDI...AMG injectors, EGR removed, mapping
Vids! http://www.youtube.com/user/silverado408
Pics! http://s776.photobucket.com/albums/yy42/...rformance/
gen3performance
E300TSC
Turbo-Supercharged
321
02-11-2011, 05:45 AM #2
Based on my experiments, the MAF sensor also controls the "ceiling" of fueling at any given moment. It also has something to do with the transmission shifting properly.
I concluded that it doesn't hinder performance and it can be replaced for under $50 all day long so I abandoned my plans to eliminate it.
E300TSC
tuikku
02-11-2011, 06:09 AM #3
MAF/EGR do not control fuelling, it just follows the fuelling rate.
Allmost all MB´s are pressure controlled.
If there is something wrong in MAF/EGR -> limp mode, when fuelling/revs are very limited.
tuikku
gen3performance
89
02-17-2011, 02:55 AM #4
Where can I buy a MAF in the 50 dollar range?
gen3performance
E300TSC
Turbo-Supercharged
321
02-17-2011, 05:35 AM #5
I just replaced the insert with this one:
http://cgi.ebay.com/ebaymotors/MAF-Mass-...1315wt_940
E300TSC
gen3performance
89
02-17-2011, 04:04 PM #6
Awesome!
gen3performance
Awesome!
Olivier
02-17-2011, 04:22 PM #7
I asked the seller and the shipping to the UK was 30 quids Sad This made it too dear...
Olivier
300D50
Graphite Moderator, ala RBMK
02-17-2011, 05:29 PM #8
Ask him/her to use USPS flat-rate international, it should be much cheaper.
300D50
Olivier
02-18-2011, 04:49 AM #9
He said this was all he could do Sad Then I said nope.
But I got another MAF from RON, the MAF electronic twaek I posted earlier, its a Pierburgh, look like it has the same properties as the 029, but I found out that if I tilt it slightly, the car is mighty again Smile
I might have been running too rich before?
Olivier
Olivier
Olivier
